Question about Radio Communications
Need new fuel tank
Where can I get a fuel tank
    Master:
  • 623 Answers
Most radios don't use fuel tanks. Need to know what brand and model you have.
Posted on Nov 07, 2014
Why is there no fuel returning to my fuel tank
23 psi is no where near enough to run let alone get past the regulator so no gas will return to the tank. Need 40 to 50 psi to run. So either you have a fuel leak could be in the tank or a line. Or the pump is junk
Mar 04, 2018 | Cars & Trucks
Harley fuel tank quick disconnect no leakage from tank
No leakage from the tank is good, is there leakage from the quick connect, if so is it with the fuel line connected or disconnected? In any case you will need new o-rings or a new quick connect. A new quick connect would rerquire tank, fuel pump etc disassembly
Jul 14, 2014 | 2011 Harley Davidson FLHTK Electra Glide...
How to replace fuel module regulator
to replace the fuel pump module.first you need to relieve the fuel system pressure.turn off radio first, then disconnect the negative battery cable.drain fuel from fuel tank.then then safely raise support car on jack stands. make sure sitting on solid level ground then remove the fuel charcoal canister hoses and vent line remove disconnect fuel pump. disconnect fuel pump electrical connector and remove fuel filler hose from fuel tank then remove the fuel tank from the vechicle.the heat shield and the rear exhaust system may have to be remove if you problem dropping the fuel tank.once fuel tank dropped you need snap ring pliers to remove the fuel pump module retaining ring.disconnect the fuel pump sending unit.disconnect the fuel pressure sensor and fuel pump module electrical connector .if you need help to replace the fuel level sending unit.you need a haynes repair manual.it has instruction how to remove and replace the fuel level sending unit.but most of the time the whole new fuel pump module come with new fuel level sending unit.if you are replacing fuel pump.when done put every thing back visa versa. be very careful working around gasoline and fuel tank.dont smoke.becareful dont make no sparks with wrenches when removing gas tank.wear safety glasses and have a helper at all times. dont work under vechicle by your self.
Apr 11, 2011 | 1999 Oldsmobile Alero
How do i remove the fuel pump?
To remove the fuel pump you will need to drop the fuel tank itself. Simply remove the filler hose from tank, and using a bottle jack with a block of wood on top, center jack under fuel tank near the center. You will need someone else to help with the removal if there is more than half a tank of fuel. Once the four bolts are removed. slowly lower the tank with jack and remove wires from the tank. Completely remove tank from under vehicle. Using a screwdriver and hammer, carefully tap the metal ring (or remove clips if plastic) and pull the pump straight out. When installing new pump, be certain that a new screen is purchased and attached to bottom of fuel pump assembly. Insert new assembly through top of tank and replace the retaining ring or clips. Then, in reverse order, install the fuel tank, reattaching wires before fully raising tank. Reinstall filler hose, be certain tank bolts are tight, and you are done. FYI...some fuel pump assemblies come with a new screen included. Be certain that new pump has screen included. If not, purchase screen. If the screen is not replaced, it will void the warranty on new fuel pump. Hope this helps you out.
Feb 27, 2011 | 1991 Dodge Ram 150
Hole in fuel tank...went to remove what I thought was a drag plate but it seems to be attached to the tank? Is that true - do I need a new fuel tank or is this plate separate from the tank? This plate is...
you need a new fuel tank. the plastic and the metal shields act as a heat barrier and are part of the tank. you should never remove any of the shields or plates it can easily cause a fire
Jan 22, 2011 | 1998 Ford Escort
The fuel pump is failing, where is it located on a 2004 Jetta GL 1.8 sedan?
Hello
Fuel pump is located in the fuel tank.
you need to drain the fuel tank
and then remove and let the fuel tank down away from the floor of the car there will be 2 fuel lines to disconect too
once the tank is down in the center top of the tank there is where the fuel pump is at there is a ring that holds the fuel pump into the tank this comes off by rotating to the left
the old fuel pump comes out
clean off where the new fuel pump goes
in stall the new pump and ring
raise tank
install lines and strap
add gas
good to go
Jul 18, 2010 | 2004 Volkswagen Jetta
1989 lesabre fuel tank replacement help?
Yes, you will need to swap everthing over to the new tank. The new tank will just have holes for the components
Jan 21, 2010 | 1997 Buick LeSabre
Need a new gas tank censar wht should i do
Most sensors are in the fuel tank. This should left to a repair shop since the fuel tank will have to be removed.
Nov 15, 2009 | 1997 Oldsmobile Bravada
The fuel lines have rotted out of the edger gas tank. How do I fix or do I need to replace entire tank with new fuel lines?Since there are no male fuel line connections exiting the fuel tank and just two...
no you can buy replacement fuel line but you must reconnect the filter in the tank that line goes to the bottom of the carby then out the top of the carby to the inlet on the primer then out of the primer and back to the tank.
Jul 12, 2009 | Poulan Pe550 Gas Edger
93 lexus LS 400 how do I replace the fuel pump?
You will have to remove your back seat to gain access to fuel pump. Fuel tank is located in trunk. No need to take fuel tank down.
Dec 07, 2008 | 1993 Lexus Ls 400
Radio Communications Logo
29 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
