Question about Bosch Classixx WFL 2066 Front Load Washer
Taking in water but drum not spinning power ok
    Prodigy:
    An expert who has answered 500 questions.
  • Bosch Expert
  • 517 Answers
Pull out the plug
check the carbons they may be worn
Posted on Apr 25, 2014
Hotpoint WT761 washing machine - Error code F-10 The machine is filling with water, then signalling F-10, then pumping the water out. So the fill solenoid and the pump are working OK. If I set the machine...
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
Sep 19, 2009 | Washing Machines
Maytag MAH6700AWW Humming Sound
Can you see water in the drum ?,No water = no action Check water supply
If there is water in the drum does it drain out at some point.
Sequence = Fill, Agitate, Heat, Wash, Drain, Spin etc.
If it fills then it may be a belt has snapped and the drum cannot turn , need to take the covers off to look.
Remove power before taking covers off !!!!
If the belt is OK then it may be the heater which has gone open circuit, try a cold wash or a rinse cycle to test that.
May 23, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Not taking in water
go back to water vavle and start form there ,,is it humming..verifie water in fill hoses,,check and make sure you have hoses on dispencer correctly,,if removed,,,check and make sure you did not twist or kink hose entering tub...make sure connection are on the water valve..onthejob
Jan 24, 2009 | Hotpoint WMA66 Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Nov 05, 2008 | Washing Machines
Washer fills with water and thats it
Possible a bad motor control board. Depending on the age of the washer, you may need to replace the motor control board and the motor as a kit. Also be sure to test that the motor control board is getting power, I've seen cases of the motor/ motor control failing and taking out the main control also. The tech sheet is in the console and should walk you through the steps.
Jul 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 44092/spin cycle
It turns out that there was a sock stuck within the pump in the washing machine. I removed the back cover and removed all the excess water, because once the sock was removed, the water was free to escape. I just removed the hose that connects to the pump and felt the sock, and was able to remove it. Once I hooked everything back up, the washing machine ran great.
Apr 17, 2008 | Kenmore Energy Star 44092 Front Load...
Washer spin problem
Ok so your having problems with the washer spin problem. Well there mightbe a sound that it is making like a jumpoing sound. Well when you here that open it and you might notice that all the clothes are on one side. That means that you put too much clothes in the washer, and it can't handle it. So open it and take out some clothes and restart it. I hope i helped you problem's. Thank you for taking your time to read my article.
Feb 12, 2007 | Whirlpool LTE5243D Top Load Stacked...
Bosch Classixx WFL 2066 Front Load Washer Logo
22 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
