Question about Motorola Computers & Internet
Nordmende Smart TV
My Nordmende Smart TV keeps switching itself of and on and wont respond to the remote control commands
    Top Expert:
  • Motorola Master
  • 74,251 Answers
Shorted component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Posted on Apr 18, 2014
My TV turns on and off itself repeatedly.
This can be caused by settings connected to the computer.Billion tv screens tend to switch themselves on and off sometimes.Read the manufacturer manual or see a pecialist when it persists.
Jul 21, 2016 | Televison & Video
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
My Samsung LA32D4O3E2 HD LCD TV is not responding to the 'source' command from both remote control and the button on the Tv itself..How can i fix it?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Samsung LA32D403E2 HD LCD TV
Manual switch ok but remote not fundtion sharo tv
Be assured that fault does not lie with the remote handset itself. In that case repair or replace it.Remote control system has two parts. One is the remote hand set and the other lies within the TV or other device for which remote controller is being used. The hand set transmits commands in shape of singnals of particular frequency and pulses per second depending on the key pressed. The other part of the remote system lying within the TV receives, decodes and responds according to the commands received in shape of signals of particular frequency and pulses of paricular width and sequence. The remote controller uses invisible infra red light as the carrier of the signal. As the light moves in straight path, no obstacles should block straight line of sight path between the remote hand set (the transmitter) and IR sensor window (part of the receiver). Hence remove the blockage from the front side of the TV.Check if the IR sensor is not defective. Check if the associated circuit and components inside the TV are not defective.Check if the TV has any switch for selecting only manual mode and locking the remote mode.Hope, some sytematic exercise will bear the successful result.
Feb 19, 2012 | Sharp LC-32SB21U 32 in. LCD TV
I NEED A NEW REMOTE CONTROL
Hello
I thinks that you need a new universal remote control for your RCA tv, and answers. You just buy one stated below,and codes and other proceedings are also given.
Model No: [RCA - D770 Wide Range Remote Control]
Codes for RCA TV with this remote control are:-
1000, 1003, 1004, 1005, 1006, 1007
.........................1019, 1096, 1098, 1099, 1100, 1101
.........................1102, 1103, 1129, 1179, 1181, 1187
............................................1188, 1190, 1198, 1199
Proceedings
1. Turn on the device to be programmed.
2. Look up the brand and code number(s) for the device on
the code list at the end of this section.
3. On your remote control, press and hold the device button
you want to program.
4. Enter a code from the code list.
5. Release the device button, and then press ON•OFF to
see if the device responds to the remote control
commands. If it doesn't, try pressing the device button
and then ON•OFF again.
6. If you get no response, repeat these steps using the next
code listed for your brand, until the device responds to
the remote control commands.
NB: Switch Off and On your TV with its front panel power switch each time [NOT BY THE REMOTE CONTROL HANSET], before you try an other code, UNTIL YOU GET THE RIGHT ONE.
Dec 20, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
Have a Nordmende NM32780 tv it keeps powering off itself and its not the power button sticking. Any ideas?
nordmende nu323lv lslcd it wont power on and is stuck in standbye any ideas???
Jul 04, 2010 | Televison & Video
Plasma tv wont respond to the buttons being pushed on the tv
ok ,try cleaning the remote, first.open it up and clean it with alcohol and soft cloth.let it dry.then,assemble it.be sure your batteries are ok.
May 28, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Computers & Internet Logo
173 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
