Question about Refrigerators
LG GR-B206GTQA Fridge Freezer ER CF Error Code
Hi, I hope someone can help me. I have an LG side by side fridge/freezer model no: GR-B206GTQA that I have recently purchased second hand. An error code ER CF is showing on the display panel. I have done a little research on the internet to try and locate the problem and found it to be associated with the condenser fan motor situated at the bottom/rear of the appliance. I have removed the panel to observe the function of the fan blade, the blade would rotate for several minutes when first plugged in and then it would stop and start intermittently before stopping completely, this is when the error code ER CF would appear. I have cleaned the condenser and fan blade etc as this area was very dusty but this didn't resolve the issue so I wrongly assumed that replacing the fan motor would fix it, I bought a new one (the correct motor for this model) and fitted it fully expecting to have successfully repaired it but the fan runs the same as the one replaced. If I turn off the freezer for several minutes and switch it back on again the motor/fan doesn't run at all but if its left turned off for a couple of hours it runs for several minutes before stopping as before and then the error code is displayed again. I would very much appreciate any help offered. Many Thanks Lee
  • Refrigerators Master
  • 884 Answers
The fan is almost certainly run by a sensor in the condenser. If it doesn't get hot enough, the fan doesn't run. Sounds like short of gas. Try wiring the fan to the compressor live and see if it runs all the time then.
Posted on Apr 22, 2014
5 Suggested Answers
  • 110 Answers
SOURCE: LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Posted on Jun 13, 2008
ZJLimited
  • 17970 Answers
SOURCE: Subject: 'New' Kenmore bottom freezer
This is a bad fan motor (click here like a sample replacement) inside the back wall of the freezer, you will need to replace it with part number that could look it accroding with your model. You can order the parts you need from the following places:
- http://www.apwagner.com/
- http://www.repairclinic.com/
- http://www.searspartsdirect.com/
So, according with your comments, if your device has few months, before to take off some part, I suggest contact your dealer or technical service keeping under warranty service.
Hope this helps.
Posted on Mar 09, 2011
  • 6 Answers
SOURCE: fan in the freezer stop working ater a while
The service manual gives the following explanation of your error code (Er FF): "Poor motor, hooking of wires to fan. Contact of structures to Fan. Snapping or short-circuit of L/wire (if there is no fan motor signal for more than 60 seconds in operation of fan motor)" So CoolTech is right!
Posted on Jun 10, 2009
SOURCE: LG Fridge Freezer display has CF error code
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
Posted on Dec 09, 2008
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Hi, I have an LG side by side fridge/freezer model no: GR-B206GTQA that I have recently purchased second hand. When I plug the unit in it runs ok for approximately 10 minutes and then the condenser fan...
You probably need to replace the fan blade or housing. They are available online and are not too much more of a job than the fan motor was. It was likely not the fan motor giving you the problem since they are rather strong.
Apr 22, 2014 | Refrigerators
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
I have a LG GR-L207DUZA ''er ff''
i dont have the manual however.. this could be your freezer fan is perhaps seized.. you can test this by leaving your freezer door open to raise the temp and wait ti see if your fan comes on.. this may take upto 10 minutes so be patient
Nov 11, 2009 | LG Refrigerators
Error code er ff.how do i fix this? freezer is still freezing but fridge is warm.
The error code appears when there is an abnormality of BLDC FAN Motor for Freezer. It circulates cold air from the freezer to the fridge to allow cooling. Check the motor wiring harness for poor connections. If the motor is not working at all, you need to replace it.
To remove the fan and motor assembly:
  1. Remove the freezer shelf. (If your refrigerator has an
    icemaker, remove the icemaker first).
  2. Remove the plastic guide for slides on left side by
    unscrewing phillips head screws.
  3. Remove the grille by removing one screw and pulling the
    grille forward.
  4. Remove the Fan Motor assembly by loosening 2 screws
    and disassembling the shroud.
  5. Pull out the fan and separate the Fan Motor and Bracket.
  6. Replace fan motor assembly in reverse order.
Oct 27, 2009 | LG LFX25960ST Stainless Steel French Door...
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
FF error code
The ER-FF problem that you have is: ERROR -FAN FREEZER so it means that you have a problem with maybe the fan motor or if it's a bottom mount freezer maybe ice built up on the fan motor so it's blockin the fan motor.
Hope i helped u a little bit ! :)
Francois Pelosse
Jan 19, 2009 | Freezers
Dec 07, 2008 | LG French Door Cabinet Depth Refrigerator...
Refrigerators Logo
206 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
