Question about Bosch Dishwashers
Dishwasher runs for to long
Is set for 65 min but runs for 195 min
  • Bosch Master
  • 3,247 Answers
Most likely the inlet hot water is not of correct temperature or if dishwasher has its own heater then the heater in dishwasher is failing to heat water to correct temperature or the thermostat is failing.
Posted on Apr 18, 2014
Testimonial: "Thank you for your solution. The dishwasher appears to be ok at 65 degree so I now believe the thermostat is failing. Is there an easy fix for this?"
  • 2 more comments
  • Sam Apr 19, 2014
    will need the full model number to assess
  • Jan Barrance
    Jan Barrance Apr 28, 2014
    Hello Sam, The dishwasher is still the same; I've been away from this PC however thank you for your continued support. The model number is SGS45E02GB/45.
  • Sam Apr 28, 2014
    The thermostat needs to be replaced. It is located in the base of the dishwasher and needs access from the bottom of the unit. Refer diagram 4 on this site and position 0110 in parts list. Sensor NTC.
  • Sam Apr 28, 2014
    http://www.bosch-home.co.uk/store/sparep...
Can I use 195 55 r15 instead of 195 65 r15?
yes
you have to fit the same size tires on the same axle
so if you want to fit 195 -55-r15 on a steer wheel you must fit one on the other steer wheel as well
Nov 22, 2015 | 2005 Toyota Corolla
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
I have a 2005 nissan sentra. Tire size is 195/60 R15. I have the chance to get 2 195/65 R15 tires at a good price, and want to put them on the back, keeping the 195/60's on the front. Will this be OK? Some...
Hi!
195(width in mm)/60(sidewall height in % of width) R15(rim diameter)
This means, a 195/60 R15 rides lower than a 195/65 R15 tire. Imagine how it would look like when you put these different tire sizes on one car. It can be done but the car will be unbalanced both mechanically and aesthetically. Remember, your car was not designed for different front and rear tire sizes unlike some sports cars.
A 2005 model will most like come standard with ABS as with most cars produced year 2001 onwards.
Just buy 1 tire size for your car. If you wish to change to another tire size, change all the tires.
Feb 21, 2011 | 2005 Nissan Sentra
We have a fairly new furnace. I have the temp set at 65 the furnace only runs for 3 min at a time and comes on every 5 min. This sounds extreme to me?
It depends on the differential that you have programmed into the thermostat. In most of them you can set the temperature you want the thermostat to activate, and then you set the run differential such as three degrees below 65. In other words, the thermostat will activate at 62, and drive the temperature up to 65, cut off and wait for the temperature to drop to 62, where it cuts on again. see:
http://yourhome.honeywell.com/home/Products/Thermostats/
Check http://homeappliance.manualsonline.com/manuals/mfg/honeywell/8000.html to see if you can find the manual if you have lost yours.
Dec 07, 2010 | Honeywell Heat/Cool Thermostat
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Tire size
From a legal stanpoint? Do you have inspections that require stock equipment? Might want to be careful there.--other than that from a mechanical standpoint the outside diameter of the tire needs to be real close and honestly it sure sounds like youd be there. Maybe about ten milimeters off in total--but that would represent about 3 mile per hour difference in speedometer reading. not bad. Hope I helped. Thanks
Apr 06, 2009 | 2004 Chevrolet Cavalier
92 Audi Avant 17" tire size
as a rule of thumb every inch bigger you go, you want to go 10% lower on the aspect ratio. so the 195/65/15 will be 195/45/17 and the 205/60/15 will be 205/40/17. the 205/40/17 are a lot more common there for a wider selection and lower price. Good Luck
Jan 13, 2009 | 2004 Audi allroad
Heater in 200 gmc sierra is not workinmg
make sure antifreeze is full. run engine 10 min. verify engine is around 195 degrees. if not, try replacing thermostat. if it is running at 195, then maybe heater core problem or heater control not functioning properly
Nov 16, 2008 | 2000 GMC New Sierra 1500
Dishwashers Logo
152 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
