Question about Fujitsu LifeBook S7010D Notebook
Want to use clone hard drive to run XP
My Fujitsu LIFEBOOK S7010D (FPCM41534) PC Notebook needs repair of fan which will take about a week. I cloned the drive to an external USB drive. Can I use the clone from the external drive to run an HP XP computer? If so, this would allow me to run a virtual copy of the Fujitsu until I get it back.
  • Fujitsu Master
  • 32,281 Answers
Because the HP and Fujitsu have different devices, you cannot clone (or create an image of) the hard disk and expect it to work on the other laptop.
Your best bet would be to copy your data files onto a USB memory stick or an external USB hard drive and plug it into the HP. You can open the files on the USB memory Stick/hard drive to work on them or copy them to the HP's hard drive to work on them.
When your Fujitsu has been repaired you can copy the latest files from the USB memory stick/hard drive back onto your Fujitsu.
Posted on Jun 19, 2009
Bios password Bios password Fujitsu Siemens LIFEBOOK E8020 PC Notebook
  1. If wanting to clone or transfer operating systems from another computer where one has a malfunction deficiency in programs requesting restoration from another with system compatibilities. Prior to the process, a compatibility check has to be performed on both devices, an estimate of the damage is determined on the computer requesting cloning to ascertain if any changes in software or hardware is required prior to the initial process commencement. Thereafter, the accessories that would be required like cables to link both devices are attained before the entire cloning starts.
Usually two computers are capable of sharing one operating system considering several conditions. First, both computers have to the have same operating system where one has experienced a malfunction requiring repairs from the other. Second, both computers prior to a clone require capacity checks. Usually the host computer would need available space to create back up before the cloning process begins should any malfunction compromise both devices integrity. Second, the receptacle computer requiring cloning depending on the conditions would require available disk space to contain the entire clone programs. Usually the cause of a computer to require restoration altogether of operating system requires evaluation since most computers only have enough space to contain an operating system with user interface fonts for productivity. Estimate the conditions on the damaged computer to ascertain if an erasure of disk spaces would be required to create spaces. Also, keep in mind that computers would not clone another system of its own if remnants of the master system are recognized as being present on the hard drive disks. The process of freeing the hard disk drives of spaces for cloning is called formatting achievable with some computers. However, the condition of formatting when not possible due to crashed or program compromises may simply require changing a new empty hard drive before the cloning would be made possible. Once the host computer is has the capacity to power an external device it nature either as available disk space to create backup required prior to cloning or usually a system checks to ascertain that the alternate computer has the capacity to receive every data. Alternately, the receptacle computer may have required changes of parts prior to cloning. A mentionable example includes hard disk drives to contain the new programs, also required to have enough space to create backup once the computer cloning is achieved. The next requirements check for cloning is ascertaining the appropriate cable connection that would be bridging the space gaps for data to be transferred. Usually an effective cable has the capacity to be recognized by both devices as measure prior to any cloning communications. Also, an efficient cable should have the most capacity to transmit data at quantities that does not cause malfunctions discussable. For example, the cables capacity may actually be able to transfer data only not capable of transferring every data size requiring transfer. Once the process is began with such a cable, some computers would transfer only what is achievable to the negligence of what is unachievable. However also, cable incapacity to transfer every data would would last several durations during the process o cloning. Simply said, the cables require compatibility to both computers, second an enormous capacity to outperform prevents any malfunction on the cable connections part during the cloning process.
