Question about Refrigerators
Cannot find control card for model no: B970
Want the quotation for the B-970 ICE CUBE MAKER MANITOWOC..all the company recommanded spares from: niraj bhatt nirajnb@deepkiran.com
rickzilla
  • 706 Answers
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Posted on Sep 15, 2008
mastatech
  • 478 Answers
SOURCE: The Ice maker is stuck on crush
This is a simple thing. the solenoids get rusted and jam stuck in position. you can just clean the device but for all the trouble it should be replaced.
Posted on Mar 12, 2009
SOURCE: Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Posted on Jun 19, 2009
woodchuck789
  • 4070 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
shustwit
  • 4 Answers
SOURCE: I have a counter top
Call the phone number on the back of the machine.
800-330-0388
They helped me diagnose the problem and sent me easy instructions for fixing it.
Apparently, the switches get icked up sometimes. I took off the side panel over the fan, removed one of the switches [the top one], opened the case and cleaned it off. Works like a charm.
The wonderfully helpful guy at sunpentown sent me a document with pictures showing me how to do it.
Posted on Jan 07, 2010
What can i use to clean my portable ice maker. It smells like mildew.
I have cleaned Manitowoc ice makers and their company specifically made an ice maker cleaner and sanitizer. Try a google search for this product.
Dec 13, 2014 | Nostalgia Electrics RIC-100 Retro Series...
We have ice maker which shows off /on mode
Make sure it's not in clean mode... needs to be in ice mode
Aug 24, 2014 | Manitowoc ID1202A-261 Dice Cube Air Cooled...
Water reasavore over flowes
Replacing Manitowoc water level probe and Ice Thickness
Feb 12, 2013 | Manitowoc SY0454A S Series Ice Maker...
I have a model qd0452a manitowoc and it will not stop making ice
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Nov 17, 2010 | Manitowoc SY0454A S Series Ice Maker...
Manitowoc ice maker does not produce ice
If it doesn't run at all open the front panel and peer inside of the control box. See if there are any indicator lights on the control board lit or blinking. Check the plastic water curtain on the machine and make sure that the magnet is in place on the bottom right. Will need more information as to what lights are lit. Printed on the board next to each light is its corresponding function or response.
Nov 11, 2010 | Manitowoc SY0454A S Series Ice Maker...
Ice machine starts on harvest mode and will not go on to production
you will have to find the main board unplug the connector for about a mintue plug back in. This should reset unit
Aug 05, 2009 | Manitowoc MAN-CVD2075 Condenser Unit...
ICE CUBE WATER FLOW IS LOW
This is a Manitowoc model QY0214A. The water tough starts to slush up after about 3 minutes after start up cycle. The slush prevents water from flowing to the pump for circulation.
What can be wrong?
By
Greg
May 27, 2008 | Dishwashers
Refrigerators Logo
11 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
