Question about Canon imageRUNNER 2270 Copier
The sensor in dv for ir2270 cannot sense toner what should i do?
2 Suggested Answers
  • 990 Answers
SOURCE: Rplacing Waste Toner Container
Hello sir;The waste toner bottle right in front of the machine, when you open front door you ill see a white bottle remove and dump it out, turn power off and back on.
Posted on Apr 15, 2009
Error code f2-4
toner density trouble,
check developer mag sensor located at bottom of DV unit
check toner motor ,
check DV-unit gear assembly
Jun 15, 2014 | Sharp AR-207 Copier
Tip
Printer stops printing before toner cartridge is empty.
You have to keep replacing your toner cartridge before it is empty. It could be anywhere from 1/4 to 3/4 full and the printer says that it is empty and needs to be replaced. <br /> <br /> This happens because of the sensing mechanism used in toner level sensing system. For the printer to know when the cartridge needs to be replaced manufacturers generally use a simple, and generally reliable system of infared emitters and sensors. An infared beam is shined through the toner cartridge from one side and a receptor senses the beam on the opposite side. As long as the beam can't shine through the cartridge all is fine and the printer thinks that the cartridge has toner. When the beam is detected by the sensor the printer thinks the cartridge is getting empty. All you need to do for a sensitive sensor is to block the path. The only thing you will lose is the ability to be warned when the toner is getting near empty. As long as you have a new toner cartridge on hand this should be of no consequence.<br /> <br /> To defeat the sensor remove the toner cartridge and look at both ends. There should be a clear window on each end for an infared beam to shine through. When full of toner the beam is blocked. If you have a sensitive sensor which can detect the beam before the toner is gone you will get a warning before the toner is completely gone. <br /> <br /> Carefully place a small piece of opaque tape, (masking or electrical tape) across the window to block the beam. Make sure that the tape is secure and will not fall off inside the printer. This should solve your problem and allow your printer to print until the toner is completely empty.<br /> <br /> Thanks for using FixYa and for the great rating.<br /> <br /> hardrocko
on Jun 07, 2011 | Office Equipment & Supplies
How to clean error 000024-01 in canon 2270
E024-0001 Error Code:
Toner gets in the developing assembly toner sensor (TS1) and may be shorting out the sensor. Blow out any toner in the sensor wiring and check to see if measure resolved the symptom. The toner level sensor has an open-circuit, replace the toner sensor.
Toner Sensor FK2-0358
However, re-attachment of the sensor also solves the symptom.
When the symptom has occurred, make the following selections in service mode [COPIER > I/O > DC-CON] and check the setting for the bit1 of [P021]. If the setting is "1", re-attach the toner sensor.
May 18, 2014 | Canon ImageRunner 2270 | IR2270 |
Ir2270 not sensing toner
Simple That problem is in the Developing Unit. If you check the DV you will find on one side it has gears remove the screws to expose the gears. Then look for the small round copper metal in front of a gear thats your culprit. Replacing it is the best way. Or clean it if no replacing part is available.
Apr 18, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Sharp mx 5111n error code f2 40
Take all toner out. Press P,*, CA, *. Go to 25. Then go to 2 automatic dv adjustment. Click kcmy at bottom and hit execute. Repeat 2 - 3 times. Then install toner and see if it works. There is a sensor in the dv unit that senses to much toner in there. Could be caused from worn out drums or dv unit itself.
Nov 13, 2013 | Office Equipment & Supplies
ERROR E0024 FOR CANNON IR2270
check the toner hopper .toner is not being fed into the developer module at set rate.clean the hopper by blowing the toner and check the toner screw motor for rotation and do check when u install toner by service mode does the toner bottle rotate.
Aug 13, 2011 | Canon ImageRunner 2020i Copier
My gestetner DSM735 keeps saying add toner. replaced toner and developer still saying add toner
The first thing i can tell you is that is weird!!!!
Because if you change the developer that error should disappear. It could appear later but not in the moment because the developer already have toner and the TD sensor will read it.
And that's the question: When you said "replace developer" you mean just the developer or the DEVELOPER UNIT??? Is your TD sensor working good????
Feb 23, 2011 | Gestetner DSm735 Black and White Copier
IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Jul 06, 2009 | Panasonic WORKiO DP-2330 Copier
Apr 14, 2009 | Canon imageRUNNER 2270 Copier
How to calibrate the dv and toner...
Did you use a vaccum on the developer unit???? You may have blown out the ATDC sensor on the developping unit
Mar 02, 2009 | Ricoh Aficio 450 Copier
Canon imageRUNNER 2270 Copier Logo
19 people viewed this question
old marine
old marine
