Question about Lands Phones
How to solve sensor problem
Sensor problem
  • 341 Answers
We need a lot more information to be able to help you! What is the sensor in, what lead you to thinking it was the problem and so on.
Posted on Apr 18, 2014
  • Logan Krager
    Logan Krager May 01, 2014
    Well what lead me to thinking that the sensor was broken is when I turned my tablet on and tried to put in my password the touch screen wont work when I touch the screen but yet it still turns on.
How can solve error p 5 idc sensor in konica minolta bizhub c450
P5 front IDC sensor failure.Wipe clean the surface of the transfer belt if it is dirty with a soft cloth or change the transfer belt unit is damaged.Reinstall or reconnect IDC sensor shutter or connector for every color unit and clean the sensors when vacuum cleaner after remove the all imaging units and the transfer belt unit.
Mar 25, 2014 | Konica Minolta bizhub Office Equipment &...
After diagnostics on my 2003 bmw 318 coupe,camshaft sensor error showed up to be the problem.my car struggles to start and keeps cutting out whilst driving..will replacing the sensor solve this problem?
You are correct...
Your vehicle's ECU relies on data received from the Camshaft sensor, to determine correct engine timing etc etc. It's also important to note that often camshaft sensor errors are closely related to crankshaft sensor problems also.
Recommend you disconnect the the Camshaft Sensor plug and do a test accross the terminals. If the measurements are not to factory specification, replace the sensor then clear the code. If the engine still cuts out, continue to query the diagnostics until problem is solved.
"If this has helped you in any way, please rate this solution"
May 08, 2011 | 1999 BMW 318 ti
My xerox machine cannon IR 2020 shows a system error E007. How can I solve it? Please describe step by step.
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Nov 11, 2010 | Canon iR 2022 Printer
How can i solve this errorcord eoo7 canon IR2016J
1. Check fixing film sensor.
2. Check fixing film sensor connector.
3. Check fixing film.
Apr 16, 2010 | Canon PC-940 Black and White Copier
Brake light is on after changing pads and sencors
Check brake fluid level, if low top up & problem solved
If not, disconnect and reconnect the sensor wires ensuring a good connection. Check to see if solved.
If not, it seems that the sensors are perhaps receiving an earth signal somehow, check that the sensors are seated correctly.
Hopefully one of the above will sove the issue.
Regards
Lloyd
Dec 15, 2009 | 2005 Land Rover LR3
Exposure density sensor problem. how do l solve it?
If you remove your drum unit, you can see the sensor inside. Make sure it is clean. If the problem returns, check the toner support of the drum unit. It is probably dropping toner onto the sensor. You will also see flecks of toner on your copies if the toner support is bad.
Oct 29, 2009 | Panasonic FP-7735 Black and White Copier
How do i solve the engine diagnostic code # 7
First check for power and grounds at the sensor. Check for voltage at the signal wire, and continuity on the signal wire bt the sensor and the ecu. if all your circuits are OK then replace the sensor.
Aug 02, 2009 | 1991 Honda Accord
Lands Phones Logo
22 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
