Question about Carrier Heating & Cooling
Auto shutdown 10 SECONds shutdown circuit board and door i want to order my needs like a circuit board like this P-SERIES 42QP8A5501C
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Plug it in, it starts,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 12, 2010
rylee_smith
  • 8619 Answers
SOURCE: After 3 or 4 hours
Hi
Thanks for using FixYa. 10 blink error in your Plasma TV means that the A Board has gone bad and should be replaced. You are right, this issue is caused due to overheating and the capacitor(s) goes bad causing these issues. You can also open the back of the unit and check the main board (A Board) first for any blown/bad components/capacitors as the board itself is around $250. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 10, 2010
  • 6468 Answers
SOURCE: Kohler Courage 20hp backfires 10 seconds after shutdown
the solenoid on the bottom of the carb may not be working or not sealing and gas drips passed the valve
Posted on Aug 12, 2012
SOURCE: CIRCUIT BOARD
http://www.appliancefactoryparts.com/dehumidifiers/goldstar/allmodels.html
Posted on Aug 23, 2012
Hi, i have an APC UPS with model BE 500R PH how to bypass the auto shutdown of it?
On mine, until an electrical storm, was controlled through my computer via USB. Now, it shuts down in 5 seconds. I'm sure it's the thermistors, but I don't have time. Also, check for timing circuits.
Apr 26, 2015 | APC Computers & Internet
Whats the codes p0685 an p0688 on a 2004 chrysler pacifica mean
P0685 CHRYSLER - Auto Shutdown Relay Control Circuit Failure
Short or open in Auto Shutdown (ASD) relay circuit
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible Causes
- ASD relay circuit is open or shorted
- Failed Auto Shutdown relay
- Failed ECM
Tech Notes
Check all the ECM fuses, if the fuses are OK try replacing the ASD relay.
P0688 CHRYSLER - Auto Shutdown Relay Control Circuit Low
The Front Control Module (FCM) has detected the supply voltage below an acceptable value
Symptoms
Possible Causes
- Failed ECM
Tech Notes
Dec 29, 2014 | 2004 Chrysler Pacifica
What does the codes 0627-0681-0680-0688 on 2006 chrysler sebring 2.4 16 valve 4 cly
Hi there:
DTC P0627 CHRYSLER - Fuel Pump Relay Control Circuit
ECM (Engine Control Module) detected an open or short in the fuel pump relay circuit
Possible causes
- Fuel pump circuit open or short
- Fuel pump circuit poor electrical connection
- Faulty fuel pump relay
- Faulty fuel pump control module (if applicable)
DTC P0680 - Cylinder 10 Glow Plug Circ, and,
DTC P0681 - Cylinder 11 Glow Plug Circ
The Engine Control Module (ECM) has detected a fault in the cylinder #10 or #11 glow plug circuit.
Possible causes
- Cylinder #10, or #11 glow plug circuit is open or shorted
- Faulty cylinder #10 or #11 glow plug
- Faulty glow plug module Help with this
DTC P0688 CHRYSLER - Auto Shutdown Relay Control Circuit Low
The Front Control Module (FCM) has detected the supply voltage below an acceptable value.
Possible causes
- Failed ECM
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 03, 2012 | Chrysler Sebring Cars & Trucks
TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Apr 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Model MAH4000AWW door leaks. Has hole worn in it.
You will need to go back to your madel number. Look you a series or rev number. 10, 42 or 53. It will have one of these numbers there. This will tell you which part your looking for.
model-number-tag.jpg Please rate solution if helpful. Thanks
Aug 24, 2009 | Washing Machines
TV shutdown for roughly 10 - 15 minutes after being on for hours
Yes the vertical circuit will shutdown the set if theres a problem with the deflection circuit. This model has a history of leaking CRT coolant on the boards near the vertical IC destroying the solder and actually eating through the circuit board. Check the area near the Vertical output IC for signs of coolant leakage or solder cracks.
Mar 11, 2008 | Mitsubishi VS-50607 50" Rear Projection...
No audio or video
Your set is going in to protective shutdown something in the start up voltages. This is something you would need a manual for. I have a linkt that has the start up circuit and shutdown diagnosing for your set if you would like me to post a link let me know
Mar 11, 2008 | Toshiba TZ50V51 50" Rear Projection...
