Question about Nikon Coolpix L830 16.0 Megapixel Black Digital Camera - 26439
Zoom control issue
I m using nikon coolpix l 830. zoom in playback is not working properly as i zoomed in into any images it automatically came to 0x level of zoom
  • 6 Answers
SOURCE: Screen
Get on to Nikon and let them know about it, it is a common problem with the S4. They are fixing the 3500 and others for free.
 John.
Posted on Oct 16, 2007
SOURCE: lens stuck in the out position
nkkabra - how do you reload the firmware?
Posted on Dec 12, 2007
  • 4 Answers
SOURCE: zoom toggle switch problem
you need:
1: a small and strong phillips screwdriver.
2. a small piece of medium strength plastic.
(I used a wall anchor like you would use for drywall)
3. superglue
4: about 15 minutes
5. some gumption
6. a bit of sandpaper, in case you screw up step 4.
step 0: You are about to void any warranty. Accept this, and move on. Take out the battery and the memory card.
step 1: remove case of camera. be careful not to strip or loose your your screws.
step 2: gently give the thing a shake. likely a tiny piece of black plastic will fall out. this is the piece that originally attached to the back of the zoom rocker button. if it doesn't come out, don't worry.
step 3: take a look at the back side of the still functioning side of the rocker button. you will see a tiny nub on the back. this nub compresses the pressure switch that is built into the circuit card of the camera, activating the zoom.
step 4: cut a piece of plastic that is about the right thickness to replace the missing nub on the non-functioning side of the button. you will be better off cutting it a bit too thick than too thin.
step 5a: VERY carefully superglue the bit of plastic to the back of the button. you don't need that much glue.
Setp 5b: let me repeat, YOU DON"T NEED THAT MUCH GLUE!
Step 6: Let the glue dry. completely. I mean it.
step 7: replace the case, and about half the screws. put the battery and card back in.
step 8. power on, and test the zoom. It should work now. if it feels like the button is too loose, or still isn't making contact, you cut the plastic too small; Sand or snip it off and start again.
Step 9. If it feels like the button is too hard to push, the plastic bit is too large. You can cut it down a bit, sand it, or just put the rest of the screws in and be thankfull that you repaired your camera for about 2 cents worth of material, and 15 minutes of work.
Step 10: make sure you don't have any extra parts. make sure you didn't screw up another button while you were mucking about.
I've done this. It works. Repaired mine about 9 months ago, and no issues since...well, I put the button in upside down, but it works exactly the same, so that doesn't count as an issue.
If FUBAR your camera, I'm not responsible.
Long live Nikon,
-aboniks
Posted on Dec 10, 2008
  • 10865 Answers
SOURCE: Nikon Coolpix s4-monitor working but no image
hello. you may be involved in a recall. please read this http://www.nikonusa.com/Service-And-Support/Service-Advisories/COOLPIX-Service-Advisory.page
please rate my answer as very helpful thank you. joe
Posted on Mar 01, 2010
lock123
  • 6831 Answers
SOURCE: my Nikon Coolpix L100 flashes a lens cap error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Have an issue with my cameras zoom function. When I take pictures my zoom works perfectly but when I switch to record mode the zoom will no longer work.
Nikon Coolpix S220 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_S220_Troubleshooting
iFixitThe Nikon Coolpix S220 is a compact 10.0 Megapixel Digital Camera. Designed with a 2.5 inch LCD ... If camera is in Video Mode the optical zoom will not work.
Nikon Coolpix L810 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_L810_Troubleshooting
iFixitThe zoom function is not working while camera is on; Zoom is not available in ... If your camera does not turn on, make sure that the battery is fully charged. If after a charge the camera still doesn't turn on, your batteries may no longer be able ... modebutton, the playback button, or the movie record button doesn't work, turn ...
Nikon L830 review ' Cameralabs
www.cameralabs.com/reviews/Nikon_COOLPIX_L830/
Feb 05, 2016 | Nikon CoolPix 900 Digital Camera
Why does my Coolpix overexpose images when zoomed in?
