Question about Husqvarna 562xp Auto-tune Husky Xp 562
Hesitation on accelerating rough idle
Saw new about a moth ago has not run right hesitates when slightlgy touching triger took bach to dealer put on computer says no faults found still have same problem
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Husqvarna 385
Sounds like dirty carberator or carb needs adjustment. How is the spark plug?
Posted on Jun 22, 2009
RaidX
  • 632 Answers
SOURCE: erratic running
Could be a problem with fuel Or air Filter
Posted on Jun 23, 2010
89 ford probe hesitates when leaving a red light, then runs fine otherwise, fuel filter?
Engine Runs Rough, Stalls, Hesitates on Acceleration, Hard ...
repairpal.com > Problems > Ford > Probe
Ford Probe Engine Runs Rough, Stalls, Hesitates on Acceleration, Hard Starting, Poor Performance. This is a verified problem based on 9 reports. Learn more ...
Starting Problems - 1997 Ford Probe - RepairPal
repairpal.com > Questions > Ford > Probe > 1997 Ford Probe
Dec 5, 2010 - Starting Problems on 1997 Ford Probe ... If the engine runs rough,stalls, hesitates on acceleration, is hard to start, or has generally poor ...
A new misfire/hesitation on accel. Problem.. - ProbeTalk.com Forums
forums.probetalk.com > Tech Section > 2nd Gen (93-97) V6 2.5L
Feb 05, 2016 | Ford Cars & Trucks
Hesitation on acceleration rough idle
There is a Service Bulletin to address the stumbling off idle. Your dealer can perform the SB for you and will prevent the problem.
Apr 18, 2014 | Husqvarna 562xp Auto-tune Husky Xp 562
How to diagnose rough idle and hesitation on gmc sonoma 2.5 4 tech?
Hello I have a 1995 Sonoma 4.3 with 150.000 on her and she ran great tell last week went to pick up a lite trailer and dove it home no problem drove it all day after that. The parked it running fine and next morning it won't hold a idle but clears up at 3000 RPM runs fine drop in gear and it won't stay running??? Cleaned TBI and there was a new fuel pump and filter put on it less them 7.000 miles ago. Found vacuum leak on the booster to manifold fix that still runs like it is misfiring??? Any help would be great thanks no check engine light on.
Feb 17, 2012 | GMC Jimmy Cars & Trucks
It seems the battery in my 04 cadillac deville is dead. I know the battery is located under the rear seat. Can I remove it without adverse effects on the computer?
you can replace battery with out effects.first turn off radio.before removing negative battery cable.when you install new battery, when you start the engine let it idle until get operating temperature.the computer will have to relearn it memory while engine idling operating temperature.open throttle a little see if engine hesitate. it will hesitate some, when you can accelerate with out hesitation,engine tps sensor has relearned it position.if idle speed stable engine dont run rough and stall out in drive your pcm has relearned itself where you can drive it.
Apr 03, 2011 | 2004 Cadillac Deville
Hesitation during acceleration
could be the type of plug you are using.I was told only to use ngk plugs.I recently put bosch plugs in my mazda 3 and the check engine light came on and it started missfiring.
Apr 26, 2009 | 2004 Mazda 3
Hesitates on acceleration
Does the car always hesitate during acceleration? If it ALWAYS struggles when it starts or ALWAYS hesitates on acceleration then I would say the issue is fuel delivery. If the problems are more intermittent and come-and-go then it could be an electrical issue.
I would start by changing the fuel filter. Changing plugs, wires, cap, and rotor are all good things to do as your budget will allow. I doubt you will have to change your injectors.
If you end up replacing any rubber fuel line, be sure to use the high-pressure stuff made for use on fuel injected cars.
I hope this helps! -Nick
Apr 10, 2009 | 1983 Chevrolet Chevy
1989 Cavalier Z24 3.1 rough idle and hesitation
it sounds to me that the sensor your talking about is the camshaft positioning sensor. It regulates how much fuel you get to your engine, so that is also why you have the fuel smell as well.
Feb 23, 2009 | 1997 Chevrolet Cavalier
2004 nissan armada low idle then won't start
I had the smae problem with mine last week, it turned out to be the IPDM Independent power distribution moduel, looks like a big fuse box. I would take it to a side mechanic and have them fix it instead of going to the dealer it took like 45 mins to take the old one out and put the new one in. If you go to the dealer they are sure to charge something crazy. Hope that works for you.
Feb 21, 2009 | 2005 Nissan Armada
2005 Jeep wrangler w/rough idle and hesitates when you accelerate
try fuel injectors....run a bottle or two with full tank through it and see if that dont solve the problemo.....
Feb 01, 2009 | 2005 Jeep Wrangler
Husqvarna 562xp Auto-tune Husky Xp 562 Logo
24 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
