Question about Makita 18V LXT Lithium Ion Cordless 3/8 Angle Drill Kit
How do you put the black chuck cover back on - Makita 18V LXT Lithium Ion Cordless 3/8 Angle Drill Kit
    Champion:
  • 304 Answers
It sounds as thought you have a keyless chuck on your drill. The cover is not meant to come off. You will have to replace the chuck.
Posted on May 04, 2014
Craftsman drill model 315
If it just fell apart the do not waste your time putting it back together as it will only fall apart again when you are working. Just get a new chuck.
Jun 28, 2013 | Drills
How do I take a bit out?
It is a keyless chuck. Put the drill in reverse (chuck should spin to the left when viewed from the back) and hold the main body area of the chuck with your hand while slowly running the drill. The chuck will open (unless it is broke) and release the bit. You do the opposite (slowing running the drill in forward) for tightening a bit in the chuck.
Jul 16, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How do I change the drill bits and then tighten so the bits stay in the drill?
The chuck will not turn. So to loosen just turn the black plastic counter clockwise. The chuck will loosen. Or you can hold the black part on the chuck tight and put the drill in reverse and slowly squeeze the trigger and the chuck will loosen also. Do the opposite to put a new bit in. Put the drill in forward and hold the black part of the chuck and squeeze the trigger with the bit in place and it will tighten down on the bit.
Dec 16, 2010 | Dewalt 18 Volt Compact Drill Kit
I have a Black & Decker 18V cordless drill with keyless chuck. The spot where the drill bit fits is in the open position stuck and won't turn in either position. What am I missing how to unlock it?
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
Jun 12, 2010 | Black & Decker CD9602SB 9.6 Volt Cordless...
Bit is stuck / jammed. Can't seem to loosen. Any ideas on how to fix?
If the chuck is too tight to get the bit out you can either put a glove on one hand grab the chuck and run the drill in the reverse direction or if that will not work use vise grips or a small pipe wrench on the chuck to loosen it but be sure to tape the pipe wrench or vise grips with a thin piece of duct tape so you don't gouge the drill chuck.
May 23, 2010 | Black & Decker BD12PSK 12-Volt Smart...
Black & Decker 9.6V drill has ''stuck chuck''
put some oil in the chuck and see if you can free it up buy turning it back and forth let it set with the oil for a day or so to let the oil soak in.
Nov 06, 2009 | GPS
Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Aug 18, 2009 | Black & Decker Drills
HI I AM USING A HILTI TE16c AND THE HEAD WHERE YOU PLACE THE DRILL BIT OF THE DRILL HAS FALLEN OFF CAN YOU ADVISE HOW TO PUT IT BACK ON
this is an easy fix. it designed to come of easily and can fall off if you dont tighten the side handle. the chuck has a quick release mechanism. place the chuck onto the machine as far as you can. it wont go on all the way. simply pull back the black collar on the chuck toward the front of the chuck and push the chuck on the rest of the way.
to ensure that it is on correctly, turn the chuck by hand until it locks into place.
Hope this helps.
Aug 15, 2009 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
There is a little metal plate that is sticking out at the back of the chuck and opening and closing of the chuck has become very hard. I cannot find a schematic for this drill. I took the screw chuck off...
Place tool lightly in vice, place any allen wrench , L shaped type , with long end out of chuck, small end in chuck. clamp chuck jaws tight around end of wrench. With pipe or hammer, tap end of wrench counter clock wise.
These chucks are tight.
Jul 08, 2009 | Panasonic 15.6v Ni-mh Cordless Drill -...
Never have used a keyless chuck b4- need to change bit, how do I do this? thanks
hi this should be reletively easy hold the end black bit with the sivler bit holde coming out not the black bit next to the yellow case on drill you hold the black part thats at end of drill by where the bit goes into not the black bit near the trigger hope i explain this ok.
Hold this bit tight then put drill in reverse then press trigger a couple of times it might be tight but shouldnt be that tight it wont undo.
1 put in reverse
2 hold black plastic piece near where drill bit goes into
3 press trigger few times
4 this should undo it allowing you to put a bit in
make sure its in reverse else you will just tighten it up more let me know if you need further assistance ok
Mar 05, 2008 | Dewalt 18 Volt Compact Drill Kit
Makita 18V LXT Lithium Ion Cordless 3/8 Angle Drill Kit Logo
77 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
