Question about Canon imageRUNNER 5570 Copier
Where is the toner sensor located - Canon imageRUNNER 5570 Copier
My machine is poblam out of toner change toner poblam change tha toner poblam as tis
Out of toner problem often happen when the sensor is blocked with waste or toner-dust-spill and recycled toner cartridge. If you can manage to air-dry-clean (using vacuum cleaner) the housing where the toner is inserted please do so. But it is advantageous to locate the toner sensor location for efficient cleaning. I may know the brand and model of the machine to help you locate the toner sensor. Goodluck!
Jan 05, 2015 | Office Equipment & Supplies
Error code E000024-0001
Toner gets in the developing assembly toner sensor (TS1) and may be shorting out the sensor. Blow out any toner in the sensor wiring and check to see if measure resolved the symptom. The toner level sensor has an open-circuit, replace the toner sensor.
Toner Sensor FK2-0358
However, re-attachment of the sensor also solves the symptom.
When the symptom has occurred, make the following selections in service mode [COPIER > I/O > DC-CON] and check the setting for the bit1 of [P021]. If the setting is "1", re-attach the toner sensor.
One problem found has been the toner sensor scraper blade in the developer not making contact with the surface of the toner sensor.
To check the toner sensor scraper blade first set up a work area. Lay out several sheets of 11 x17 paper on the work surface. Disassembling the developer is a messy job. Remove the upper cover of the developer and then rotate the developer in a counter clock wise direction. Basically the cylinder should rotate so the toner is scraped off of the cylinder by the developer blade.
If it is rotated in the wrong direction a large amount of toner will adhere to the developer cylinder and makes a mess.
The toner sensor is located on the on the outside of the developer and part of it goes through the wall of the developer unit.
Next look at the inside surface of the developer where the toner sensor is mounted while rotating the developer cylinder in the correct direction. There is a mylar scraper sheet that needs to touch the inside surface of the developer wall. In the image below the inside surface of the developer wall is being touched by the mylar scraper blade. If the blade is damaged or broken off the toner will not be cleaned off of the sensor and give the error code E024. If the blade is the problem the developer will need to be replaced.
The part number for the developer is FM2-0287-010.
Apr 13, 2014 | Canon imageRUNNER 4570 Copier
Hi where do i find a toner sensor in a lexmark T644
The toner sensor is located in a hole on the right frame (is an optical sensor)
Sep 05, 2011 | Lexmark T644 Laser Printer
What does trouble code C-2204 mean on our Minolta C451
this is a waste toner box error the waste toner box could be defective or the full sensor is defective i would start with replacing the waste toner box and clean the sensors on the door with some canned air the waste box and the sensors are located inside the lower front door the instructions on how to remove the waste box are on a label on the inside of the door
Dec 01, 2009 | Konica Minolta bizhub C250 All-In-One...
543:K toner sensor error. How do I fix it?
Hi dianabusk:
You have a bad K (Black) toner cartridge or the sensor is dirty,the sensors are located on the toner cartridge and in the machine where the toner cartridge seats. Try cleaning the sensors and/or replace the K (black) toner cartridge. The sensors are a silver color.
Hope this helps
Sep 26, 2009 | OKI C5150n Led Printer
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
Replaced K image drum,K toner had 68% left,now says replace K toner.
There is probably toner spill near the sensor. Take out the K toner unit,careful it is 2 parts, toner resevoir and drum, Then clean the toner spill. The K sensor is located on the right inside wall acrooss from the k Drum. Try to clean the sensor with a cottom swab and alcohol. Hopefully this will clear it. If it does not, you need to have it serviced,Tthe sensor board is held in with 14 springs and it is a bear to deal with.
Good luck,
Joe
Please remember to rate Techs who assist you for free :)
Oct 08, 2008 | Office Equipment & Supplies
OKI C3200N laser printer, low toner problems
For each toner there is an individual toner sensor. There is a real good possibility that the metal contacts on the sensors have become dirty. Typically, a little bit of canned air directly on the sensor contacts will resolve the issue.
After removing a toner cartidge, look to hte left side of where that cartridge rests. The sensor is located there.
May 05, 2008 | OKI C3200n Led Printer
Aficio color 6513 id sensor location, td sensor location
toner density sensor is located in the developer unit. either the sensor is not reading cause something is covering it or it has poped so it can not reference any longer.
Oct 17, 2007 | Ricoh 6513 Copier
Toner low signal
Try turning your copier off & back on. Allow the machine to cycle after turning it back on - until it comes to ready or displays add toner signal again. You can try this three or four times as it sometimes takes the machine a few trys to advance the new toner to the toner sensor. If after 4 attempts you are still getting the add toner message - you may have a dirty or faulty toner sensor. The toner sensor is located inside the developing unit that you are loading toner into. Toner sensor is usually located on the bottom of the developing assembly & is held in by 2 scews. It can be cleaned with a dry cotton rag & reinstalled. 90% of the time power cycling the copier a few times will solve this problem.
Apr 18, 2007 | Sharp AL-1000 Copier
Canon imageRUNNER 5570 Copier Logo
18 people viewed this question
old marine
old marine
