Question about Siemens Dryers
My Siemens IQ-700 tumble dryer not heating during drying cycle. It is a WT46W572DN/16 condenser model. How can I reset it? Is there a high heat emergency switch somewhere in it? Any source maybe for a user's manual? The original is missing... Thanks
    Habit-Forming:
    New Friend:
  • 186 Answers
Ok there could be several things preventing it from heating, here is a list gas valves, heat limit switches, bad thermostat, bad sensor. Time to open it up and get to testing. Sorry but this not one with a simple answer..
Posted on Apr 19, 2014
  • 126 Answers
SOURCE: Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Posted on Dec 13, 2007
  • 113 Answers
SOURCE: no heat in tumble dryer
Is this a gas dryer, if so check the thermal fuse, should be white plastic with 2 wire ports. These tend to bad first. Thanks Dave www.washermd.com
Posted on Dec 16, 2008
barkencoa
  • 3463 Answers
SOURCE: I don't have any heat from my hotpoint aquarius ctd40G tumble dry
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Posted on Jan 07, 2009
rogrrabbit
  • 986 Answers
SOURCE: Hoover Condenser Tumble dryer HSC 170 not heating up
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Nov 27, 2009
  • 77 Answers
SOURCE: no heat from dryer
This is a common problem with ALL electric dryers. What is most likely the problem is either a) your heating element has broken or b) your high limit cutoff has blown (this is simply a fuse that blows when it gets to hot). These problems almost 100% are cause from a vent that is clogged.
To know if your vent is clogged you go outside where the dryer vent exits the house. The air flow should be quite good, and you should be able to hear it from several feet away. If you feel no air, you have a clog. The clog MUST be fixed or you will have the same problem again.
To figure out what has gone wrong with the dryer we have to access the back of the machine. UNPLUG the dryer from the wall. Pull the dryer away and get behind. Remove the back panel (8 1/4 inch screws). The heating element is at the bottom right. There are two 1/4 inch screws holding it in. There will also be 2-3 wires on the left hand side. Note where these were plugged in, and then disconnect them.
Now, with the heating element in your hands you can see the coils. These glow red when the dryer works and get extremely hot. I pinch two coils at a time and look for a break. If you can visually see a coil broken that is your problem. If you have a multimeter you can check the continuity of the heater by touching your leads to the terminals the red wires you disconnected were plugged into. If the heater is fine, reconnect it.
Above the heater is the high limit cutoff. It has two wires going to it. The only way to know if it is good is to check it with a multimeter. If you know someone that can check the continuity, do it. These are 90% - 95% of the problem. But keep in mind, they are not the source of the problem. The heating element breaks for a reason, and the high limit cutoff blows for a reason. Check your vent!
Now, your model number is missing a character in between the 4 and the Q. I will need this to be complete and I can tell you the part numbers or the heating element and cutoff switch and an average price :)
Posted on May 29, 2010
Testimonial: "Yup it was the heater!! I was able to remove and replace it for a fraction of what it would have cost me to have the repair man do it. Thanks for all your help."
Where is the filter on tumble dryer AWZ241
Hi Angie, The filter is at the back right in the middle, You pull the cover off and clean off the lint.........CHEERS..
Apr 27, 2016 | Electrolux IQ-Touch EIMED55IIW 27"...
When dryer is on there is a smell of catfood/fish while clothes are drying.
Move dryer and look for cat food/fish under or behind. The heat may be activation the order.
Jan 14, 2015 | Siemens WT46W568GB Condenser Tumble Dryer,...
I want to know how hot my dryer gets. I do not have temp. controls on my model
Good Morning Tabitha,
I see that you are looking to see how hot your Frigidaire dryer, model# FER311FS, actually gets, due to you not having temperature controls on your particular model. Being that you have just the timed dry cycle, it provides up to 100 minutes of drying time at high heat for regular and permanent press items. When drying permanent press items, turn the cycle selector to 40-50 minutes. This is the average time needed to dry most loads of permanent press items. The load tumbles without heat during the last 10 minutes of the Timed Dry cycle. Use this setting to refresh clothing, pillows or blankets or to dust draperies. Heat-sensitive items such as plastics, foam rubber or similarly textured rubber-like materials or items containing feathers or down should be dried only with this setting. Hope this is helpful.
-Best Regards-
Mar 17, 2014 | Frigidaire FER311FS Electric Dryer
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
I need advice on dryer for my kitchen.
This isn't an add its two different units that I have installed and are both condensation dryers. Which in my opinion is better for your needs and lacking venting.....LG and Miele also have 15 cycle so now the decision is what your needs and Budget. Prices range from 700-1500 but well worth the money. Bosch Axxis Condensation Dryer (model: WTMC8320US) you can machine-dry clothes without venting hot, moist air (or indeed any air at all). The Axxis Condensation Clothes Dryer condenses the moisture in the hot air to water and releases it through the water the need for ducting and a blower motor to help expel hot air. Ventless dryers make installation easy, fast, and very cost effective. And since little heat is lost when the air passes through the condensing chamber, it takes very little energy to raise the temperature back to optimal drying levels, thereby saving you energy. The Bosch Axxis ventless dryer features the unique DUO TRONIC system with 11 auto dry cycles that tailor the drying cycle to your clothing. And Bosch's exclusive DUO TRONIC system combines two moisture and three temperature sensors to automatically deliver precision drying. This machine virtually operates at the touch of a button to prevent over drying and damage to your clothes. With the stacking unit I think this is your best option due to keeping moisture, and later mold problems due too condensation. The Ariston Stackable Condensing Dryer ASL75CXSNA is the perfect choice for any home lacking venting capabilities and is the largest condenser dryer on the market, bringing the convenience of a compact laundry system to any home. Wrinkles are minimized with the innovative Pre and Post CreaseCare feature - periodically tumbling the clothing until you come back to remove it - and the handy Bidirectional Rotation of the stainless steel drying drum. Clothes gone musty from long closet stays can be quickly and easily refreshed with the ASL75CXSNA using the intuitive Air Fluff cycle, and the 12-hour Delay Timer allows for freshly-dried loads at your convenience.Key features include: spacious 16-pound load capacity; 180º reversible full metal door; removable lint filter; included stacking kit; Easy Iron option; and electronic Sensor Controls. The Ariston Stackable Condensing Dryer ASL75CXSNA has the high class, top performance, and compact convenience to be a welcome addition to any energy efficient home.Note: This item pairs with the matching Ariston Stackable Washers. I hope this was helpfull~ Have a good day
Feb 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Dryers Logo
852 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
