Question about Dell Studio 15 Laptop
M1522 printer firmware - Dell Studio 15 Laptop
My hp laserjet m1522 powers on then hangs
Check voltage between 1 & 12 connector J32 on formatter should be 5V, if no replace DC controller(engine controller PCA),P.No RM 4932-000cn(120V), RM4936-000cn(220V).If voltage is good replace Formatter..P.No.CC396-60001
Oct 18, 2011 | HP LaserJet M1522nf Multifunction Printer...
On my HP M1522 which i only use the photcopying function I have to keep turning it on and off to get the copier to work each time.
If your 1522 keeps freezing up, then it is likely that the formatter board is failing. Any M1522 manufactured before January 1, 2010 is covered by an extended service advisory, which means HP will replace your defective formatter. Check the serial number sticker on the back of the unit for the date of manufacture and if it is older than the date indicated above, contact HP and ask them to fix it for you. Or you can locate a local HP service partner who can do the work for you.
Mar 14, 2011 | HP LaserJet M1522nf Multifunction Printer...
HP LASERJET M1522 NF 79 error what is it?
Hello i hope u 'll be fine.... thanks for using fixya.
NF 79 is actually an
internal firmware error. It means unit has encountered an firmware error internally.
To solve it try this
If printer is plugged in to a surge protected extension lead then remove it and plug it directly in to the wall socket.After it retry.
If this fails again, then replacement of formatter of the printer is best option.
Best of luck
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Jan 01, 2011 | HP LaserJet M1522nf Multifunction Printer...
My M1522 turns off after printing once. It has
it could be a power failure on the formatter board
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp, 1800-334-5144. If within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Jun 17, 2010 | HP LaserJet M1522nf Multifunction Printer...
How can i do hp Laserjet M1522 printer online?
If you have any doubt in my mind related to hp printer then you can call on 1-888-924-2961 toll free number anytime for hp printer support. Technical Support For HP Printer
Jan 27, 2010 | HP LaserJet M1522nf Multifunction Printer...
HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Jan 07, 2010 | HP LaserJet M1522n MultiFunction Printer
After I scan documents with the M1522, it will not receive faxes
Hi dbraaten,
This sounds like there is a problem with the scanner assembly. Are you getting any error messages? Like scanner error 5? If so call hp tech support 1800 334 5144.
Al
Dec 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
HP LASERJET M1522 NF 79 error what is it? I happens each time I print and the printer shuts itself off.
The unit has encountered an internal firmware error. If it's plugged in to a surge protected extension lead then remove it and plug it directly in to the wall socket. Retry the printer. If this fails again, then it looks like it would have to be a formatter replacement on the printer
Oct 04, 2009 | HP LaserJet M1522nf Multifunction Printer...
Dell Studio 15 Laptop Logo
mukhtar21 shaikh
mukhtar21 shaikh
