Question about Kenmore 44102 Front Load Washer
Hot water /cold water
Jams up using drain/spin cycle when using hot wash water. Will not cycle through anything with cold water (fabric softener in chamber). The cold water IS turned on. It just started happining and was fine five years before. Please help
  • 15,935 Answers
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Maytag bravos x econocserve wont go through all the cycles and then you have to select the drain and spin to finish the clothes
You may be over sudsing the machine and it thinks the water is not drain and stops. Run a empty load on a cold water cycle and not hot water. then cut back on the soap. if you use fabric softener the cut back even more.
Feb 01, 2016 | Maytag Washing Machines
Fabric softener ends up around rim of washer.
When you say you've cleaned both parts - have you poured hot water in and seen it actually drain out of the top peice while it was removed from the agitator? Have you poured hot water into the agitator with the top peice removed and seen it drain out of the holes? If not, repeated flushing (of the agitator) and soaking (of the top peice) with hot water as needed until is drains may be required. Until you can get water to drain out of both peices alone, it will work automatically. Once you have the water draining try again with a regular load of laundry and fabric softener. If it still doesn't work...
Since you've cleaned both parts (the non-removable and removeable top portion) of the agitator - it would suggest that the fabric softener dispenser's actuator inside the agitator is not functioning properly. The fabric softener isn't being released in the rinse (or at all really) and as a result of the centrifugal forces during the high speed spin cycle - it is causes the fabric softener to move up the sides of the dispenser and spray out of the top of the agitator onto the rim. This may be caused a mechanical or electrical failure in the washer or washer control. It will continue to work like this until it is fixed - so I suggest that you do not use the dispenser.
You will likely need to have the washer professionally serviced to have it begin working again. You can save the repair costs and either add the fabric softener yourself during the rinse cycle - or use "dryer sheets" in the dryer instead.
Feb 05, 2013 | Washing Machines
I own the Whirlpool duet set with the front loading washer. The clothes comeout with a bad smell. I was told that the washer probably needed to be cleaned. How is this done, and what makes it happen?
Using the wrong kind of detergent in your fancy front loader is a great way to grunge up your washer and impart some oder onto your clothes. And it accelerates the mechanical deterioration of your washer.
2. Using too much fabric softener and/or detergent.
Liquid fabric softener does not break down very well in cold water and the residue collects on the outer tub and basket along with the lint left from the wash. We professionals refer to this accumulated as grunge. Once formed, this grunge collects ever more additional soap, dirt, grease, human waste, mites, , parasites... and then some really bad stuff.
As it turns out, this grunge makes a perfect substrate for microbial life forms. Over some time- not very much time in warmer climates- those little bacterial colonies build up lots of microbial sewage, just like we do until one day you open the door to the washer
Using too much fabric softener will waterproof your clothes. How clean do you think your clothes will get if they repel water inside the washing machine?
3. Doing all your wash loads in cold water only.
Detergents don't dissolve as well in cold water. As a result, cold water washes leave behind more grunge. So... do an occasional wash in hot water. OK, maybe more than occasional. Like, I hope you at least wash your skivvies in hot water.
4. Leaving clothes in the washer at the end of the cycle.
Front loaders don't have as much access to open air as top load machines. Consequently, leaving clothes in the washer for more than eight hours will increase mold and mildew build up.
1. Add one additional gallon of hot water to the unit before sending it into a hot wash. This will raise the water level high enough to remove the Grunge Hiding Behind the Basket
2. Same as 1 but with bleach added to all dispensers. Clean the fabric softener cup with a rag first (bleach will not break up fabric softener since it is introduced in the rinse cycle with the fabric softener).
3. Same as1 and 2 but with a cap full of pine cleaner added to the wash water (NOT the dispenser). Add some old rags (they don`t need to be dirty) and select the extra rinse cycle. The wash action will help remove the accumulated grunge from the components
Once again, make sure you're only using high efficiency (HE) detergents in your front loader.
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
Fabric softener doesn't empty during wash. I use he softener, and don't overfill the basin. The washing machine completes the cycle, but the softener doesn't empty.
my son had this same problem and when we took the dispenser out and checked the hoses they were clogged with semi hardened fabric softener that didn't pass through. they always used a warm wash with a cold rinse and since i told them to use a hot water wash with a cold rinse at least once a month they have not had a problem. hope this helps.
Oct 14, 2009 | Frigidaire Affinity ATF7000ES Front Load...
I have a Samsung SW62ASP top load washing machine. I keep getting chunks of black flaky stuff turning up through my wash. I always empty the in bowl filter, is there another filter?
Aug 05, 2009 | Samsung SW62ASP Top Load Washer
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Water in Fabric Softener Compartment
As for the softener compartment, powder tends to overflow and block the three drain holes. It needs removing and thoroughly cleaning out, i use cotton buds and lots of hot water.
Dec 18, 2006 | Zanussi FS1455W Front Load Washer
Kenmore Front Loading machine, does not drain the fabric softener
We had the exact same situation with the fabric softener not draining and here is how we fixed it. Turn the water off first, then remove the water lines that bring water into your washer. (They are near the top.) There is a screen in the end of the line, do not remove it, but take an old toothbrush and brush the gunk out and clean it as best you can. Do both the hot & cold sides. The screens keep any debris out of the washer, so after a while it collects and slows down the water intake time (has your washer been slow to fill also?) Screw back the lines, making sure to put the hot and cold back as they were originally, then test that they do not leak. Put your washer back in place and viola - problem solved! I hope this works for you, and good luck!
Sep 03, 2006 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
16 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
