Question about Vacuums
How to check wether a motor is working
I have a Euroclean Mitey Vac EC300 . Its not working. So I am checking all the parts of the Cleaner.So can anyone tell how a vaccum motor can be checked .
  • Vacuums Master
  • 1,534 Answers
I remove the power wires going to the motor and wire a power cord directly to the motor to see if it will run.
Posted on Apr 21, 2014
5 Suggested Answers
SOURCE: Kenmore Whispertone model 116, 29512991
unfortunatly what happens is the dirt that gets sucked up goes over the moter and ruins the motor. the fact that it lasted this long is suprising. the motor should be right behind the bag the only one that ive seen that isnt there is a kirby! I hope this helped you!
Posted on Feb 27, 2008
  • 231 Answers
SOURCE: how to dissasmble vacuum cleaner, kirby g4 to
before you do all this, check the cord where it mounts to the handle up top by the pivoting strain relief. Frequently the cord goes bad right where it snaps in the strain relief.
first you will need to remove the handle, bag, and the cord. there is a release button for the handle, the mini emptor on the bottom of the bag twists off away from the body. there should be 2 screws on the scuff plate, one to hold the cord strain relief and another down by the transmission for the scuff plate. use a small flathead screw driver in the slot of the scuff plate and pry up. it will pop off. you should also take out the screw in the cord cover where it plugs, pop the cover off and remove the cord. now you can remove the top cover. there will be 2 screws in the front of the unit, and 2 screws under the scuff plate. they are either phillips or T15,T20 torx. remove those 4 screws and you can lift the top cover off and access the motor and the switch. check for bad motor carbon brushes and a worn commotator where the brushes ride. let me know if you need anything else.
Posted on Jan 03, 2010
  • 15273 Answers
SOURCE: Miele Vacuum Cleaner - burning smell / motor won't stay on
check brush the belt may have popped off and is binding or brush is binding clean brush of any debris thread/hair wrapped binding brush and check and or replace belt
Posted on Mar 24, 2010
heatman101
  • 43501 Answers
SOURCE: how do i disassemble bissell proheat model 8910
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
I want rubber washer to attach hose pipe of mitey euroclean ec300
Go to a used vacuum place they will have them there.
Jun 25, 2014 | Vacuums
No suction in vaccum cleaner
Look for a clog somehere in the intake path, perhaps right at the top of the canister.
Feb 13, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How to replace brushes
if its a up right vac turn in up side down probley 2 2 4 screws holw the bottom on the u can take the bottom off the brush should come out by pulling up on the brush just sets in slots jesus saves an loves you more than any body can in this world
Nov 05, 2013 | Euroclean 930 Canister Vacuum Cleaner Bags...
My Vacuum Cleaner Machin Euroclean Bullet Deep Plus was Bearing Problem Please Send Bearing Details Urgent
This is NOT the place to obtain parts for your machine. You need to contact your local vacuum dealer to get the parts you need. I hope that answers your question.
Oct 15, 2013 | Vacuums
When the switch is turned on the vaccum cleaner starts running instead of,when the hose is connected. removed the earth lines from the unit and truned on the vaccum cleaner. It did the same. What might...
Dirty switch at vac where hose connects go to radio shack get some tuner cleaner spray. spray this switch and plug hose in and out a few times spray again see if this works
Feb 26, 2011 | Broan-NuTone CV554 Cyclonic Bagless...
Just receved this steam vac and noticed the floor was still very wet after using on a small area. looked at bottom and it has the one long stright row of brush and nothing behind(large gap, with some...
If their is problem with the sucction,you should clean or replace the bag seen inside your vaccum cleaner
If any basic part of your vaccum cleaner lost excludes brushes and cleaners you can't use it.
Feb 15, 2011 | Vacuums
Mar 24, 2010 | Miele S318 Bagged Canister Vacuum
I need a wiring schematics for my ezi-vac 2(euroclean) please.
Thanks for getting back to me,i solved the problem by asking a vac tech and he told me what to do ,it was easy.cheers gazza.
Feb 20, 2009 | Electrolux Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
