Question about ASUS Computers & Internet
Asus eee pc 4g error message grub rescue - ASUS Computers & Internet
    Habit-Forming:
  • 103 Answers
This would imply a Linux distro.. What are you attempting to do, exactly? The error occurs when you install Linux and then it is removed;(sometimes incompletely other time when you remove the partition from the Windows Disk Manager). If you want to retain Linux, just put the disk/flash drive for it back in and finish the installation or boot to the recovery. If you only want a Windows system, follow the steps:
  1. You'll need a disc for the version of Windows on your hard disk drive. Place it in and select for whatever will bring you to your advanced options. (This is so you can get to your recovery command prompt).
  2. Instead of Restoring from Disk Image or whatever other standard choices you have, you'll want the command prompt.
  3. Using the following commands will restore the Windows Partition, if it's on there still.
    1. bootrec.exe /fixboot
    2. bootrec.exe /fixmbr
    3. bootrec.exe /ScanOS
    4. bootrec.exe /RebuildBcd
  4. Once you reboot afterwards, it should restore your Windows system if it didn't get removed during the Linux installation.
Hopefully this helps, if not; I'll need more information as to how it happened.
Posted on May 07, 2014
SOURCE: webcam driver
Some times BIOS disable webcam after updating it.
To enable it do the followings:
1. Restart your Eee PC.
2. Press F2 while booting (to enter BIOS sittings)
3. Go to "advanced" tab (by pressing right arrow)
4. Select "Onboard Device Configuration" (by pressing down arrow)
5. From there you can find if "Onboard Camera" is enabled or not.
6. If not, just press enter to pick "Enabled"
I hope that would help :-)
Posted on Aug 07, 2008
ginko
  • 19396 Answers
SOURCE: i need a link for
Download and reinstall camera drivers here:
First download the camera driver here.
Posted on May 30, 2009
yboyandrei
  • 828 Answers
SOURCE: ASUS EEE PC 4G Password recovery!
its all technician consultation and for me remove the CR2032 battery inside the laptop to reset the biois inside... or press F8 to go safe mode and remove the previous password to enter at administrator...
Posted on Jun 16, 2009
  • 86 Answers
SOURCE: how to reset asus eee pc 4g surf to factory
Run the recovery software in the programs menu and fallow the prompts.
Posted on Jan 28, 2010
technical114
  • 1851 Answers
SOURCE: ive got an asus eee pc 4g and forgot the only
You can use a tool for resetting the administrator password. One tool for this purpose can be located here. Since your laptop has no cd/dvd rom you can use either an external one to boot from (using the cd you created at the previous step) or use this portable tool in order to extract the iso file and create a bootable USB stick (read the readme file at the iso file for details). There is also another one solution using a windows xp setup cd but it's more risky, so I suggest you to try with the steps I told you before.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Oct 09, 2010
Administrator password reset
download trinity rescue kit from their site, follow the steps and voila.
Sep 19, 2013 | ASUS Eee 4G Notebook
ASUS Eee PC 900 Notebook when I turn on said grub loading stage1.5 then said grub loading . please wait ...and Error 17 ,how do i fix it ???? plsss any1 help meeeeee plsss,
sorry folks but youve corrupted your bootloader (grub) unless you can restore to factory settings(you might be able to my asus its F10(whilst booting) if you have corrupted your system beyond external repair your only option is to use an external drive and use your operating system restoration discs to restore drivers and O.S
Mar 14, 2011 | ASUS Eee PC 900 PC Notebook
I installed linux ubuntu remix on my ASUS Eee 1001PXB-BK301 multiboot, then i deleted ubuntu after not using it anymore using windows xp disk mangement and found myself without a mbr with grub saying grub...
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Jan 29, 2011 | ASUS Eee PC Netbook
Specifications
get full specifications from here:
http://reviews.cnet.com/laptops/asus-eee-pc-4g/4507-3121_7-32466960.html
Jan 13, 2011 | ASUS Eee 4G Notebook
Asus eee pc 4g Camera can not be found. It was ok, but since i re-installed my windows, its not working and it can not be found.
You need to download the driver from above link http://laptop-driver-download.blogspot.com/2009/04/download-asus-eee-pc-4g-x-xp-drivers.html and install in your laptop.
Oct 07, 2010 | ASUS Eee 4G Notebook
Asus eee pc 4g wont connect to internet with
Can you connect through a "wired" connection? Is your router connected to the Internet? If you're using wireless encryption, have you told your netbook what that encryption key is?
Apr 29, 2010 | ASUS Eee 4G Notebook
How to fix a 403 error message on my computer
sorry but I thought your service was free at least that's how it
was advertised
Jan 17, 2010 | ASUS Eee 4G Notebook
Accidentally deleted my audio device
check your model first, in your bottom case. eeePC 4G. And now you connect to ASUS site for downloading that driver, for you need it.
http://support.asus.com
click DOWNLOAD (right side)
select product (up) = Eee Family
select product (middle) = Eee PC
select product (bottom) = Eee PC 4G Surf/XP
and then click SEARCH....
select for win xp
enjoy it...
Sep 22, 2009 | ASUS Eee 4G Notebook
USB pen drive not being recognised by ASUS eee 4g PC
Update the driver that the usb stick is using.
Aug 13, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
