Question about Epson Stylus NX127 Multifunction Inkjet Printer
About every 4th line is un readable
About every 4th line of print the letters are skipping
  • 75 Answers
Hi, try cleaning the printer head via your pc ( use printer manual for maintenance). The other problem could be that the ink is running low. Hope this helps.
Posted on Apr 18, 2014
4 Suggested Answers
SOURCE: my Dell Printer skips lines when printing
mine did the same i used copy paper now i use ink jet and it works fine
Posted on Jun 21, 2009
  • 1548 Answers
SOURCE: Prints every few lines- skips
Inspect the ink cartridge parking zone. If there is a heavy build-up of ink, there's probably a fair amount of ink crusted on the cartridge heads. The bad part is if you remove the cartridges on this model for manual cleaning, the printer may not let you use them again (it will claim the cartridges are empty), so you may want to try cleaning them without removing from the printer.
For this operation, first get the cartridges into the center and pull the plug on the printer so it won't try to put them away while you are working on them. I haven't tried this scheme on a printer yet, but it's worked in other tight spaces: dampen a paper towel with isopropyl alcohol (rubbing alcohol). Wrap it once around the end of a strip of poster board the width of the cartridge and long enough for convenient handling, and hold it with just enough tension the paper towel to keep it in place. Slide this under the ink heads and gently wipe them with the paper towel. Flip the cleaning tool over and repeat with this side. Replace the strip of paper towel and repeat as necessary. And while you are at it, gently wipe out the head parking zone so it doesn't re-contaminate the heads.
Of course, it is possible you really are out of ink - sometimes ink feed to the heads gets erratic when the level is very low.
Posted on Nov 18, 2010
rishardrox2
  • 145 Answers
SOURCE: When printing, it doesn't print the full
it could be the coagulation of ink in between the cartridge better dip it in mild hot water for some times and replace it wiping the water . it would do the trick and solve your problem . it has been practically tested.
If this solution helpful/useful for you please rate my solution.THANKS FOR USING FIXYA.
Posted on May 16, 2011
Printer is skipping
Clean or replace the printing head.
Oct 03, 2012 | OKI MICROLINE 320 Turbo Matrix Printer
When printing, it doesn't print the full detail. It prints, but has lines missing from it to make it un readable. Like if I were to print a letter the top half of the sentence would print but the...
May 16, 2011 | Epson stylus nx110 All-In-One InkJet...
Faint line when printing a letter
hi this may be the toner roller or supply drum for the toner cartridge . if it scratched or worn it leaves marks on the drum or the roller, which in turn fills with toner and leaves an imprint on the page, you can check these , just remove the toner cartridge and look at the green roller and also look at the black roller, it might be a simple case of changing it or cleaning it....hope this helps
Feb 25, 2010 | OKI C5250n Printer
Newer hp 6300 when I print some lines are unreadable, others dark
Dear sir; this is a very comon problem,most people don't know how to take care of, now power on, open the cover until cartridge move and stopin the middle, then UN-PLUG (not turn off) the power cord,let the cartridge stay in the middle,now push cartridge all the way to the end opposite of cartridge seat,use Q-tip with water to clean print head cleaning blade,may be also you can see a ink sticker, remove it, make sure cartridge print head is ok,let me know the resolve. GOOD LUCK !!!
Dec 19, 2008 | Office Equipment & Supplies
When printing some lines don't print properly-appears to be just the top half or less of the line will print. It seems it happens every 3rd or 4th line, but has done it on the second line also, so is not...
Try printing out the test page from the printer, this will show you if any of the inkjet holes are getting plugged. If you can't print a test page without the skipping try changing the ink cartridge(s), the test page will show you which one is clogging.
Carl
Dec 10, 2008 | HP OfficeJet 7410 All-In-One InkJet...
My Dell Printer skips lines when printing
Oct 06, 2008 | Epson Stylus C86 InkJet Printer
HP 5740 Printer skips top half of several lines
try a letter with brown letters to see if it is the black ink cartridge Refilled cartridges do that from time to time
Sep 12, 2008 | HP DeskJet 5740 InkJet Photo Printer
HP 7410
do a self test on the printer and see what that looks like.
Apr 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Not printing right
You need to run an inkjet printer maybe once a week or so, depending on the relative humidity of its location. You need to do a head clean, maybe change your cartridges - again.
Dec 22, 2007 | Lexmark X75 All-In-One InkJet Printer
Epson Stylus NX127 Multifunction Inkjet Printer Logo
106 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
