Question about Biostar G41D3 Intel G41 Socket 775 Motherboard
Reset video size - Biostar G41D3 Intel G41 Socket 775 Motherboard
Why is video stretched?
Removing the power erased the memory setting for screen size. Locate and go in the menu controlling size and reset.
Sep 07, 2015 | Televison & Video
Wrt320n cuts dsl speed in half
You can try changing the MTU size on the router to 1365.
Open the setup page of the router.
On the setup page you will see MTU, change it to manual and change the size to 1365. Save the settings and power cycle the router.
You can also try to upgrade the firmware on the router.
After upgrading the firmware on the router, reset the router and reconfigure it.
See HOW to upgrade firmware on the router
Watch video : How to reset the router.
utube.png You-Tube video "zOp-zkn4JsY" placeholder
Apr 04, 2012 | Linksys WRT320N Wireless Router
Where is the reset button on jdvd300mk11
If there is a reset switch, it will be a pencil tip sized indentation on the face, It will not be marked. If there is no reset switch, you can reset the radio by disconnecting the battery for a few seconds.
Oct 11, 2011 | Jensen VM9020TS Car DVD Player
How I can reset a Clarion MAX385VD?
If there is a reset switch, there will be a pencil tip sized depression somewhere on the face. It will not be marked. If there is no reset switch, just disconnect the battery for a minute or so.
Jun 22, 2011 | Clarion MAX385VD Car DVD Player
Megapixels on camera needs to be reset?
You can check the user manual to change again the resolution settings, or just reset the camera to the factory settings through the menu settings (last and bottom setting option).
Best regards,
May 28, 2009 | Canon PowerShot S3 IS Digital Camera
What is the AGP aperture size? Can I reset to 128,000?
It depends on how much physical RAM you have. Whatever you set the aperture size to, it should draw that much from your RAM to allocate towards video memory, so if you only have 128mb of RAM, I wouldn't set it to 128.
May 08, 2009 | Gigabyte GA-7VAXP Ultra Motherboard
19" Samsung Monitor Image size function, distroted
Yes, this can be reset by pulling up your video card utility window. this should be located on the right hand side of the task bar. it should be a background utility. Just reset all settings to default in the video res tab...
Jan 28, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Sony Cypershot Digtial Cameras Video file is Screwed up.
Please reset camera to get ride of this small size picture playback problem.
Go to camera menu and find initialize option, select it and press OK
Jan 27, 2009 | Sony Cybershot DSC-H3 Digital Camera
Video Settings
Hey there,
I remember reading about this in my manual
It's under one of the TIP! sections, on page 46 under the 'Video Camera' topic. It says the following;
  • "When you exit the video camera all your settings will return to default, except Video Size and Video Quality. Any non-default setting you require will need to be reset, for example colour tone and white balance. Check them before you shoot your next video."
Same applies to the Camera settings on page 43;
  • "When you exit the camera, all yours settings will return to default, except image size and image quality. Any non-default settings you require will need to be reset, for example, colour tone and ISO, Check them before you take your next photo."
Hope this helps!
- Ness. :3
Oct 29, 2008 | LG Secret ? KF750 Cellular Phone
Reset button ?
A tiny pin size button just below the "Mode" and "Next Track '>>I' " button.
Aug 10, 2008 | Dual XDVD8181 Car Video Player
Biostar G41D3 Intel G41 Socket 775 Motherboard Logo
12 people viewed this question
Top Biostar Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
