Question about Vehicle Parts & Accessories
Need to change a headlight on 07hondajazz - Vehicle Parts & Accessories
    New Friend:
    Problem Solver:
  • 18 Answers
You will need 2 things...a flathead screwdriver and plenty of patience. To access the left bulb, you will need to turn your wheels to the right. You will need to remove the clips that hold the plastic fender well in place just one or two depending on how much room you need. pull the plastic part down and you will be able to see the back of the headlight assembly. Unplug the headlight electrical plug, take note of the rubber seals position, then remove it. you will see a metal clip holding the bulb in place. Push in slightly and slightly up to release the old bulb. place the new bulb, make sure not to touch the glass part of the bulb with any part of your skin. Don't worry, the bulb will only go in one way because of the tabs on it. reset the retaining clip. Be sure to install the rubber seal in the same position it was removed...make sure it is sealed all the way round. Reattach fender well with the clips you removed. You are ready to change the right side. Turn the wheels to the left and repeat the process. Take your time and it will be a smooth job. I would expect the first time to change both bulbs to take 40 minute minimum. I hope this helps.
Posted on Jan 03, 2015
How to change headlight bulb in 2003 Acura 3.2 CL
Nick, To see how headlight bulb is changed, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Replacement How to replace install fix change hid head light ballast...
Headlight Change 1999 2003 Acura TL 1999 Acura TL 3 2L V6
Acura TL Headlight Replacement WITHOUT removing the bumper
Aug 06, 2016 | 2003 Acura 3.2CL
Front headlight need to be replaced
Please see the attached link for step by step instruction on how to change a headlight on a 2004 Trailblazer.
http://www.ehow.com/how_2117391_replace-headlights-trailblazer.html
Feb 20, 2011 | 2004 Chevrolet TrailBlazer
I need to change the low beam headlight bulb
  1. Remove headlight mounting bolts and nut
  2. Remove assembly
  3. Install headlight assembly (with new bulb)
  4. Replace/tighten headlight mounting bolts and nut
Oct 30, 2009 | Hyundai Motor 2003 Elantra
Need picturss on how to change headlights for 2005
if you have a owners manual its in there, if not there is a pin and a screw on top on headlight assm. you take out and assm. pulls out to access headlight and turn signal bulbs.
Oct 13, 2009 | 2005 Chevrolet Uplander
How do I change the headlights
Headlights , tricky , but you need to remove the front bumper to get acces to the headlights
Jun 19, 2009 | 2004 Jaguar X-Type
How do you change the drivers side headlight assembly?
You need to remove the bumper assembly to remove the headlight.
Oct 14, 2008 | 2003 Nissan Altima
Replace front head lihgt bulsbs on 350 z
you should be able to access the connector and bulb without removing headlight assembly. lift the hood and you should see the connector behind the headlight.
Aug 29, 2008 | 2003 Nissan 350Z
Changed passenger side headlight bulb, now unable to adjust or align head lights
Changing the bulb should not have affected the housing adjustments.
The bulb is just inserted into the headlight housing. The adjustments on the headlight housing is what adjusts the alignment of the headlights.
Did you maybe not get the bulb not seated correctly in the socket? Or didn't get the socket not seated correctly into the housing?
Aug 12, 2008 | Ford Focus Cars & Trucks
Vehicle Parts & Accessories Logo
42 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