If you zoom in then press the shutter down halfway. If you zoom with the shutter pressed half way you can get an over exposed image.
Aug 04, 2014 | Nikon Coolpix 4300 Digital Camera
Nikon Coolpix L24 camera. It doesn't take pictures. I mean that camera turns on nicely, the lens unfolds, you can even view images that you previously took, but when you press the button to take new photo,...
Check that your digital camera is not in playback or review mode.
Make sure the memory card is in the camera and that the card is properly formatted.
The Memory Card may be full. Download the images to the computer or delete some to make way for new photos.
Check the charge on the batteries. Replace if necessary.
Have you been using the flash? It may be recharging. When it is recharged, the camera will be ready to take photos again.
Aug 21, 2013 | Nikon Coolpix L24 Silver Digital Camera...
If I buy a used camera do I need the cd-rom to upload the pic takened by the camera to my cpu
I would recommend you to buy Nikon Coolpix S4000 Nikon's Coolpix S4000 creates touching memories by combining 12.0 effective megapixels, 4x wide-angle Zoom-Nikkor glass lens and an amazing 3.0-inch High Resolution HVGA (460k-dot) touch-panel LCD with sensitive touch. The Coolpix S4000 also features HD (720p) movies for high quality movie recording. The Coolpix S4000, with Nikon's EXPEED image processing concept, 4-way VR Image Stabilization System and Smart Portrait System enables you to get incredible pictures, incredibly easy. Nikon's Scene Auto Selector automatically analyses the scene you are taking and adjusts the scene mode for you. All you have to do is compose, then touchYou can check out more detailed review for Nikon Coolpix S4000. http://hubpages.com/hub/Nikon-Coolpix-S4000-12-MP-Digital-Camera
Dec 18, 2009 | Nikon COOLPIX L10 Digital Camera
I am buying a Canon SD970 IS digital camera. What
I would recommend you to buy Canon PowerShot SX210IS 14.1 MP Digital Camera with 14x Wide Angle Optical Image Stabilized Zoom and 3.0-Inch LCD. Decidedly slim and sleekly refined, the PowerShot SX210 IS packs a feature set that reads like a wish list. The 14.1 Megapixel CCD joins a 14x 28mm Wide-Angle Zoom for imaging power to spare. Frame your shots in the bright 3.0-inch widescreen PureColor System LCD, with the Low Light mode for sharp images in dimly-lit situations. It also captures stunning HD movies with Dynamic mode for enhanced image stabilization when shooting movies using wide-angle settings. Capture smooth HD video (720p) with stereo sound for a truly natural, high-quality HD experience. The PowerShot SX210 IS not only goes wherever you do, but takes your photography and video to a whole new place, too. You can check out more detailed review for PowerShot SX210 IS http://hubpages.com/hub/Canon-PowerShot-SX210IS-Digital-Camera
Nov 16, 2009 | Canon PowerShot SD890 IS / IXUS 970 IS...
Nikon S210- Coolpix 8.0-Megapixel Digital Camera - I want to buy this model...please can you help me out to buy it.
Sep 29, 2009 | Nikon Coolpix 8.0-Megapixel Digital Camera...
Nikon Coolpix 5700 Over-exposure of image whilst zooming in brigh
I now have the exact same issue. When not zoomed or fully zoomed the exposure is correct, however when partially zoomed the aperture does not engage and stays fully open. So basically I cannot really use the zoom or the picture is over exposed. Note - actually about 2/3 mechanical zoom and on works, so I can use a bit of the zoom.
Suggestions?
Sep 20, 2009 | Nikon Coolpix 5700 Digital Camera
Over exposure when zooming
If you want to be able to use optical zoom try getting a more advanced camera because cameras like Nikon Coolpix 4300 does`nt have quality zoom its very poor and you can see it yourself the images gets blurry when maximize your zoom.
Jun 22, 2008 | Nikon Coolpix 4300 Digital Camera
Nikon Coolpix L830 16.0 Megapixel Black Digital Camera - 26439 Logo
21 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
