Question about Frigidaire FD5125 5.5 Liter Stand Mixer, Meat Grinder & Blender 220 Volts"
Machine not starting
I bought from kuwait new frigidaire fd5125 5.5 liter stand mixer ,meat grinder & blender 220 volts since about 1 month... I transfere it to egypt where there is no dealler to this product .... When i tried to use it for first time it did not start at all what can i do and what is the possible causes .... Please help me .... I cant take it back to kuwait because it is very heavy 15 kg ... Thanx
SOURCE: Frigidaire LEQ2152ES Electric dryer
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
Posted on Jan 03, 2008
  • 58 Answers
SOURCE: Dryer Won't Start
try to turn the drum by hand
Posted on Mar 12, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Posted on Dec 03, 2008
MNfisherman
  • 11896 Answers
SOURCE: My Frigidaire heavy duty dryer stopped working.
The loud noise could be a faulty or worn out motor. Or if the motor is good, the drum bearings might be worn and motor cannot turn drum. You will most likely have to remove some access panels to get a closer look at where the sound is coming from. There is excellent videos and information on howstuffworks.com that will explain the workings of a dryer and troubleshooting and more.
But please feel free to ask any other questions you may have.
Posted on Oct 14, 2009
  • 16 Answers
SOURCE: My 13 year old step-daughter tried to add
It sounds like the door latch is not working correctly. As a safety feature the unit will not run without sensing the latch is locked. Check the male end on the door first. If that is not broken then you will need a new door latch assembly.
Posted on Jul 06, 2010
Where can I get repair parts & repair manual for my Frigidaire FD5125 All-in-One Mixer, Meat Grinder, Blender, 220 Volts?
go on line to the manufacturer customer or spare parts departments and make enquiries as to service centres near you
Apr 27, 2015 | Food Mixers
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
I have osterizer food grinder( Detouchable) but machine was lost where can i find a replacement for the machine...
If you mean the one that attaches to a Kitchen Center, they are no longer available, eBay or garage sales are your only hope.
http://www.ebay.com/itm/OSTER-REGENCY-KITCHEN-CENTER-MEAT-GRINDER-ACCESSORY-/270805020990
Same with the free-standing models they had.
Sep 12, 2011 | Blenders
I was using meat grinder attachment and stand mixer stopped running
I just got the same problem too. There was a little piece of fat in the meat and it stopped the grinder. I removed it but the attachment rotates a full turn and then stops. The same happens with other attachments even under practically no load.
Dec 02, 2010 | KitchenAid Food Mixers
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Black Residue on meat using Kitchenaid meat grinder attachment
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid sausage maker does not stuff the sausage casings
This may be a problem with assembly of the Sausage Stuffer Attachment. Your Use and Care Guide for both the Food Grinder and Sausage Stuffer could illustrate the assembly for you in detail.
Also, it may take up to 4 minutes after meat is fed through the top of the Food Grinder for it to start stuff into the casings. The meat is fed into the Food Grinder, ground, and then pressure is built up behind this ground meat to push into casings.
Jun 01, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Frigidaire FD5125 5.5 Liter Stand Mixer, Meat Grinder & Blender 220 Volts" Logo
380 people viewed this question
Top Frigidaire Home Experts
Donni Steen
Tom Chichester
Are you a Frigidaire Home Expert? Answer questions, earn points and help others
