Alps MD1000 press power printer makes some noise and error light comes right on Will not load paper and cannot run self check
fcollingwood
  • 58 Answers
SOURCE: Alps MD1000 printer.
MD-1000s hit end of support almost 10 years ago. Chances of getting spares are nil.
Best bet is to get a junker of eBay for spares, or you can get a new MD-5500 from http://www.alps-supplies.com
Posted on Sep 02, 2008
fcollingwood
  • 58 Answers
SOURCE: ALPS Printer MD1000 Driver
Several things about these printers.......
1. Do NOT use the MS XP driver for these - it has limited functionality. Download the Alps driver, which you can find in the files section at the Alps YahooGroup (http://tech.groups.yahoo.com/group/Alps/files/)
2. The printer requires bi-directional comms in order to feed back the printer status to the computer. While this is not an absolute requirement, it means that without bi-dir comms, the error light will flash, and you won't know what the problem is.
3. The driver is hardcoded to only communicate bi-directionaly with Alps virtual LPT ports - run this with a non-Alps cable (And all of the cables on FleaBay are non-Alps), and you will not be able to monitor the printer status.
Now, how to install.....
1. Plug in the USB cable to the computer (But not the printer), and let it install. Reboot if required (Unlikely)
2. Install the Alps driver you downloaded fron the Alps YahooGroup. Reboot if required. If you now look at Printers in Control Panel, you will see a nice Alps printer there, waiting to be used. Make a note of what it named.
3. Plug in the printer and turn it on. XP will now tell you it has found new hardware, and install the MS driver. Reboot if required
4. Go back to Printers in Control Panel. You will now see you have TWO Alps printers! The MS driver will be called something like "Alps MD-1000 (MS)". Rename (DON'T delete!) this driver to something like "Alps MD-1000 (DO NOT USE)". If you delete it, it will come back to haunt you every time you switch on the printer, and screw up your settings.
5. Open the properties page of the driver you made a note of in step 2 (Control Panel -> Printers and Faxes -> right click on printer, and select "Properties"), and click on the "Ports" tab.
6. Check the checkbox next to the port created for your USB-// cable, and uncheck the other box that will be checked.
7. Uncheck "Enable bidirectional support"
8. Click on the "Advanced" tab
9. Select the "Print directly to the printer" radio button
10. Click on the "Print Processor" button
11. Select ALMD224S as the Print processor and select RAW(FF AUTO) as the Default data type
12. Click Apply.
Posted on Sep 04, 2008
fcollingwood
  • 58 Answers
SOURCE: ALPS MD1000 Won't print
Please ignore courtdate & creamgetmonE. Here's why:
creamgetmonE - If you're using the XP driver, you are using something so crippled, it should have been aborted. USE THE ALPS DRIVER!!!!!!!!
courtdate, oiling the carriage rail will not change a thing, apart from gunking up the printer, and ENSURING it will fail sometime in the future.
TO FIX YOUR PROBLEM:
There is a sensor under the anti-curl veil. Clean it.
Posted on Jul 19, 2009
  • 83 Answers
SOURCE: MD 1000 Thermal Printer: I need a driver for ALPS MD1000 printer that will ...
Go to the ALPS Yahoo Group. They have an extensive file section with drivers. Windows will use the default plug and play driver for the printer. The MS version is very limited. You should rename the MS driver to something else like "MS Alps Driver" and then install the ALPS driver you find at the Yahoo Group. These will give you full functionality.
good luck
Posted on Jun 04, 2010
  • 83 Answers
SOURCE: Alps MD1000 printer won't do anything.
Do you get the green ready light when you first turn on the printer?
Posted on Nov 05, 2012
Nov 05, 2012 | Alps MD 1000 Thermal Printer
Alps md 1000 printer wont print
Make sure that you have the dark grey cartridges and not the blue cartridges. The blue ones will not work in the MD1000. Can you tell us more about the problem? Have you tried an internal self test print?
Jun 17, 2012 | Office Equipment & Supplies
I just want to run the self-test, but my MD 5000 won't do it. When I finish the button sequence to start the self test, it just makes some crunching & whining noises, then the power and error...
Check to make sure you have the dark grey ink cartridges installed in the printer. The blue (photo) and the Econo Black cartridges cannot be used for the self test.
Sep 02, 2011 | Alps MD 5000 Thermal Printer
How to test the MD 1300 , also look on how to get error codes...
One test you can run is the self print test. Discount the printer from your computer. Load a single sheet of paper and the CMYK cartridges. Turn on the printer. Press and hold the "reset" button until the lights begin to flash. Release the "reset" button and the printer should do a self print test.
Dec 26, 2010 | Alps MD 1300 Thermal Printer
good luck
May 16, 2010 | Alps MD 1000 Thermal Printer
Will not print. turns on lights up makes noise
There are two self tests you can try to test the printer. With only the black cartridge and on sheet of paper. Disconnect the printer from the computer and unplug it. Plug it back in and do the following:
Press and hold the power button. At the same time, press and hold the Ready/Insert button. Release the power button, but keep holding the Ready/Insert button. After 4 seconds, release and press the button again and release. It should print a one page diagnostic test.
The second self print test using all 4 cartridges. Turn the printer on, press and hold the Ready/Insert button for a few seconds and release the button. The test will use all 4 inks.
Jan 02, 2010 | Alps MD 1000 Thermal Printer
Driver and software disc lost for Alps MD1000
Join the Alps mailing list at YahooGroups. The drivers are in the files section.
No Vista, 95/98/Me/NT/2000/XP only
Apr 29, 2008 | Alps MD 1000 Thermal Printer
Jan 18, 2008 | Alps MD 1000 Thermal Printer
Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at http://tech.groups.yahoo.com/group/Alps/
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
Reboot
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Nov 08, 2007 | Alps MD 1000 Thermal Printer
12. Click Apply.
Sep 23, 2007 | Alps MD 1000 Thermal Printer
20 people viewed this question
jasbo
jasbo
