Tv just go dead and has to be be restarted at the on/off switch.
The tv for no reason at all just go dead and have to be switched on at the on/off switch at the bottom off the tv.Sometimes several time fliking the switch.Sometime you have to tilt it forward while flikking it on and off.It sometimes stay on for long but sometime has to be put on every 5 to 20 minutes.I checked for loose components and wires but found none
  • 341 Answers
It sounds like your power supply is about to die or it has some capacitors that are about to fail.
Posted on Apr 18, 2014
Kimi
  • 277 Answers
SOURCE: Panasonic TH-50PV30
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Posted on Dec 22, 2005
SOURCE: my plasma tv switching off byself
Sounds to me like your internal cooling fans are not working. Try placing a fan behind your tv and seeing if it stays on longer. If it does then you'll know it's a problem with these fans. Not expensive to fix but not easy to do either.
Posted on Apr 10, 2008
wiznet2000
  • 86 Answers
SOURCE: The tv keeps switching itself off at random,
This problem is exactly the same with my tv, just remove the battery of the remote. if it stop on & off, then clean the remote
Posted on Jun 28, 2009
  • 304 Answers
SOURCE: Samsung 50'' Plasma TV won't turn on anymore
If your tv is within the one year warranty period then call 1-800-Samsung for warranty repair. Look at your tv purchase receipt for the Purchase Date. You have one year from the date of purchase to get warranty repair.
Posted on Jul 16, 2009
  • 636 Answers
SOURCE: Philips LCD TV Matchline series keeps switching off!
heating up issue, try unplugging it and if you can clean the dust from within the unit. Try reversing the vacuum and blowing excess dust out.
Posted on Sep 09, 2009
Testimonial: "I will try your solution...sounds logical and may well do the trick. Thank you for taking the time to sending me your advice...much appreciated. CJ"
My TV has dead but not same of the 1st and 2nd time,and the switching regulator has be protected.
The set shuts down after one or more times? It is called shutdown and the set is protecting itself.
Apr 17, 2012 | Sharp Televison & Video
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
Tv has no power, can't find reason.
they have little relays in them, kinda rectangle and tall on the board, you can peel the thin plastic case off the sides and manipulate the switch to narrow it down as to which one is bad.
Aug 19, 2009 | Televison & Video
My tv seems to be dead...
Ur power board ic converter is dead.
Need a new one.
Aug 18, 2009 | LG 42LC2D 42 in. LCD HDTV
My xbox 360 turns on fine but it won't show on my tv
Im presuming you have check all the cables settings...
and still just audio , It requires that the G.P.U. be Preheated
and seated ( clamp down) and then Burn in A.K.A. x clamp mod.
the dead video problem needs a little more then the regular
x clamp mod , so make sure who ever dose it has a good
success rate .
Jun 22, 2009 | Microsoft Xbox 360 Console
I seem to have a short in my main power switch on my astar tv
it won't be the mainpower swith problem,your tv has a fault,u wiggle the main power swith,the tv lose the memory of the fault,it's like a reset the tv,and then the tv back on again.
Mar 29, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
Sony KV-27FS100L -
This is due to switches malfuction due to corrosion in switch and dust accumulated in the switch. Since you rarely used switch now after failure of remote of remote control you tried to operate the switch. Another thing you said did"t get picture, maybe memory problem is there. This can be sorted out by the technician only.
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
