Question about Refrigerators
Error code ER CF on my LG Side by Side Fridge Freezer
Hi, I hope someone can help me. I have an LG side by side fridge freezer, model is: GR-B206GTQA. An error code reading ER CF has appeared on the front display. I looked for potential caused on the internet and wrongly assumed that replacing the condenser cooling fan motor would solve the problem. The fridge freezer seems to be cooling well enough but the back of the appliance is hot because the cooling fan isn't running. The original fan motor that I replaced worked intermittently after cleaning the thick dust from the fan and surrounding area then it would stop completely, that is when the error message would appear. The new motor is the correct one for this model and works for several minutes before stopping and the error ER CF has returned! If i unplug it and leave it for a few hours then plug it in again the fan runs as before. I would greatly appreciate any help. Many Thanks Lee
  • 4 Answers
SOURCE: Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech.
Posted on Aug 15, 2008
SOURCE: LG Fridge Freezer display has CF error code
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
Posted on Dec 09, 2008
aasc
  • 1606 Answers
SOURCE: GE Side-by-Side model #GSSWGPDWW freezer stopped working.... help
First of all , a GE , GSS model has no defrost timer , or calrod heater . If your ready for a little work , diagnosing , here we go .
You have a defrost problem , so , pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it .
Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR55X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater .
To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , and when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and when to cycle off due to set temperature reached .
Posted on Dec 11, 2009
  • 135 Answers
SOURCE: Side by side , fridge & freezer both stopped
did you feel the compressor runing?if not , need to check have power to the compressor. if power ok. i think the start relay or capacitor is bad. but make sure the condensor not drity. sometime it cause the problem. good luck
Posted on Jan 09, 2011
ZJLimited
  • 17970 Answers
SOURCE: Subject: 'New' Kenmore bottom freezer
This is a bad fan motor (click here like a sample replacement) inside the back wall of the freezer, you will need to replace it with part number that could look it accroding with your model. You can order the parts you need from the following places:
- http://www.apwagner.com/
- http://www.repairclinic.com/
- http://www.searspartsdirect.com/
So, according with your comments, if your device has few months, before to take off some part, I suggest contact your dealer or technical service keeping under warranty service.
Hope this helps.
Posted on Mar 09, 2011
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Hi, I have an LG side by side fridge/freezer model no: GR-B206GTQA that I have recently purchased second hand. When I plug the unit in it runs ok for approximately 10 minutes and then the condenser fan...
You probably need to replace the fan blade or housing. They are available online and are not too much more of a job than the fan motor was. It was likely not the fan motor giving you the problem since they are rather strong.
Apr 22, 2014 | Refrigerators
LG GR-B206GTQA Fridge Freezer ER CF Error Code
The fan is almost certainly run by a sensor in the condenser. If it doesn't get hot enough, the fan doesn't run. Sounds like short of gas. Try wiring the fan to the compressor live and see if it runs all the time then.
Apr 18, 2014 | Refrigerators
I have a lg side by side with a fault code of dh er and the evap. is frosted up. I would be happy to get any information on the problem.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | LG LSC26905TT Side by Side Refrigerator
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Error code er ff.how do i fix this? freezer is still freezing but fridge is warm.
The error code appears when there is an abnormality of BLDC FAN Motor for Freezer. It circulates cold air from the freezer to the fridge to allow cooling. Check the motor wiring harness for poor connections. If the motor is not working at all, you need to replace it.
To remove the fan and motor assembly:
  1. Remove the freezer shelf. (If your refrigerator has an
    icemaker, remove the icemaker first).
  2. Remove the plastic guide for slides on left side by
    unscrewing phillips head screws.
  3. Remove the grille by removing one screw and pulling the
    grille forward.
  4. Remove the Fan Motor assembly by loosening 2 screws
    and disassembling the shroud.
  5. Pull out the fan and separate the Fan Motor and Bracket.
  6. Replace fan motor assembly in reverse order.
Oct 27, 2009 | LG LFX25960ST Stainless Steel French Door...
FF error code
The ER-FF problem that you have is: ERROR -FAN FREEZER so it means that you have a problem with maybe the fan motor or if it's a bottom mount freezer maybe ice built up on the fan motor so it's blockin the fan motor.
Hope i helped u a little bit ! :)
Francois Pelosse
Jan 19, 2009 | Freezers
Dec 07, 2008 | LG French Door Cabinet Depth Refrigerator...
Kenmore Elite Refrigerator error er dh
Great advice from medeer, I had the same ER DH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel. I accessed it by removing the freezer door, all components inside the freezer, and the tracks mounted on the sides of the freezer. Be careful when removing the white panel because a fan is mounted to the left side of the white panel and plugs into the back left side of the freezer compartment.
Found the green technical data sheets under the refrigerator in a small plastic bag near the front.
My refrigerator is 20 months old, just a few months past the warrentee,
Feb 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
