Question about Husqvarna Chain Saw 20" Bar
Can chain oiler on husqvarna be adjusted as the oil is just flowing through
You can not adjust the oil pump it helps to use the right oil
Posted on Jun 20, 2009
Can the chain oiler be adjusted on a 141?
No adjustment possible.
But that can be good news when you got good oil as you can run a longer bar and chain up to 20" The shorter the bar the more oil present on the chain and bar during operation
Jan 08, 2015 | Husqvarna 36 41 50 51 55 136 141 154 254...
HOW AND WHERE TO ADJUST THE OILER ON THE 240 HUSQVARNA
The Husqvarna 240 does not have an adjustable oiler. Always use good quality bar and chain lube, never motor oil.
Jun 14, 2014 | Husqvarna Garden
Husqavarna rancher not oiling. I removed the chain and bar and cleared out ports on bar and still not oiling. I adjusted oil flow screw, but it didn't help. Someone said to remove the oiler, but...
Husky has pretty good exploded view diagrams on their website. I would try there to see if you can figure out how it gets removed.
Here is their helpful website:
http://www.husqvarna.com/us/homeowner/support/download-manuals/
good luck.
Aug 26, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
When i get about half way through a log my chain begins to smoke as if it is hot i have been round chainsaws enough to no that its not getting oil.. So i pull if from the log and place the tip above the...
Depending on the model, yes. But first I would remove the bar and chain and make sure the 4 or 5 square openings behind the bar for the auto oiler are not clogged with gunk. If everything is clear and the oiler adjustment is turned up as high as possible (15ml/min), you may have a problem with the internal pump.
Also, a chain will smoke if the tension is incorrect. Before you use it again, when cold check the chain tension. You should be able to see about half of the chain drive when pulling on the chain. Another thing may be the sprocket tip if applicable. Make sure it is properly greased each time you add fuel/bar oil.
May 20, 2010 | Husqvarna Chain Saw 20" Bar
Auto oiler not working
Remove the bar cover. Remove the chain and bar. Behind the bar you will see a set of 4 or 5 small square openings. This is the auto oiler. Make sure they are not obstructed with gunk. There is also an adjustment to increase the oil flow to the bar. It is a small screw and will be marked with a + on one side and a - on the other. You can adjust it to run from 5 (minimum) to 15ml (maximum) per minute. Never use old motor oil or 2 cycle oil in yo
May 22, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 272 xp, setting for setting screw for oiler
To check for proper oiling, run the saw at speed with the tip of the bar near a piece of cardboard--it should throw off a thin line of oil after several moments of running. Adjust the oil adjust screw CCW for more oil. The screw is usually in the lower front or underneath the engine. Remove the bar and chain first before adjusting anything and check the oil passages located in the drive end of the bar for plugging--especially the two small passages that go from the large oil holes out to the chain groove on both sides. Start the engine without the bar and chain--look at the oil port where the bar mounts next to the engine. It should ooze out oil with the engine running fast. If nothing at all, the pump, oil lines, and oil filter in the tank should be checked. When everything seems to be working, then adjust oil flow for best operation. Hope this helps!
Apr 17, 2010 | Husqvarna Chain Saw 20" Bar
How to adjust chain and bar oiler flow on a jonsered 49 sp chainsaw
The chain should be adjusted so that the chain can be pulled by hand fairly easily, but doesn't droop from the bar underneath. Oil flow should be set so that a running engine (chain moving fairly fast) will send a thin line of oil off of the tip of the bar (onto a piece of cardboard) with a few moments of running. Hope this helps!
Feb 27, 2010 | Garden
Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Apr 10, 2009 | Garden
Husqvarna Chain Saw 20" Bar Logo
314 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
