Ho do I share hp deskjet 460 with windows 7 - Office Equipment & Supplies
  • 121 Answers
SOURCE: re: download hp deskjet 710C
can you speci the full problem
Posted on Mar 03, 2008
benwabnick
  • 2404 Answers
SOURCE: Unable to install driver of HP deskjet 3740 on window 7
HP doesn't have the drivers available for windows 7 cause its only in Beta and they won't have it until windows 7 becomes official and available in stores. The only chance would be if you go into the control panel and then add printers. See if in there it has your make and model of your printer. If it doesn't then try a printer that is similar and it might install it. If you still can't get it to install then you'll have to wait for HP to come out with a driver for windows 7.
Posted on Jun 08, 2009
seanpwright
  • 2030 Answers
SOURCE: Have Windows 7 on my laptop. Have a HP Deskjet
simply download the new drivers from HP and install them , that will fix your problem
Posted on Nov 13, 2009
BlacMamba
  • 215 Answers
SOURCE: HP 6940 Deskjet driver not installing WINDOWS 7
hi,the reason why it most probaly comes with that error is that the driver is not meant for windows 7,so go on line check hp site, printer drivers and download.
Posted on Jan 02, 2010
SOURCE: Will HP Deskjet 722c work with Windows 7? There
If you are using a 32 bit version of Windows 7 you can add a driver using the following: go to the Devices and Printers folder, Add a printer, Local printer, LPT1: (or which ever parallel port the printer is connected to), select the Deskjet 720c driver. You may need to click on the Windows Update button if the driver does not show up initially in the list.
If you are using a 64 bit version of Windows 7 there is not a solution at this point, the supplied drivers have an issue.
Posted on Jan 05, 2010
Im looking for a driver for Hp deskjet 825c for windows 7 in south africa
Use the Deskjet 830C/832C drivers. I have a Deskjet 825C and the Deskjet 830C/832C works fine on my Windows 7 64 bit OS. It will work with the 32 bit version as well.
Previously I had Windows Vista installed and found the Deskjet 830C driver worked ok with it as well.
1. Start, Control Panel, Devices and Printers
2. Click Add a printer
3. Click add a local printer
4. Selct Use an existing port
5. In the drop down list select USB001 or 002 or 003, which ever appears. It should say "(Virtual printer port for USB)"
6. click next
7. On the install the printer driver screen under manufacturer select HP
8. Under printers select HP deksjet 830C/832C
9. Click Next
10. If prompted for Which version of the driver do you want to use?" select "Use the driver that is currently installed." and click next
11.Type a name for the printer int the text box for printer name:
12. Click next
13. If you want other computers on your network to be able to share this printer select "Share this printer..." and click next.
14. click print a test page.
15. Click finish.
Download Driver...... HP Deskjet 825c Printer Drivers
Read More help... HP Printer Support
Thanks,
Aug 18, 2014 | HP DeskJet 825c InkJet Printer
Hp deskjet 550c trying to print from network But I am on windows 7. Printer is on xp. Can't find driver or fix to run printer on network
Use my published guide to install the latest drivers for all computers on the network. It is entitled
How to Install the latest drivers for Hewlett Packard Printer!!!
The drivers need to be installed on all computers in the network.
Then once the drivers are installed all you need to do is to navigate to the Windows control panel and double click printers and faxes on the computer that the printer is connected to.
Now right click the your printer and select the option Sharing, this will allow you to share the printer on the network.
Click the lower circle to share the printer.
Then when you print from another computer on the network, be sure to select this shared printer as the printer to print to, or set this shared printer as the default printer by right clicking the printer and selecting the option to set as default printer.
Please be sure to rate this session.
Take care!
damnor01
Jun 01, 2011 | HP DeskJet 550c InkJet Printer
Ho i ll get "HP Deskjet 990cxi Printer"'s
GEt it fro free from HP.com, look under support and drivers.
Feb 23, 2011 | HP DeskJet 990cxi InkJet Printer
My hp photosmart c309n printer won't print quickbooks
Click on printers&faxes(XP)
or
Devices & printers(7)
click on ADD A PRINTER
install basic driver i.e Deskjet 990c (xp,vista)
or deskjet 460 (7)
it will work great
i have tried this and it works
Feb 18, 2011 | HEWLETT-PACKARD Photosmart Premium C309n...
Install hp 1220c on windows 7
See: HP DeskJet 1220c Drivers
However, HP says that this printer driver is in the Windows 7 OS. Try doing a Windows update.
Here is HP's Windows 7 information page:
HP 1220c and Windows 7
Thanks for using Fixya.
Dec 29, 2010 | HP DeskJet 1220c InkJet Printer
I need driver for HO deskjet D4200 or 4260 for system operating Windows 98... Thanks... and best regards ... my friends
Sorry, HP says "If your operating system is not listed, HP does not have software or driver downloads available for this product in that operating system.".
Win 98 is not listed....
Nov 20, 2010 | HP Deskjet D4260 Printer
Hp deskjet f2280 pinter windows 7 driver free
Hp deskjet f2280 pinter don't install in windows 7. now what can i do ?
May 10, 2010 | HP DeskJet F380 All-In-One Printer
Hp deskjet 460 service manual
i need to know the pass code for the bluetooth conection
Feb 09, 2010 | HP DeskJet 460WF Mobile Color Printer
Installation problems with HP dj 460c drivers
unplug the printer then install the drivers then reboot the PC then plug in the USB printer to USB port then insert again the CD installer..if their is same the problem you need to re-install the OS/windows...good luck
May 27, 2009 | HP Deskjet 460c InkJet Printer
I LOOKIN FOR AC ADAPTER FOR HP F370 PRINTER
Whenever I am need of power cords I use Ebay. Here is one for your system.
http://cgi.ebay.com/AC-Adapter-Fits-HP-DeskJet-DJ460-DJ-460-Printer_W0QQitemZ260290984216QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item260290984216&_trksid=p3286.c0.m14&_trkparms=72%3A1199|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
Jan 30, 2009 | HP Ruggedized DC Car Adapter for HP...
20 people viewed this question
jasbo
jasbo
