Question about Canon imageRUNNER 2270 Copier
Ir2270 after putting toner the machine is just turing with red light flashing
Toner problem
4 Suggested Answers
20YrsCompExp
  • 227 Answers
SOURCE: a message is poping out saying replace the waste toner container. Could you please advse where it is located on the machine?
Open the front door and try looking down to the right corner of the machine
Posted on Apr 14, 2009
  • 990 Answers
SOURCE: Rplacing Waste Toner Container
Hello sir;The waste toner bottle right in front of the machine, when you open front door you ill see a white bottle remove and dump it out, turn power off and back on.
Posted on Apr 15, 2009
Cogz
  • 1326 Answers
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
When should I replace the toner cartridge? I found that red light is flashing( the lower light, totally there are 2 lights: upper one is green now). I don't understand what does it mean.
It mean when your toner is near empty,then red light flashing.tow light is fixed or red mean toner cartridge is empty.must be replace toner cartridge.You buy a new cartridge and put in your printer then printer is OK.
you can also get better idea please read printer user guide.
Mar 04, 2010 | Samsung ML-2240 Laser Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
When i turn on the copier it is stuck on 10 copies and a light flashes to the left of the copy number. I don't have a manual. I don't know what the flashing light means.
If the light is a red light with a flash shape then the machine probably has a jam. Look for jams and once you have cleared any jams switch the machine off and then on again. It could be the toner light if there are about six red dots - in this case you need to add toner.
Jun 30, 2009 | Canon NP 7130 Black and White Copier
Apr 14, 2009 | Canon imageRUNNER 2270 Copier
RED LIGHT
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
Feb 23, 2009 | Sharp AR-153E Copier
2200d hp laserjet
The green flashing light lets you know that the machine is recieving data. This is completely normal, however, the red (Attention) light can mean several things. There can be a door open, missing toner cartridge, out of paper, or paper jam. In this cause it is probably the toner cartridge. Typically on these machines there is an Orange or Green tab on the side of the toner cartridge that needs to be pulled to fully engage the cartridge. You may want to make sure this has been pulled and the cartridge has been properly seated.
Hope this helps...let me know if you need any further assistance
V
Sep 19, 2008 | HP LaserJet 2200D Printer
Canon imageRUNNER 2270 Copier Logo
23 people viewed this question
old marine
old marine
