Question about Brother MFC-8840D All-In-One Laser Printer
Scan lamp is burned out - how can i replace it?
    Habit-Forming:
  • 145 Answers
You can call to authorized service center in your region and take a new lamp)))
Posted on Jun 19, 2009
Burned out lamp RCA DLP TV Mod # HD50LPW165YX4 lamp type B
you can get the replacement lamp cartridge from the following link which also has installation instructions. Your model uses the 265866 lamp assembly.
http://www.tvrepairworld.com/rca_dlp_lamps
Aug 04, 2012 | RCA Televison & Video
What does "E" in the display area mean, toner empty? (We don't own a manual)
E means ERROR. If copies are totally black check to see if the lamp under the glass turns on & scans over your document. Odds are that the lamp is burned out and needs replacement.
Jul 23, 2012 | Sharp Z50 - Z88 Toner
I'm looking for the pig tail or the part where the wire hooks on to the lamp
I think you have to replace the whole lamp socket as the wires are permanently attached to it. I found the sockets online with Google searching for "Socket XX" where XX is the type of lamp specified on the units. They are not expensive BUT the vendors have a minimum so I had to order 6 of them and also some spare lamps to meet the minimum. The wires of the socket you get will have to be trimmed like the original ones for length. These sockets like to burn up. Getting the screws into the socket in the lamp holder I remember is a bit frustrating.
Dec 23, 2010 | Chauvet (2) Chauvet Intimidator Scan Led...
Just replace the lamp.. there is a burning like smell, does anyone know what is causing this smell?
After the projection lamp was replaced the tv work fine right?The burning smell,is the burning carbon from the dead projection lamp.
Oct 06, 2010 | Mitsubishi WD-Y57 57" Projection HDTV
My canon d320coping black no image. what is the
Hello sir; It seems like the exposure lamp burn out, lift up the cover and hit print , if it scan with on light means the exposure lamp out, replace it.
Dec 05, 2009 | Canon PC-920 Black and White Copier
When I scan it comes out all black
The lamp in your scanner is defunct and the replacement of these varies greatly and may not be a DIY job depending on the amount of work to access the guts of the scanner. You need to contact Dell to obtain the part number for the lamp and perhaps order it through them; check your owner's guide for the 800 number.
Sep 09, 2009 | Dell 948 All-In-One InkJet Printer
My internal fluorescent lamp just burned out.
dependes on model of machine, if you are machanically inclined then you should be able to preform repair if not then tech will be needed and it will run you about 150-300 to replace lamp
Apr 11, 2009 | Office Equipment & Supplies
Scanjet 4570c lamp not lighting
Contact HP for warranty services, if it's still new and covered.
You will likely get a replacement unit or factory refurbished replacement.
If out of warranty you will likely have to buy a new one.
Dec 10, 2017 | HP Scanjet 4570cxi Flatbed Scanner
Horizontal Banding
From the Microtek KB: www.microtek.com Scans that produce lines, fading, and discoloration generally result from a corrupt scanner driver installation or a burned out lamp. To determine if your problem is caused by a burned out lamp, simply open the scanner lid and check the color of the lamp. If the color is a shade of red, pink, or green, then the lamp is burned out. Perform a scanner preview to get a clear view of the lamp. If the lamp is a bright white and the problem still exists, please contact technical support.
Jun 06, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
Scanner scanning blackonly
Look at the lamp to see if it is dim or burned out; if the lamp is defective, you can contact Microtek here: http://support.microtek.com
Apr 01, 2007 | Microtek ScanMaker s400
Brother MFC-8840D All-In-One Laser Printer Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
