Error code 50c
Iam getting cartridge error 50c on my Lexmark 6150
What is it and how do I fix it?
  • s_e_brown Jun 19, 2009
    I did the procedure twice, once with a hand wipe and the other with isopropyl alcohol on a tissue.
    I still get the same error code.
    Sam
  • s_e_brown Jun 20, 2009
    Thanks for the info.
    I tried cleaning the cartridges twice and I was replacing the black ink cartridge.
    The color cartridge was supposedly half full, but when I tried replacing the color cartridge, the error code went away and now everything is fine.
    Next time suggest changing both cartridges as a first solution.
    Sam
  • 10,515 Answers
Cartridge Error 50C
Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
If not, upgrade the software, it might fix the issue.Unless call Lexmark.
Thanks for using "Fixya".
Posted on Jun 19, 2009
    President:
  • 2,187 Answers
Here are the steps:
  1. turn off your printer then unplug i
  2. remove both cartridges get like a wet baby wipe or something similar let them sit on it for 10 secs
  3. Gently wipe the front piece and take the same wipe and wipe the heads in the printer as well. You have to sort of dab them and dont wipe and let dry for about 10 secs or more.
  4. Then you have to put them back in (note you will need to move your cartridges over to where load position by hand to and back)
Says erorr 50c on my lexmark x5150
The 50c error indicates a problem with your cartridge. This article will help you determine and resolve the issue: Cartridge Error 50C and Other Errors on the Lexmark X5100/X6100 Series LCD Screen.
Apr 20, 2011 | Lexmark X5150 All-In-One InkJet Printer
Cartridge error on Lexmark 6150
Try first unplugging power and usb cable.
Removing cartridges, putting them back and restarting.
Aug 22, 2008 | Office Equipment & Supplies
Cartridge error 50c
The Cartridge error 50c indicates that the printhead(s)/cartridge(s) has shorted. Follow troubleshooting steps available at http://bit.ly/8Zf7ef. If error continues even with brand new genuine Lexmark cartridges, contact Lexmark technical support for assistance. Thank you for choosing Lexmark.
Sep 20, 2010 | Lexmark X6170 All-In-One InkJet Printer
Errir 50C
Try these solutions from Lexmark online support: (apparently one of your print cartridges has shorted)
Lexmark X5150 Error 50C
Jan 09, 2010 | Lexmark X5150 All-In-One InkJet Printer
Won't print reads error code 50c
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 31, 2009 | Lexmark X6150 All-In-One InkJet Printer
I have a Lexmark X 6170 all in one printer and I get error 50c
Oct 20, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark 6100 cartridge error 50c
Are you using a factory "New" Lexmark cartridge?
Lexmark does not support the use of refilled cartridges or third party cartridges in their products.
Lexmark considers this to be Product Tampering and will void the printer' warranty.
Don
May 11, 2009 | Lexmark X6100 Flatbed Scanner
6150 Lexmark
is printer Cartridge new? if now try to purchase new cartridge. If it doesnt work your print cartrige is the problem.
Jan 17, 2008 | Office Equipment & Supplies
Computers & Internet Logo
Alun Cox
David Payne
David Payne
