Question about Epson EB-X72 diamond lamp
Green tint - even background when blue selected
I'm getting a continuous green tint. Tried different cables, computers and fixes described in themanual. Still green!
We have usually found it to be the VGA cable connection when the whole screen is tinted. Have you checked the pins in the VGA cord as well to make sure one is not missing or bent.
Posted on May 08, 2014
Turned on computer today and my screen is blue green, does not change using monitor buttons?
Sounds like you are using an analog standard VGA cable interface. Since the menu has the correct coloring, it is not the monitors fault. Check the connections of the video cable at each end to ensure they are tight and not kinked. If they are ok, try using a different video cable. If thew problem still exists after that, it is probably the video card in the computer.
Apr 11, 2015 | AOC Computers & Internet
Green screen on VGA with Viewsonic PJD5122
VGA is separated analog signals in Red, Blue, and Green. Under normal cases, you'd be able to change the cable, source, or input port and resolve the issue. Unfortunately, if the green tint persists with all input ports on the projector (The two blue ones are Input, the black one is output. There is a potential that attaching input to the black output port could have caused the damage), different sources, and different cables, then it's likely a problem with the projector hardware itself and would require warranty service or otherwise repair or replacement of the projector. If you have an alternate way the projector can be attached, then try that (Such as SVideo), otherwise there may not be any good solution in this case short of checking the guts of the system.
Mar 28, 2014 | ViewSonic Office Equipment & Supplies
Acer h233h monitor has blue tint all over screen
It's any one of these issues in decreasing importance video cable, video card, monitor. Make sure the video cable is plugged into the monitor and computer firmly first. After that, start replacing until you hit the culprit. You should be able to take any one of these items back to the store if it doesn't fix it.
Oct 22, 2012 | Acer H233H BMID 23 Widescreen HD Flat...
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
Everything has a green crystalization, green tint or otherwise fuzziness... Also seems that anything red is also screwed up. Ive tried everything on the TV to fix it.
You could have one three component cables (red, blue, green) not put in the right spot on the back of the TV.
If you are not using a component cable, then the problem can be either the Main board and or the Time Control board.
Try using a different input on the back of the TV, or even using a different device into the back of the TV. This will tell you if the problem is with that one input on the back of the TV or if the problem is with the TV itself.
Jun 19, 2010 | LG 42LC2D 42 in. LCD HDTV
There green tint in my picture on all my connections on vizio 47
Try shielded video cables and make sure you have your cables hooked up correctly. Sometimes you can conect them wrong, specially the red one. If you are using componet in on your tv, make sure the red one is not connected to your audio. The green tint is because you are missing red in your picture.
Mar 16, 2009 | Vizio VO47L 47 in. LCD TV
Computer has red tint!HELP!!!!!!!!!!
If it is under warranty, take it back. Elsewise caveat emptor.
Mar 06, 2009 | Gateway FPD1975W 19" LCD Monitor
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Monitor is blue-evrything has a blue tint-i can see colors,they just have a ble tint
I've found that strange color tints are usually the result of a loose cable connection, either at the computer end of the monitor end.
Try unplugging both ends, and then replugging both nice and securely (might even try reversing the direction of the cable, if it is a simple VGA-VGA cable).
Feb 27, 2008 | Computers & Internet
Green tint
what cable are uusing coumpount vga 15 pin to coumpunt or u try new cables
Jan 24, 2008 | Dell 3200MP Multimedia Projector
Epson EB-X72 diamond lamp Logo
148 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
