Access menu dvr 1600 - Computers & Internet
How can I get the diagram for dvr 1600?
You can download a manual from manuals online at the following address
http://tv.manualsonline.com/manuals/mfg/cyberhome_entertainment/1600.html?p=1
Jun 04, 2014 | Cyberhome DVR 1600 DVD Recorder
Cant install dvr 1600
I HAVE MANUAL FOR SALE (COPY) 7.50 FREE SHIPPING CALL 2095683327 TO INQUIRE
Apr 02, 2009 | Cyberhome DVR 1600 DVD Recorder
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
Mar 31, 2009 | Cyberhome DVR 1600 DVD Recorder
Off site access to view security camara dvr
access the router look for portforwarding and enable port forwarding assign a name to your camera
type in the port your camera use. ex 593
then type the assign IP for your camera ex 192.168.1.6
to access it type in your browser the your public IP ex. 209.45.0.0:593
read your ip cam manual for accesing it.
Nov 12, 2008 | Computers & Internet
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
The clock time is off, how can i change it?
The only way to change this is going thru the menu and you need the control remote. I had the same problem until I found my remote control to fix it
Jan 26, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome dvr 1600 Remote
codes for this dvr are
0714
0816
they don't work for my new remote but everywhere says they are right
Jan 21, 2008 | Cyberhome DVR 1600 DVD Recorder
Need 3 digit remote code for Cyberhome DVR 1600 PLEASE HELP!!!
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600
into a Region Free DVD Player
There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding
CH-DVR 1600 MU
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
CH-DVR 1600 ZU
  3. Press the Red Record button on your remote control
  4. Press the 8 button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 0 button on your remote control
  7. Press the 5 button on your remote control
  8. Press the Red Record button on your remote control
  10. Press the Setup button on your remote control
Jan 02, 2008 | Cyberhome DVR 1600 DVD Recorder
Can't set the clock
try the setup menu on the remote control.
Nov 19, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 1600 DVR Format problem
Heat related.  Google "Cyberhome DVR-1600" "power supply" (with the quotes included) for answers...or look elsewhere in this forum.
Jun 30, 2007 | Cyberhome DVR 1600 DVD Recorder
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
