Question about Vivitek Qumi Q5 Super Bright HD Pocket Projector, Red, 500 ANSI Lumens, 1280x800 WXGA Resolution, 3D Ready, 10000:1 Contrast Ratio, 4GB Internal Memory
How to reverse image in Qumi Q5 projector? Need to mount it from ceiling.
2 Suggested Answers
gopakumarg43
  • 75462 Answers
SOURCE: Upside down picture on Vivitek D530
Hello
Check the Projection setting on the Installation I menu of the OSD
Posted on Feb 12, 2012
How can I stop my Qumi Q5 shutting down after a minute?
It is most probably overheating. First you need to open up the unit and see if the fan moter is frozen. It is probably because you can't hear it spinning. There are usually two bushings one in the front and one at the rear of the motor. They are usually permentally lubricated but as we know nothing is forever. So, try to take some good quality oil like 3 in 1 and try to drip a drop on either side of the motor where the shaft comes out and then try spinning it by hand. Hopefully that may work but if not then as a last resort try spraying just a very small amount of WD-40 and try spinning it again. If it then does work then use the 3 in 1 again. WD-40 will probably clean the gum out of those bushings but it is not a proper lubricant so that is why you need to use that 3 in one or any good quality lubricant like gun oil.
If all else fails then you probably have a bad fan motor and it will have to be replaced. Just so you know I have had this same problem, usually with air conditioning fan motors and most of the time the lubrication method that I just described worked very well.
Good luck,
Marty
Jul 20, 2014 | Vivitek Qumi Q5 Super Bright HD Pocket...
I mounted the projector on the ceiling and need to flip the image
ok go in the main menu u see 4 windows under on eof the options flip throw the windows to get it to go right side up ok in menu settings on the sony ok
Feb 02, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
How do I flip the image on my Epson EMP 30 projector for ceiling mounting please?
Press MENU on the remote control (as show on picture below)
the menu window displayed
Press down arrow key to select ADVANCED
press ENTER on the remote control
use down arrow key to select ceiling (as show in picture)
press RIGHT arrow key to select OFF to ON status
press MENU key to exit menu
(the projected images are horizontally and vertically reversed.)
Feb 13, 2011 | Epson EMP 30 Multimedia Projector
Projector is suspended from the ceiling upside down and so it is projecting upside down. How do i get it to project the images the right way up?
Since you have not mentioned the model it is diffficult if the option of reverse image is available on the menu. If so all you need to do is to scroll the menu and reverse/invert this image. If not the other option is to mount the projector with the projector fitted on a small stand in the same direction and not invereted. I hope you will search for this in the menu or in the rear panel. If not mount it in the actual position with a stand so that you can corrrect the height using the provided screw adjusters.Helpful? Good day
Jul 07, 2010 | Audio Players & Recorders
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Casting image lower on wall
I don't know the model number for your projector, but most projectors are designed to place the image level with the bottom of the projector, which works great for tabletop mounting but not so great for ceiling mounts.
If you're mounted at ceiling height, try turning the projector upside down to see if it places the image in the right place on your screen. If that fixes it, then use the on-screen menus for your projector to flip the image and you should be all set.
Dec 09, 2009 | Dell Office Equipment & Supplies
How do I flip the image on an Epson EX50 for ceiling mount?
go into the menu, image adjustment, and chose ceiling.
Aug 03, 2009 | Epson Office Equipment & Supplies
Xd70u upside down image no remote how to control with PC
Try the menu feature, then installation, image reverse until it gets to the correct position. Note, the Image Reverse rotates in quarters. You can also access the Menu feature from the projector. It just happened to me and as I was looking for answers and playing around with it, I fixed it!
Good Luck!
Nov 25, 2008 | Mitsubishi XD70U Multimedia Projector
Picture become reversed
In the menu functions there is a place you can change the way the image is projected on the screen. If the projector is mounted in the ceiling you need to change it to front/ceiling, but if you scroll through the options you should be able to find the one that will work for you.
Oct 03, 2007 | Epson PowerLite 8100i Multimedia Projector
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
Vivitek Qumi Q5 Super Bright HD Pocket Projector, Red, 500 ANSI Lumens, 1280x800 WXGA Resolution, 3D Ready, 10000:1 Contrast Ratio, 4GB Internal Memory Logo
109 people viewed this question
Top Vivitek Office Equipment & Supplies Experts
Miguel Luiz Martins
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
