Question about Hitachi 50VS69 50" Projection HDTV
Hitachi 50vs69. Suddenly shut off and now when you try and turn it back on a weird high groaning sound comes from inside the TV. The blue power button blink as do the two red ones underneath it. Nothing is on the screen. The TV is my sister's and she will be home from Vacation this week. I'd like to get it working soon. Any ideas out there?
  • 668 Answers
As a guess, I would check to see if the Lamp fan is binding or being obsructed.
Hope this helps,
Skyassoc
Posted on Jun 30, 2009
Lamp light blinking red
From your description it sounds like the lamp bulbs needs to be replaced.
You need one of these:
http://www.amazon.com/Hitachi-50VS69-Watt-RPTV-Replacement/dp/B006C58MOI
NOTE: DO NOT TOUCH THE GLASS PART OF THIS BULB. The smudges from your fingers can show up on the image projected onto your screen and make things look blurry.
Once you have the new bulb then turn off the TV and unplug it. On the back panel there is a rectangle on the left with a screw holding it on. Use a philips head screwdriver to loosen the screw then slide the rectangular panel to the left and pull it off. Inside will be the old lamp bulb. Use the screw driver again to remove the screw holding the lamp bulb in and pull the lamp bulb out (it may be hot). Insert the new bulb and then screw it back in. Place the panel back on and screw it back in as well. Make sure the screws are tight or the TV may not turn on. You can now plug the TV back in and turn it on. If done correctly this should resolve the issue.
May 07, 2013 | Hitachi 50VS69 50" Projection HDTV
The Tv turns on but there is no picture and than it sounds like a cd spinning inside than it shuts off
Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Was the fan was running ok? You can clean it w an air pressure can. Part # is ux25951 for lamp you can find it here: http://www.discount-merchant.com/SearchResults.asp?Search=UX25951+?Click=48173 Have a blessed life!
Nov 18, 2009 | Hitachi 50VS69 50" Projection HDTV
I keep getting a blue bloge driping down in screen of my 50" hitachi tv
It sounds like you have a Optical Engine that needs to be replaced. Due to the cost of the repair, I recommend you to call Hitachi at 1800-HITACHI and see if they would be willing to help with repairs and also help in locating a Service Facility near you to confirm the symptom.
I hope this helps,
Skyassoc
Oct 24, 2009 | Hitachi 50VS69 50" Projection HDTV
My hitachi 50VS69A tv shows the picture green.
A green image is usually due to a lack of red or especially blue. the problem is becoming all too common with hitachi lcd projection sets. what happens is that one of the lenses in the optical block (or light engine) starts to burn or discolor due to overheating because of a blocked air filter causing poor air (cooling) circulation. Nothing can be done when the damage is too far gone except to replace the light engine-at acost that makes it not worth repair. if the damage is minimal than to reduce further damage the air filter should be replaced. Light engine needsto be removed in order to replace the air filter.
Sep 04, 2009 | Hitachi 50VS69 50" Projection HDTV
Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Aug 31, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi 42HDS69 42 in. Plasma... Problem
Describe the past - How did it fail? One day or acting up for a while? Could be a weak power supply - a bad capacitor on a power supply too. Look for popped up capacitor top inside.
Apr 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 51F500 (Two separate problems?)
My guess is that the sound you heard was that of some High Voltage discharges that could have fed back and damaged some semiconductors including the microprocessor itself. Since it could be a very expensive repair, I would be very tempted to look around for a new HDTV by JVC or Toshiba. Hitachi has slipped a notch or two in recent years according to my experience.
Jan 25, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 51uwx20b blue hue on screen
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible
http://www.digitalhome.ca/forum/search.php
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 27, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Televison & Video Logo
153 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
