Question about Acer AL1916W 19" LCD Monitor
I power on my acer p201w monitor it comes on for a second or two then says no signal
5 Suggested Answers
  • 74 Answers
SOURCE: Acer Monitor Doesn't Receive Signal From Computer
can you test your monitor on another computer to verify the monitor is at fault? If the monitor is at fault its time for a new one, factory warranties on monitors are usually 1 year unless you purchased an extended warranty.Otherwise repair is usually more costly than buying a new one.
Posted on Dec 26, 2007
  • 23 Answers
SOURCE: Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Posted on Oct 28, 2009
budmrtn
  • 11361 Answers
SOURCE: the green power light comes on, but the monitor
Check for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 03, 2010
budmrtn
  • 11361 Answers
SOURCE: I have an Acer Monitor AL2216W and it will come on, the Acer name appears, then no signal and then the green light goes to orange. Is this the power supply or what?
It will go into sleep mode if it does not detect the signal from the PC. Try is with other PC first, also make sure the cable is seated properly.Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Here is the inside of your monitor:
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL2216W/
Posted on Jan 21, 2012
Acer p201w monitor
go to this link should help you out.... how to set display Acer p201w monitor Google Search ...There is no difference in changing the display on an Acer monitor and on a monitor from another company.
  1. Access the desktop of your computer and right click the screen. ...
  2. Click on the "Settings" tab that is on the top-right corner of the "Properties" window. ...
  3. Adjust the resolution and color to your preferences.
How Do I Change the Display on an Acer Monitor? ' It Still Works ...
Oct 24, 2017 | Computers & Internet
Just today when watching a movie my monitor will go blank and the light at the bottom which is white when on will go dark and then turn orange like it's been turned off then about 20-30 seconds later it...
When the power saving options of the computer is turned on, after particular time the signal stops to the monitor and the orange light will come on, once you move the mouse or press keys on the keyboard, the cpu comes back from the power saving mode, the signal passes on to the monitor and there will be display.
Sep 05, 2010 | Acer H233H bmid Monitor
No Signal
yes start the computer then keep pressed the key F8 untill the display comes then hightlight the option last good known configuration and select the problem will be solved
Mar 06, 2010 | Acer 22" X223w LCD Monitor
Acer monitor AL1706 Power On problem
You are more likely to have bad capacitors problem in the power supply, inverter circuits. I would look for bad caps first. Look at some of the sample here: http://s807.photobucket.com/home/budm/allalbums
Jan 02, 2010 | Acer AL1706AB LCD Monitor
X191w blank screen after 2 seconds
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
Oct 07, 2008 | Acer X191WSD Monitor
Dec 25, 2007 | Acer 17" AL1706B LCD Monitor
"No Signal"
go to safe mode then reinstalll or update dispaly driver . other wise set the screen refreh rate to 60 hz
Dec 04, 2007 | Acer AL1916B 19" LCD Monitor
Acer monitor
What do you mean by it takes awhile to come on? Sometimes with these monitors depending on the type you have it takes time for the PC to pick up the signal. I have my PC hooked up to a KVM switch and it takes about 10 to 20 seconds for my monitors signal to be recognized.
Nov 15, 2007 | Acer AL1916W 19" LCD Monitor
Acer Al 1711 Monitor
Turn the monitor ON and continue to hold the power button for a few seconds.
Worked for me :)
Nov 09, 2007 | Acer AL1711 17" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
