Viewsonic n3246w manual
I'm trying to connect my Acer Aspire V5 14" laptop to my Viewsonic N3246w TV using a HDMI cable. the video comes perfectly fine however the sound doesn't work. Even though in control panel my laptop says the sound has been switched from the laptop speakers to the TV
  • 36 Answers
I have had this problem before and all you have to do is click on the sound button on the task bar (bottom Left) and click 'mixer', make sure that the sound is coming to the TV and if it is still not working try moving the HDMI cable in a circle while it is still connected to the TV and the laptop/computer. Hopefully it should then make sound but if the problem still persists try restarting the laptop/computer and/or TV. The cable might be broken so if the steps above to not work try getting a new HDMI cable and make sure it is plugged in properly into the TV and the laptop/computer. Hope this helps.
- Nathan
Posted on Apr 19, 2014
Amith DSilva
  • 34 Answers
SOURCE: I have an Acer Aspire 8930G trying to connect to my TV with HDMI
After you connected the HDMI Cable to the TV...Did you press the FN + F4 Key on the keyboard... The first screen you will see is the notebook screen is blank and the TV has got the desktop on top of it...The second time you press the FN + F4 then you will see thedesktop on the notebook and as well as the TV...The third time you press the FN+F4 you will see the desktop on the Notebook...
Posted on Aug 22, 2009
sandrew
  • 2961 Answers
SOURCE: Acer aspire 4315 connect to TV problem
you should be able to right click on an empty space on your desktop and choose graphics properties and then the output option should be able to be set and the resolution changed if needed, set your tv for AV3 or s video and connect a seperate audio cable as s video is video only
Posted on Sep 10, 2008
SOURCE: Sound problem - Acer Aspire 5920
I assume you are using Windows Vista as ships with Aspire 5920's. Try the following to make sure that Windows is using the correct output options:
  1. Click on the Start Menu and go to Control Panel
  2. From Control Panel click on Hardware and Sound
  3. Click on the heading Sound and the sound configuration box will appear.
  4. The first tab is called Playback and allows you to select a playback device.  You should find your external speakers and internal speakers listed.
  5. Click the external speakers and then click on the "set default" button to make sure that the sound is played back through those instead of your internals.
Posted on Nov 06, 2008
SOURCE: cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
Posted on Jan 19, 2009
SOURCE: I want to connect my
THE ACER ASPIRE 5738 HAS AN HDMI PORT ON THE LEFT HAND SIDE. BUY AN HDMI LEAD AND CONNECT IT TO YOUR LAPTOP AND HDMI PORT ON YOUR LCD.SELECT HDMI AS INPUT ON YOUR LCD AND HEY PRESTO JOB DONE
Posted on Jan 13, 2011
Need the code for sky remote for viewsonic n3246w tv
The only viewsonic codes I know are 0805 , and 1783, if these dont work try the internet for sky codes. be aware you may have to wait and try again for codes to catch up.
pete
Nov 08, 2010 | ViewSonic 32 in. LCD TV
Change address on component for Harmony One
Has anyone found a code for the above ViewSonic N3246W LCD TV?. I have just got a Sky+HD box and would like to operate the TV volume with the Sky remote.
Thank you in anticipation.
Mar 31, 2010 | Logitech Harmony One Advanced Universal...
Powerlock Enable cannot be removed from my ViewSonic N3246w.
I have a 19" ViewSonic and if you hold down the 2nd and 3rd buttons together under the screen, counting from the LEFT, it will disable the Powerlock.
Aug 31, 2009 | ViewSonic N2060w 20 in. LCD Television
ViewSonic TV sound but no picture
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Mar 20, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Power lock enable
To get rid of the power button enable you need to either press and hold the power button on the tv ( not on the remote control pad) for approx 15 seconds or if that does not work do the same using the source button
Jun 03, 2008 | ViewSonic N2060w 20 in. LCD Television
Viewsonic n3246w Screen goes blank
It's the LCD panel assy failure. Most likely the high voltage Inverter board failed.
Feb 01, 2008 | Televison & Video
Connecting tv to dvd player
It should be fairly straight forwards.. Simply get the SCART to SCART Cable.. Connect up the Two, DVD to Screen, turn them on, selecting any input/outputs Format etc, setups from any Menus...then start player select "Play" & ya should see the Picture & hear the sound...
Aug 31, 2007 | Philips 30PF9946 30 in. HD-Ready Plasma...
Viewsonic N3246W
does it only ghost on the channels that showing football only?
Apr 19, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
