Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
M1522nf firmware - HP LaserJet M1522nf Multifunction Printer (CC372A)
Hp Laserjet M1522nf . my folt i am load 3020 firmware . how to solve this problem. my email id --sarif.sk14@gmail.com
can you tell me you loaded firmware or driver coz they wont accept old or different firmware if you did you need to re install original firmware frim disk (if its in disk ) or download
Jun 23, 2011 | HP LaserJet M1522nf Multifunction Printer...
My hp laserjet M1522nf is showing Firmware corrupt ready 2 download
You need to connect the unit via USB and then run the HP firmware update utility so that the current firmware can be installed. This error is usually caused when a firmware update is interrupted. Current firmware for this unit is 20100902.
Feb 22, 2011 | HP LaserJet M1522nf Multifunction Printer...
I have a problem with me HP M1522nf printer, fax copier. I read one of the solutions but not sure how to update the firmware. Can some one tell me how I go about doing this. I cleared the machine and it...
Its not that difficult, first do you print to this machine? If you do then this will be easier, if you don't then you will need to add this machine as a printer to your PC. Go to HP.com and click Support and Drivers, check download drivers and software. Enter the product number off of the metal plate (on the back of your printer) It will be something like CB543A. This will give you a couple of options choose the printer that you have, select your operation system, scroll down to firmware and download. This is an executable file which means when you "RUN" this product it will send it to the printer. It will give you a prompt to select the printer, select the printer you want to upgrade. hit send firmware. It may take a while on the printer side, don't shut off until it says to. After it finishes cycle power and print a configuration page to make sure it is upgraded..
Sep 15, 2010 | HP LaserJet M1522nf Multifunction Printer...
When i start my printer hp m1522nf mfp printer ,its shown me the erorr your firmware is curropt
Turn the printer off, hook up the USB cable and try making a firmware update, you can find the file for making the firmware update from support and drivers section under www.hp.com, finally turn the printer back on
If this does not fix the problem means that the formatter board is damaged, call 1800 334 51 44 (hp tech support)
Mar 04, 2010 | HP LaserJet M1522nf Multifunction Printer...
How can I speed up printing?
First check if you are able to print self test page faster or at the same speed.
If you are able to print self test page faster than you need to check for drivers and incase if self test page is at the same speed than you can try upgrading firmware of the printer.
As you havn't mentioned the exact speed i cannot confirmed whether printer will speed up or not.
If the printer is already printing at the designed speed than upgrading the firmware will not help.
However upgrading the firmware is always advisable.
Please upgrade the firmware using the link below :
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3442754&prodTypeId=18972&prodSeriesId=3442750&swLang=8&taskId=135&swEnvOID=228
Apr 28, 2009 | HP LaserJet M1522nf Multifunction Printer...
How to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Dec 13, 2008 | HP LaserJet M1522nf Multifunction Printer...
Error messsage on HP M1522nf MFP "firmware corrupt ready 2 download".... how do i fix this?
1. install M1522nf printer driver PCL5 to any usb port. 2. download latest firmware from www.hp.com 3. run firmware utility and select installed printer from drop down menu.
Sep 07, 2008 | HP Office Equipment & Supplies
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
