The eee pc goes through boot startup but will not load windows xp only shows flashing prompt
    Problem Solver:
  • 8 Answers
Need to put windows bootable CD in the cd drive and then restart computer.
Posted on Jun 19, 2009
Screen stays black after boot up
Use Recovery Console:
When a Windows XP boot problem is severe, you'll need to usea more drastic approach. The Windows XP CD is bootable and will provide youwith access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
Use system utility software like RegInOut after restarting windows.
Jan 01, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My Eee pc notebook is booting in safe mode.
You need to look at the boot loader.
In WIndows XP:
  • Right click on My Computer and choose Properties.
  • Under the Advanced tab, click on Settings under Startup and Recovery
  • Under System Startup click Edit
  • Make sure to remove /safeboot from the end of the Operating Systems line
  • Close Notepad and choose Yes to save
  • Restart the computer and it should go straight into Normal boot mode
Jul 24, 2011 | ASUS Eee PC 1000 Notebook
My asus eee pc gets to the window s xp loading page and continues to reload with out going further. Any suggestions?
If your system is stuck on the Windows Loading Screen you can try to boot using Safe Mode by restarting the computer and tapping F8 while it is booting. When it successfully load the Operating system you can disable some startups on the machine. Click on Start then click on RUN, type MSCONFIG on the dialog box located on the lower left of your screen. Then Click on the SERVICES tab. Put a tick on Hide All Microsoft Services then click on Disable All button. Restart the computer see if it will works. If not then you need to Reinstall the Operating System to your machine.
Thanks for using Fixya.
Jan 27, 2011 | ASUS Eee PC 900 PC Notebook
I have an Acer Aspire One AOD250 that will not load windows xp normally. It will only load in safe mode. When I turn on the computer it just hangs on the Windows XP page. What can I do?
Boot into Safe Mode with Command Prompt (F8 during startup)
run this command once it's loaded: chkdsk /r
Let me know what happens after normal startup again.
Oct 28, 2010 | Acer Computers & Internet
Wont load the os, it sticks on the windows xp page
1. Press F8 as it's booting and select 'go back to last working configuration'
if that doesn't work, go to step 2.
2. Press F8 as it's booting, and choose 'Launch startup repair' (I'm assuming you have Vista/Windows 7). If your on XP, you need to do a windows repair which is described here: http://www.michaelstevenstech.com/pdf/XPrepairinstall.pdf
Jul 02, 2010 | ASUS Eee 4G Notebook
HOW DO U REBOOT AN ASUS EEE PC 900 WITH WINDOWS XP AND NO CD ROM
Hi! Please try this, restart your pc. During the start up press F9, it will restore it. Hope this helps and have a good one!
May 17, 2010 | ASUS Eee PC 900 PC Notebook
Eee pc asus 904hd xp, corrupt registry
you can install windows XP from a Pen Drive/Flash Drive provided that your motherboard supports booting from USB drives.
Further detailed instruction can be found here.
http://www.troublefixers.com/solved-install-windows-7-from-usb-pen-drive-with-iso-image-without-cd-dvd-drive/
Oct 08, 2009 | ASUS Eee 4G Notebook
I have a eee asus laptop. I cannot startup the window at all. The pc show this message; "Windows could not start because the following file is missing or corrupt C:windowssystem32configsystem " how can i...
you have to fix error on harddisk.
If you have winrecovery disk you can boot your computer with winxp recovery disk then boot computer with recovery disk then type in recovery console prompt "chkdsk /r" then pres "y"
then it fix error on harddisk.
Jul 13, 2009 | ASUS Eee 4G Notebook
Desktop theme changes at startup
That's not supposed to be a problem... When you log in to your account windows loads your personal settings, as well as other programs, so it's supposed to take time. Windows probably has the theme set on default so it would show that while your settings are loading. That or you've got a virus... But... if you think your computer is unusually slow then that's a different problem. Try cleaning up your hard disk space and doing other sorts of stuff, like scanning for viruses to make it run faster.
Jan 18, 2009 | ASUS Eee PC 1000H Laptop
Windows XP fails to load and Computer will not start up.
Boot from startup floppy disks or CD-ROM, choose repair option during setup, and run Recovery Console. When you are logged on, you can run FIXMBR command to fix master boot record. This should solve your problem.
Sep 20, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
392 people viewed this question
Alun Cox
David Payne
David Payne
