Question about Zanussi WJS1265W Front Load Washer/Dryer
Has power but stopped worki
Power to machine is on, power light on door does not come on or do anything
    New Friend:
  • 75 Answers
Hi, check if the door is closed properly ( has a two step lock on door). The door must be closed firmly all the way. Hope this helps.
Posted on Apr 18, 2014
SOURCE:
Problem with AWO3561 wash machine red door light flashing
there is a valve for the door lock if this goes it thinks the door is open and shuts down thinking the door has been opened if the feed pipe become blocked the water pressure sends air pressure to the switch when water is added. spin/drain setting it don't use this sensor switch, but on filling up it will. its usual down to a blocked pipe , or a leak in the line. sometimes it can be the switch, the pipe is located at the bottom around 2 inches from the bottom and the feed wire goes to a sensor , take the pipe off and blow down it best to have some water in the bottom of the drum, so suck and blow on the pipe to loosen anything blocking the pipe. switch don't blow or suck on this as it can damage the sensor. if the sensor is at fault you can only replace it as the valve inside for the switch if you use anything it will pierce the valve , hope this helps you.
Jun 24, 2017 | Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
The washing machine seems to have stopped during it's cycle ad the door light has come on, now it is stuck with the door light on and I'm not able to reset it, change functions, start a wash,...
From your desciption it seems to be indicating that there is a problem either with the door lock or more likely the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 19, 2011 | Electrolux Washing Machines
Hi, the lights come on but machine wont do anything. Is there anything i can check before calling an engineer?
hello check the door interlock with the power off make sure the door's got a good connection also check the belt might have snaped or come off if theres a humming sound from the motor the brushes might be the cause. these are made of carbon and wear down can cause the motor to stop working on the motor there are 2 plastic blocks sit either side of the motor they just slide out hope it helps
regards
shaun
Mar 19, 2011 | Candy Washing Machines
The timer was set without anything in the Microwave. Now nothing is workiing - no lights, power, etc. It was very hot!
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 28, 2010 | GE JVM1850 1000 Watts Microwave Oven
No power not coming on. circuit braker is not kicked.
Start with the simple things and work your way from there. You will be amazed how many people call a plumber who flips a breaker or simply clears a stuck float valve (for $80 minimal fee).
If no lights are coming on.
Check if your float valve is jammed.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine. Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
Not the float valve ?
Check the door interlock latch.
Much like a washing machine a dishwasher will only operate with the door closed (or when it thinks it is closed!). There is a metal tab that engages a switch in the door. This is the same switch that activates as you operate the handle to open the door. If it is misaligned it will not signal the machine that the door is closed and the machine will not operate.
You can check this by overriding the locking tab. Put a screwdriver in the door latch and press the switch. You should see the lights come on and power flow to the machine.
Note: if the machine is in run mode you will get water spraying.
To fix this problem bend the tab to properly engage the switch. Or if necessary loosen the screws retaining the switch and move it to correctly align with the tab.
Not it?
OK now you are into electronics.
First is quite simple. Some units have an internal fuse to protect the control panel. Check that first. Take your time and take care. Turn the breaker off.
The control panel is screwed in place. Remove the screws and gently remove the control panel. Take care not to have parts of the door latch fall out or springs drop out etc. On newer units it is very simple as it is just a circuit board. Look for the fuse and check that it is OK. Replace if necessary with correctly rated thermal fuse.
Mar 21, 2010 | GE Dishwashers
Light is blinking but the light bulb is good, cooling seems worki
no lights and a clicking noise when the doors are opened??? control lights also are out, but appears ti be still cooling??? if this is ht eissue you have a problem withte control board, located behind the refrig mounted next to the compressor in a white enclosure. call the manufacture or local part distributer for part, you can replace yourself!
Jan 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Zanussi WJS1265W Front Load Washer/Dryer Logo
56 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