The PT-53WX52
This looks like a problemcausing the shutdown circuit to trigger. The shutdown circuit prevents the TV from being further damaged by an overcurrent or overvoltage event. The overcurent event is caused by a component being over driven and thus it decreases in resistive value causing an increase in current, The over voltage event is caused by a component increasing in its resistive value either due to an open circuit or decrease in the component's conductive area. In any event the shutdown circuits senses these eventes and shuts the TV down to prevent futher damage.
I would suggest taking the set to your local TV repair shop.
I hope this helps,
Shuttle83
Nov 16, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Stops in the middle of the wash cycle
HAVE THE SAME PROBLEM WITH THE SAME MAYTAG MODEL DISHWASHER. THE PROBLEM IS WITH THE CONTROL PANEL ASSEMBLY HAVING ONBOARD COMPONENTS NOT SODERED CORRECTLY TO THE MAIN CONTROL BOARD. THESE LOOSE OR COLD SOLDER CONNECTIONS HAVE TO BE REHEATED,RESOLDERED WITH A SOLDERING IRON . THE ON BOARD COMPONENTS THAT I WAS HAVING PROBLEMS WITH WAS THE BLUE BOX LOOKING COMPONENT,SOLID STATERELAY, AND THE RAISED RESISTOR,HAS COLORED BANDS AROUND IT. THESE COMPONENTS ARE LOCATED ON THE LEFT SIDE OF THE PRINTED CIRCUIT BOARD FACING THE DISHWASHER LOOKING OVER THE TOP. TO MAKE THE REPAIR, TURN OFF THE CIRCUIT BREAKER TO THE DISHWASHER, OPEN THE FRONT DOOR AND REMOVE THE 10 SCREWS THAT HOLD THE DOOR TOGETHER. THIS WILL ALLOW ACCESS THE THE CONTROL PANEL.. IF YOU DO NOT FEEL QUALIFIED TO MAKE THIS REPAIR USING A LOW WATTAGE SOLDERING IRON YOU CAN ORDER THE CONTROL ASSEMBLY LED FROM PARTSSELECT.COM. FOR ABOUT 100 DOLLERS. THEY ARE ABOUT THE CHEAPEST. FOLLOW THE ON SCREEN INSTRUCTIONS TO ORDER THIS ASSEMBLY.THE ASSEMBLY PART CAN BE FOUND IN THE CONTROL PANEL PARTS ILLUSTRATION. WHEN SEARCHING FOR THIS PART YOU MUST SEARCH USING YOUR DISHWASHER MODEL NUMBER. THIS INFORMATION CAN BE FOUND ON THE LEFT SIDE OF THE TUB OF THE DISHWASHER AFTER OPENING THE FRONT DOOR. ALSO, WHEN LOOKING FOR THIS PART IT WILL BE LISTED TWICE,AS SERIES 10, OR SERIES 24. YOU MUST ORDER THE CORRECT SERIES. THE SERIAL NUMBER ON THE SAME PLATE THAT THE MODEL NUMBER WILL PROVIDE THIS INFORMATION. IF YOUR SERIAL NUMBER STARTS WITH A 10 ORDER THE SERIES 10, WITH A 24, ORDER THE SERIES 24. WHILE YOU ARE ORDERING CHECK YOUR LATCH HANDLE, THE SIDE PIN WAS BROKEN MAKING IT HARD TO OPEN THE DISHWASHERS FRONT DOOR. ONE OTHER THING YOU MIGHT WANT TO CHECK IS THE FLOAT SWITCH OPERATION. MINE WAS STICKING. TO ACCESS THIS REMOVE THE 4 SCREWS THAT HOLD THE PANEL .THE FLOAT SWITCH IS LOCATED TO THE LEFT.WITH THIS PANEL REMOVED CHECK FOR ITS FREE NONSTICKING OPERATION. IT CAN BE DISMANTLED AND CORRECTED. A SERVICE SHEET IS LOCATED, ATTACHED TO THE INSIDE OF THIS PANEL.IT HAS GOOD TROUBLESHOOTING INFORMATION INCLUDING A AUTOMATIC FUNCTION TEST.THIS TEST PROVIDES A DIAGNOSTIC ANALYSIS THAT WAS EXTREMELY HELPING FOR ME TO DETERMINE MY PROBLEM AND CORRECT THE MALFUNCTION CONSIDERING I AM NOT A APPLIANCE REPAIRMAN. I HOPE THIS INFORMATION IS BENEFITICAL. REGARDS.
Jan 03, 2007 | Maytag 24 in. MDB9150A Built-in Dishwasher
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
