Question about Home
Why does the formost single flush toilet run every once in a while??
Thought it was an eco toilet !!!But to me with water running from time to time does not appear to be very econimising!!!!!!!!
  • 341 Answers
It sounds like your flapper is leaking slowly
Posted on Apr 18, 2014
SOURCE: cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
Posted on May 08, 2009
  • 3 Answers
SOURCE: not enough water in the toilet bowl
WellI had the same problem with a client. never seen a stubborn problem like this. I was worried there was no vent on the toilet. My resolution was to get a new flapper from Moen. I replaced the existing flapper that had the yellow float. the float is designed to kepp the chain away from the flap. the existing flap had a vent hole in it. compare it to the new moen unit and you will see what im talking about. After the replacement things were better. Cheers
Posted on Jul 17, 2009
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
SOURCE: My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Posted on Jan 24, 2010
  • 19 Answers
SOURCE: toilet handle stick on flush and water runs and
Turn water off and get a handle repair kit, very easy repair
Posted on Mar 02, 2010
What is causing air in my cold water line and how do I fix it?
try running all the water in the whole house at once. all toilets. outside faucets, washing machine, ect...
assuming you have no leaks.
Aug 25, 2014 | Home
Kohler flush problems
If it has a power flush (i.e hole about 1" in size opposite side of flushing direction) that hole gets plugged by minerals from the hard water, when it does the flush will be much weaker. To clean it, use a bent coat hanger and ream out the deposits as far in as you can reach. Then turn off the water supply, flush the toilet, then quickly pour one pail full of water into the toilet to drop the water level to minimum. Get "Lime Away" at H/Depot, pour in 1 cup and let sit overnight to eat the remaining hard water deposits from the bowl and power flush. In morning turn on water flush a few times, should wok good as new. Repeat anytime hole starts to get plugged.
Aug 21, 2014 | Home
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
Constantly running
one of two things one flapper valve bad -or flush valve bad or out of adjustment
Nov 28, 2012 | Sloan M-101526-F42 Flushmate?® Complete...
After flushing, the toilet keeps running. However, if I turn off the water supply, and then turn back on, the toilet stops running until the next time it is flushed. Toilet makes a
It could be the type of flap you are using. I would suggest you try a different shaped flapper (a cone would work best) and if that doesn't do it, put a new kit into the unit, because it could be that the float system is sticking causing it to continue running.
Jan 10, 2012 | Toto Carlyle One-Piece Toilet Toilets
When I flush the tank only half empties and not enough flushing action is the result as well as the bowl does not adequately fill after the flush.
Hi, if you remove the cistern lid and flush the toilet, look at the float (back left) to see if this is rising freely when the water fills back up. Once the water has stopped filling, check the fill level lines on the large syphon in the middle of cistern. Your model of toilet has an eco flush which will be lowest line to save water, so not as much water will flush out. There is a long plastic screw on the float (back left) which you can turn to adjust the water level to the higher line on syphon (1.6 gallon flush) and turn it slowley till the water level reaches that mark. flush a couple of times to see it is filling back up to the set amount.
Jan 14, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
I have K3397 Kohler toilet. Water is running little by little. How to stop it?
open were the water system is flush once watch the water rise localize the floaty tat rises with the water once u localize the floaty their will be adjuster were the floaty is then just lower the floaty adjuster down 2 half inches down once ur dun flush then the problem shud be solved.
Aug 18, 2010 | Kohler K-3360-G Revival One-Piece Toilet...
Our topflush toilet will nto stop running, once it is flushed. Theflapper seems secure. Not sure about the fill valve part.
after flushing observe flapper if it flops back and water is still getting by when tank is full than replace the flapper /if water is running down tube [high level]in tank than adjust level or if not responding to adjustment than flush unit is bad
May 31, 2010 | Kohler K-3360-G Revival One-Piece Toilet...
Home Logo
54 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
