Question about Westinghouse Freezers
Chest freezer suddenly stops working then will start again later
  • Westinghouse Master
  • 744 Answers
This is normal if your freezer is in good working condition. If your compressor runs constantly then there is a problem. Once the unit reaches the set temperature the compressor shuts down. The set temperature should be between -2 & +2 degree F. The set temperature also depends on how full the freezer is. There will be a time when the freezer like refrigerators will shut down. This is relative to the term, "Frost Free". The unit will shut down for about 10 minutes. This occurs ever 8-10 hours. The heater turns on to defrost your freezer coil. It sounds like you are in good shape.
Posted on Oct 26, 2014
  • 1122 Answers
SOURCE: fridgidaire chest freezer problem
go to your local appliance store and buy a 3 in 1 starter kit,install, directions are with kit,this is your last hope as the compressor is getting weak,hope this help-mike
Posted on Jun 02, 2008
  • 124 Answers
SOURCE: freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Posted on Nov 02, 2008
  • 358 Answers
SOURCE: Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
Posted on Apr 04, 2009
erpaalai
  • 999 Answers
SOURCE: compressor click
Possibly. However it sounds like the compressor is running hot which could be the relay assembly sticking with the start windings in the circuit.
Eric
Posted on Jan 24, 2010
  • 36 Answers
SOURCE: my chest freezer has stopped working . kelvinator
If the light isn't even coming on, check for voltage at the outlet. If that is good, check the bulb in a lamp or drop light. If both those check out, then the fun starts.
Could be that the thermostat is stuck (rusted) in the open or off position.
Posted on Mar 03, 2010
My reset button on my chest Ken more freezer keeps going off. Push reset it stops then hours later goes off again
There is an excessive current draw. The compressor is the first thing to check, then the inside and outside fan motors. If there is a strip defrost heater element that has gone bad, that will do it too.
Mar 28, 2017 | Kenmore Freezers
I have a bush chest freezer CF-143GB. Recently the compressor runs continually. It can be stopped by turning the thermostat right down. A little while later and having reset the temp control it restar
Sounds like it has an auto shutoff if issues arise
Try clearing all vents - inside (make sure vents not covered) and out (vacuum - the coil areas)
Sep 11, 2014 | Freezers
My chest freezer has stopped working . kelvinator H150H*13. I switched it off as it was not being used, then switched it back on again 2 weeks later but its not working at all. The light does not come on...
Mar 03, 2010 | Freezers
I was just given a ge chest freezer model # cb10 dk serial number vv186793. i cleaned it up and plugged it in about 5 minutes later it started buzzing . i turned the control to the lowest setting (0). and...
switch on and leave it to freeze.approx 24hours.buzzing could be compressor working overtime to get cold.or in fact the freezer is not on a level surface.
Mar 02, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
Compressor click
Eric
Jan 24, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezes for 7 to 14 days then just quits!
hate to tell you but your compressor is going out on your freezer ,,, i'd look for another freezer.
Larry
Oct 28, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Fridgidaire chest freezer problem
May 21, 2008 | Freezers
Freezers Logo
170 people viewed this question
Top Westinghouse Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Westinghouse Freezer Expert? Answer questions, earn points and help others
