Question about Electronic Arts The Sims 3 - Seasons Addon
How do i make the blur go away when a sim on sims3 is *****
How do i make the blur that is covering go away
I lost the code for sims3
No, the code is unique to the game and there is no way to retrieve it.
Jun 09, 2014 | EA - Electronic Arts The Sims 2: Pets
My sim is stuck in midair on the sims3 can't play
Uninstall and reinstall the game. Reboot the game
Jan 06, 2014 | Computers & Internet
Sims3 is incompatible
I assume you running it on Windows 7 32-Bit. Now before you trying the tips below, do make sure your computer is compatible and meet the Sims 3 requirement.
The Sims 3 can be run on a PC with Windows XP and Vista, and on a Mac. However, there is no official Windows 7-compatible version. This means that Sims 3 will not install on Windows 7 properly.
To fix this error, you need to run Sims 3 in Compatibility Mode. To do that, simply right-click the Sims 3 icon, select Properties and then select Compatibility. Then check the Run this program in compatibility mode for box and select Windows Vista or Windows XP SP3. The game should work fine.
Nov 17, 2013 | Electronic Arts Sims3 Sims 3 - Pc...
Need help please my new sims3 is corrupt
Such problems occurs when game files and windows are infected due to virus or missing registry entries.
I would suggest to perform a complete scan with a system utility tool Intel Software Partner Reginout.
Also update the drivers that control your PC.
Dec 07, 2012 | Electronic Arts Sims3 Sims 3 - Pc...
I want free download the sims 3. . . what should I do ? can you help me ?
i want to download sims3 but i don't have a link can you give me a link
Feb 11, 2011 | Acclaim The Sims 3 World Adventures for...
My sims3 game launcher says that my sims3 base game is incompatible with the sims3 expansion installed please update it via your game via game launcher. what can i do to resolve the problem?
Hi. I encountered the same problem when I install worlds adventures to my desktop. What solved my problem is to change the value of SKU file. To be able to change the value of that file follow these directions:
1. Go to RUN 2. Type in regedit 3. Open hkey local machine and then software 3. then sims and then sims 3 4. then you will find the SKU file try changing the value from 1 to 7 check if it should match your base game
Hope this helps your problem. Have a good day!
Jan 06, 2011 | Acclaim The Sims 3 World Adventures for...
Were is the registration code on the Sims3 box?
For most The Sims games it is on the back of the cd box cover but in a few others it is located in the instruction manual. Hope this helps!
Oct 18, 2009 | EA - Electronic Arts Sims: Complete...
Sims3
The Sims3 is due to be released on June 2, 2009.
Feb 08, 2009 | EA - Electronic Arts Sims: Complete...
Electronic Arts The Sims 3 - Seasons Addon Logo
10 people viewed this question
Top Electronic Arts Video Game Consoles & Games Experts
 Shayaan Tanwir
Shayaan Tanwir
 TE5LA
TE5LA
Josh Whitehead
Josh Whitehead
Are you an Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
