Question about Refrigerators
Lg multi air flow
Freezer working, fridge not
HVACRH20
  • 237 Answers
SOURCE: Fridge is warm, freezer is cold!
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves no working. Good job trouble shooting!
Posted on Jan 14, 2007
  • 236 Answers
SOURCE: Zanussi fridge freezer
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Posted on Jun 04, 2007
  • 115 Answers
SOURCE: freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Posted on Dec 30, 2008
  • 400 Answers
SOURCE: lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Posted on Mar 10, 2009
  • 38 Answers
SOURCE: we have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Posted on Mar 14, 2009
My LG bottom freezer refrigerator is not cooling
check in the ducting in between the freezer and fridge compartment for obstructions such as an ice ball or collapsed lining
Apr 05, 2014 | Refrigerators
I AM HAVING LG FRIDGE. HOW WILL I CLEAR IT THE MELTING? RECENTLY PURCHASED LG 225 MODEL. HOW WILL MAINTAIN THE FRIDGE? HOW WILL SAFE?
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | LG LRBN20520 Bottom Freezer Refrigerator
Freezer is icing up
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 18, 2011 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Sep 26, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Dec 31, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
LG will not defrost motor making a noise like ice hitting it
I had this issue as well, techs replaced the control board and problem solved. Mine was done under warranty during the first year, hope yours isn't too expensive.
Dec 29, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Changing panel display from farinheit (sp?) to celcius
Hold the colder button for the fridge and the colder button for the freezer both for about 3 to 4 seconds. It should change to C.
Dec 25, 2007 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Freezer working fine, but Refrigerator no longer cooling
Sounds like there's an airflow problem to the top section. Things that cause no cold air to the top fridge section are... frozen up coils completely blocking most of air flow (defrost cycle not working), evap fan not working to blow air up to fridge, air control dampers in fridge closed or not working properly, or frozen air ducts supply/return. Pull the whole drawer out the bottom and take the rear inside back off to expose the coils. If they are frozen solid the defrost t-stat or defrost timer could be bad (heat element not usually bad). If there is a nice white frost all over evenly then that's OK. Check that the fan is running when the compressor is running to blow the air up and that there are no blocked air ducts, etc. If all that is good, check if you can feel good air flow from the upper vents with the lower door closed (that shows there is no blockage and the fan is running).
Jan 06, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
10 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