  1. Alternately, a computers operating system is replaceable simply by acquiring the restoration programs at retail markets. However, the original computers restore operating systems program has to be acquired with details acquirable as computer type, year, models, and versions as guideline references in acquiring operating systems programs at retail. The reasons for such evaluation include acquiring a program that simply is adaptable to the malfunctioning computer. Alternately, a different operating systems program is acquirable on the retail market to replace the malfunctioning computers systems only with some conditions considered. First, the computer has sigficant parts that integrated with the prior operating system that may need alterations altogether to function with the newer but unique brand away from original brand specified. If choosing to acquire an alternate operating system from the original several additional alterations are required. First, the computer hard disk drive may need replacement either since most operating systems would not override an existing version unless every existing remnant programs were erased completely. Also, keep in mind that the older disk drive had spaces available to store programs from the older operating system that may have a unique requirement of spaces to perform. Acquiring another alternate operating system at retail may be compatible with the computer only the computer has least available spaces in store for separately engineered system programs. Simply said, each device has a set of requirements to perform with the remain ones on the computer being repaired. Where changing once original part that was connected to several other would require acquiring additionally the same remnant compliment from retail to achieve compatibility standards.
The operating system acquired on the retail market is usually in the form of a disk CD that is simply inserted into the computers drive medium from which restoration instructions are generated to achieve user experiences. For example, inserting an operating system disk CD in the drive of the computer should request either repairing the prior existing version on computer or simply replacing the entire system features. Usually, each acquired disk has instructions on the systems reconfiguration as would be termed. Alternative descriptions of the process are restorations, rebooting of installations of systems programs.
Important notes to be wearisome about when working with computers operating systems includes software and hardware compatibilities where a change may require alteration of the remaining, else a malfunction response would be likely. For example, the operating system is the command interface of the computer. Each operating system has functionalities where for example, the malfunctioning computer may have been designed for office productivity causing the manufacturer to install the compatible requisite program system for such an experience to be achievable. Especially on a computer that requires every functioning parts recognizable for communications to be achieved during user experiences, a change in one significant part that would achieve computer user expectation may not necessarily equate to every component parts usually functionality prior to replacement parts.
Consulting with a computer systems technician to achieve the experience would guarantee an experience of restoration functionalities were the computer user simple retrieves a device at functioning mode soon after repairs are completed. The significance of consulting with experts is several mentionable. First, professional hand tends to perform expectedly on devices. Second, experts are capable of the repairs without gimmicks experienced with alternate persons.
Jan 23, 2011 | Fujitsu Siemens LifeBook E8020 Notebook
Can anyone tell me how can i reset the bios for lifebook S7010D?
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Nov 24, 2010 | Fujitsu LifeBook S7010 Notebook
BLUE SCREEN STOP ERROR AND NO HARD DRIVE SHOWING
Sorry, but there's no real way to troubleshoot this without actually having the device. The problem you describe could be anything from a simple corrupted system32 driver or MBR (master boot record), to a hardware failure. The simplest thing you could try is to boot from your OS installation CD/DVD, reinstall the OS, and re-install your applications. Next would be to re-format the boot drive and restore your data from your most recent backup. Sorry I don't have better news for you.
Aug 16, 2009 | Fujitsu Siemens LIFEBOOK S7010D...
I have replaced my hard drive as the pc was locking up alas this did not repair it is it a problem with my motherboard? its gets so far and locks up it gets fully into windows but then locks as and when it...
I think by locks up you mean the system hangs.Not necessary it could be other than the hard drive if it still hangs after replacement.In this case you should contact the hardware support because the whole system needs to be checked.
Regards
Aug 06, 2009 | Fujitsu Siemens LifeBook S7010D Notebook
Need to replace fan
www.insidemylaptop.com/replace-fan-fujitsu-lifebook-t4200-tablet-case/
i think this site will be enough to know instructions to replace it
Jun 19, 2009 | Fujitsu LifeBook S7010D Notebook
Multibooting
nope not if its in vista u would nee dto dual boot dl alll latest drivers software for vista then mosttime it works on older stuff
Oct 14, 2008 | Toshiba Satellite A135-S2276 Notebook
Lifebook S7010D Fujitsu siemens, power problems.
Does it work connect to the the mains electricity? It could be a battery failure check this first plug to mains see if it works. then come bakc
May 18, 2007 | Fujitsu Siemens LifeBook S7010D Notebook
Fujitsu LifeBook S7010D Notebook Logo
223 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
