Question about RCA T09082 9 in. TV/VCR Combo
I am wanting to connect my Directv DVR to a RCA T09082 tv/vcr combo.  I can get audio but the picture is unclear with lines running through it. Is there something wrong with the tv? I tried running it through an RF converter as well and had the same issue.
  • 43 Answers
Have you tried a another av cable. Also make sure your connections are color coded yellow to yellow and so on from the directv receiver to you tv av input.
Posted on Aug 02, 2009
We recently connected to Direct TV...I want to transfer some old western TV Shows I recorded on my Direct TV DVR Recorder to VCR Tape. I was told by the people at Direct TV that I would need to contact you...
You can try this: Connect your DirecTv to VCR with Red/White/Yellow cables. Then the VCR to your TV with the same type of cables. Make sure the VCR is set to the video input, not the tuner. Turn your TV to the correct video input. Get the program ready on the DVR as if you were going to watch it. Press record on the VCR and then play on the DVR. At the end of the program, press stop on both. You may have a problem with the video recording properly. Some stations broadcast with copyright protection.
Apr 12, 2011 | Emerson Televison & Video
I need to know how to hook up my vcr to my dvr to record something off of it onto a vhs tape. directv said i need to contact the maker of the vcr & guess what RCA doesn't help with that. but i...
Ok. You connect the vcr to the televison first. Take an rca cable and connect it to the video out of the vcr then connect the other end to the av input on your television. Then take another set of RCA cables and connect them to the RCA av input on your vcr and connect the other end to the output on your dvr.
Now hopefully your tv has another RCA input you can hook directly to the dvr with another set of RCA cables to another one of the dvrs outputs. If not then don't worry about that.
Now make sure the tv is switched over to the av video RCA input the vcr is connected to and turn the vcr on. The vcr should be in input and when it is you will see the picture from your dvr and you will change channels with your dvr remote. You can now record using the vcr remote.
Jun 14, 2010 | RCA VR546 S-VHS VCR
We have a T09082 and would like to hook up to dishnet work. We lost the remote and we are trying to find the right remote code can u help.
Try the codes for an RCA VCR.
If using a One For All (or UEI) remote it is code 0240
If you need to use the A/V input on the side press the setup key and then 212, that will switch the input (I think this only works on the UEI OneForAll remotes).
Nov 23, 2009 | RCA T09082 9 in. TV/VCR Combo
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
jlopez.jagsat@sbcglobal.net
Mar 02, 2009 | Daewoo DV-T47N VCR
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
I need the pinout for the AC/DC 5 pin power plug on the RCA T09082.
This is what I found, I haven't tested the DC side yet, but I did trace it to the circuit board and this is what I found.
I can say the AC side does work if you plug an appliance cord into the yellow pins, that is how I use it.
Jan 13, 2009 | RCA T09082 9 in. TV/VCR Combo
Need to program my TV-VCR 9" combo using the RCA remote RCC311w
Try pressing the VCR button and see if that works.
Alternatively use one of these codes (For RCA VCR):
2000, 2003, 2007, 2013, 2021, 2022, 2055, 2056, 2082, 2083, 2084, 2085, 2086, 2087, 2088, 2089, 2090, 2091, 2100, 2107, 2115, 2120, 2125, 2133
Two methods of programming RCA remotes:
A: If your remote has a "Code Search" button:
Press and hold the button until the light comes on and stays on, then release and press "VCR", Enter the last 3 numbers of the code (no using the first number 2).
B: No code search button:
Press and hold the device key, while holding it put in all 4 numbers of the code, then release the device key, the light should go out.
Dec 21, 2008 | RCA T09082 9 in. TV/VCR Combo
Only works when playing a DVD.
This is an easy and quick fix.
What you will need:
RCA cables (audio)
( possibly Line out converter )
Your television is either going to need Video Out, or if you have a VCR or VCR/DVD combo connected to your television. Assuming that you have a VCR combo, the way your tv should be set up is on the back of the vcr combo, your cable will run into the coaxial IN and then you have another cable running from Coaxial OUT to your tv. If you have it set up like this, then the DVD / VCR combo will have RCA Audio / video out ports on the back side. Run RCA cables from the DVD / VCR output to the surround sound INPUT. If you already have your inputs in use on the surround sound, Radioshack has RCA splitters for about $1.50 each, you might need to pick some of them up so you dont have to go through the trouble of reaching behind it all the time to disconnect and reconnect whatever your trying to connect. Now if you dont have the DVD / VCR combo, then your TV "MUST" have RCA Outputs. if it doesnt, then the only way that your going to have your surround sound connected to your tv is to take the TV apart and get a RCA "Line output converter" and wire it to the left / right channels of your tv. From what I've read, i think this is what your trying to do so I hope this helps
Feb 19, 2008 | Durabrand STS92 System
I want to connect my sound system to my tv
Jan 20, 2008 | Durabrand STS92 System
RCA T09082 9 in. TV/VCR Combo Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
