Question about Sony Cyber-Shot DSC-P52 Digital Camera
Shutters are locked in half open position???
Shutter on sony cyber shot dsc P52 digital camera will not open all the way. Is locked half open all the time. When I turn camera on it makes a rattleing sound coming from the shutters as it tries to open them. They still will not open and a beep sound comes from the camera for about 20 seconds. The viewer says "turn the power off and on again". Same thing happens all over again.
Any suggestions. The set up setting works and so does the picture folder as they don't need the shutters.
Thank you for any help
  • 4 more comments
  • sparky1971 Nov 12, 2007
    exactly the same fault with mine. i've tried taking it apart but can only release back cover. Scared to force it anymore. I suspect it's the gears that are faulty. Either something in mechanism ie sand or gears are out of alignment. I gutted. I though sony went on and on? Any one got a clues on what to do?
  • Jill12 Nov 13, 2007
    Same problem with the shutters half open with I turn it on, please advise
  • danielle5 Nov 16, 2007
    i have this camera but when i try to take picture and turn it to camera mode it won't power up. the green power light comes on for a sec and shutter won't open. when i have it review mode its fine. it shows picture i have taken. do you have any ideas?
  • Anonymous Nov 26, 2007
    exactly the same problem. thanks for any help
  • Anonymous Dec 23, 2007
    I just started having the same problem as you Danielle. I can view my pictures I have already taken but as soon as I switch the camera back into picture taking mode the camera powers off. When I try to switch it back on ..its on for a second then powers off. Its frustrating. Its been a good little camera all around up until now. :(
  • greenworms Feb 10, 2008
    turn power on and back off
My camera came to life again!, and the shooter no more rattles.
Used info provided by garyjames, and it was helpful.
I'd like to add some details.
Use a jewelwrs srewdrivers set.
1.- To open the camera, you should remove 4 philips screws along the edge of the body (the fourth is hidden behind the memory stick cover)
2.- Withe the screws removed, use a slot screwdriver to help you open the cover.
Take care not to force or mark your camera, as there are no hidden locks.
Be careful with orange flat cable (I did'n disconnect this)
3.- Disconnect the motor cable (connector with red and black wires).
4.- Then unscrew the four philips screws that hold the printed circuir board.
5.- Now lift the complete assembly (board, lens, trigger button).
Use care and the slotted screwdriver again to help you in this.
Be patient as it is not easy.
6.- Now you should see the motor-gear assembly.
Unscrew two screws that hold the unit into position.
7.- Close the shutter blinds manually.
8.- Remove the two plated screws and separate the motor from the gears.
Turn the gears with your finger and I saw the missing tooth referred by garyjames. (I'm also in doubt if this is a design feature or if it is broken.  I didn'n find any residue)
9.- Now the magic:  I rassemble the camera in reverse order (The motor and the gears have some guides that you must align to install properly) and the camera is now working as new.
NOTE: I really don't know exactly what I do (Think that the gear is now working in another teeth), but I think you should try.
Hope this can help.
Posted on Jan 27, 2008
Posted on Mar 16, 2008
Buy a new camera
Posted on Mar 10, 2008
I have same problem. banging the camera didn't solve the problem. took camera apart (requires a little force but can be done without damage-tricky part is the edge along the top face near the button.) took motor apart to discover that one of the gears is missing a tooth. am uncertain as to whether this is intentional (purposeful missing tooth) or the result of wear and tear. anybody know?
Posted on Dec 16, 2007
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Feb 15, 2013 | Sony Cyber-Shot DSC-P52 Digital Camera
Lost manual for this camera. Do you have a instructions for Sony Cyber-Shot DSC-P52 Digital Camera?
Direct link to the PDF manual
For more info link to the sony support site for cyber shot cameras
support site for the DSC-P52
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 30, 2010 | Sony Cyber-Shot DSC-P52 Digital Camera
When I power on the lense cover only partially opens and will not close when I turn the camera off. Sony DSC-P52
The problem could be from simple dust accumulation to a camera drop. If you take it to the service center, it would be an easy fix, and won't cost you much.
Feb 14, 2010 | Sony Cyber-Shot DSC-P52 Digital Camera
When I push the shutter button down, it takes 3 to 4 seconds before the shutter opens to snap the picture. What's with that ?
You need to press the shutter button half-way and allow the camera to lock in the focus before pressing the rest of the way.
Dec 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Self Timer
Hi - You can download the manual from the link underlined in blue below:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 09, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
DSC-P52 Shutter Problem
I have investigated my problem further and basically the teeth on the black cog which opens the lens cover have broken. This a very small component which attaches to the motor, so when you hear the motor, or if you have had grinding noises, it is the mechanism trying to operate the shutter but cannot beacuse the teath won't engage. If you have this probelm all the turning on and off again wont solve the issue. You might be lucky if only one of the teeth have broken but you are only postponing the inevitable which will happen when you least want it to. I have aChristening at the weekend and only hope I can get this sorted by then.
I will need a new shutter mechanism ( don't know the technical terms) but as yet I have to investigate where I can get one. Any suggestions anyone??
Apr legal
Jun 28, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony DSC-P52 Lens Cover Problem
Is there a setting for the lens gear on the DSC-P52?
Jan 31, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony DSC-P52
Take a picture with the camera and download it to your computer. If the picture also shows up black, then this sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Jan 24, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
172 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
