Question about Canon imageRUNNER 2270 Copier
Please help solve my problem with my ir2270 for not recognising toner
3 Suggested Answers
  • 990 Answers
SOURCE: Rplacing Waste Toner Container
Hello sir;The waste toner bottle right in front of the machine, when you open front door you ill see a white bottle remove and dump it out, turn power off and back on.
Posted on Apr 15, 2009
Cogz
  • 1326 Answers
SOURCE: a message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
My canon ir2270 is saying code error e000020-0000 please help me understand this
that error indicates that there is an obstruction between the toner hopper and the developing unit .
Feb 16, 2016 | Canon Office Equipment & Supplies
E000024-0001
Hi
The first thing I tend to do with any fault on a computer or related hardware, is to turn it off, unplug it from the power supply, turn off and unplug the rest of the system components. Wait for a few minutes, plug the equipment back in and turn all components on and then reboot the computer.
If you have already done all this then I suspect that from the error code your machine is a Canon in the iR range. For the purpose of a reply I have used the iR2270, but the error code can occur on other models.
Description:- The developing assembly connector is disconnected.
The connection detection signal is absent continuously for 100 msec.
Remedy:- Replace the developing assembly toner sensor. Connect the connector. Replace the DC controller PCB.
This can be seen on this webpage where you can change the model number to your particular machine by using the drop down menus along the top of the page:
Error Codes Canon iR2270 Code E024 0000
You can also obtain a full service manual from this site.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 13, 2014 | Office Equipment & Supplies
Please help me a reset key for the copier machine IR2270 wich read error code E000000-0001
The abnormal rise of temperature.May be main thermistor or dc controller pcb.You have to reset the machine in service mode COPIER FUNCTION CLEAR ERROR.
Oct 30, 2014 | Canon iR2270
How to clean error 000024-01 in canon 2270
E024-0001 Error Code:
Toner gets in the developing assembly toner sensor (TS1) and may be shorting out the sensor. Blow out any toner in the sensor wiring and check to see if measure resolved the symptom. The toner level sensor has an open-circuit, replace the toner sensor.
Toner Sensor FK2-0358
However, re-attachment of the sensor also solves the symptom.
When the symptom has occurred, make the following selections in service mode [COPIER > I/O > DC-CON] and check the setting for the bit1 of [P021]. If the setting is "1", re-attach the toner sensor.
May 18, 2014 | Canon ImageRunner 2270 | IR2270 |
Error code E00024-0001 for canon ir2270
Clean DP unit (developer unit) and install toner manually Press- additional Then 2,8 ,additional press Copier ,function ,install toner ,ok if not then Replace DP censer or toner hopper censer
Nov 06, 2013 | Canon imageRUNNER C3200 Copier
ERROR E0024 FOR CANNON IR2270
check the toner hopper .toner is not being fed into the developer module at set rate.clean the hopper by blowing the toner and check the toner screw motor for rotation and do check when u install toner by service mode does the toner bottle rotate.
Aug 13, 2011 | Canon ImageRunner 2020i Copier
IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Jul 06, 2009 | Panasonic WORKiO DP-2330 Copier
Apr 14, 2009 | Canon imageRUNNER 2270 Copier
A message is poping out saying replace the waste toner container.
Apr 14, 2009 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 2270 Copier Logo
29 people viewed this question
old marine
old marine
