Question about Freezers
Freezer insulation ice plug is re-forming 10cm down the drain pipe and up to the tray in freezer's back. A tech said that there is water, inside, down at the (injected) Polystyrene insulation, and that it is impossible to dry, and I would have to buy new Fridge !. I had to melt the ice every ~10 days since. Is there a way to remove & dry it = drill from back ( to where the drain pipe meets the freezer built-in pipe ) or from main (lower) compartment up ?
  • 884 Answers
Could you fit a trace heater inside the drain tube to keep the ice from forming? Or extend the dripdown time after defrost cycle so the water doesn't accumulate? If the tech thinks the insulation has blown, it may be time to bite the bullet and replace the fridge.
Posted on Apr 30, 2014
  • Ilan B
    Ilan B Apr 30, 2014
    Thanks for the help.
  • Ilan B
    Ilan B Apr 30, 2014
    The Tech insists its the wet insulation, that he verified the heater sys works. I did try a copper wire but its a glass tube heater and it didn't work. Seems once there's ice plug in the drain pipe there's no other solution but to build a heater. I am thinking on using a Fridge V to 12V Relay to activate a DIY heater with external power block and run the wires up the drain pipe. Though it needs to produce low heat I don't want the risk of influencing the fridge's power scheme. I got e-cig coil wire and var V adapter to find the sweet spot. but i never actualy made such... thx again
fixitallguy
  • 11 Answers
SOURCE: layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
Posted on Jan 25, 2008
  • 124 Answers
SOURCE: Upright Freezer not freezing,
looks like low on freon. that causes freeze up. oddly enough they freeze up when charge is low , just the opposite of what you think they would do. you have a freon leak unfortunately. probably not accessible, and therefore not repairable. i would suggest, cut your losses and buy new. unfortunately for me and all other srevice techs, the days of affordable repair are over, you can now replace cheaper than i can fix and have a warranty and its new... good luck
Posted on Nov 27, 2008
tborn6
  • 700 Answers
SOURCE: Ice forms on copper pipe under freezer off compressor
it sound like your unit has a bad sensor on it or a leak. you should never have to add refrigerant to a unit unless theres a leak then it has to be repaired firdt the recharged.
Posted on Jan 11, 2009
  • 109 Answers
SOURCE: Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Posted on Aug 23, 2009
Testimonial: "So far that worked great, we will see if it continues to drain when the freezer is back on and does it defrost cycle."
TheMobilian
  • 8220 Answers
SOURCE: Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Posted on Feb 05, 2010
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Model No.ERF415M 13CT. I have ice forming underneath the bottom freezer draw, when I open the door it melts and runs out as water under the appliance.
drain is plugged up were it is normally drain to defrost the freezer completely find a place to store food in freezer for a few ours leave door of freezer open pull out all shelfs and lay a few tools down at bottom of freezer were you seen the ice build up after you have done that pull ref away from wall take back of bottom look fro drain pan with a turkey baster send water thru back of freezer inside if water still flows back out into freezer drain tube is still clogged use warm water when doing this if you see drain pan full of water use a shop vac that can deal with water suck out water send water again water should go strait to drain pan if still flows out may have to remove drain tube
Aug 23, 2011 | Daewoo Freezers
We appear to have a blockage in the pipe that takes liquid from the fride part of our FFSS70 model. Because of this we get water forming in the bottom of the fridge each day.We have tried all ways to try...
Hi Bob. First off let me say that a clogged compartment drain with ice in it can be a real pain. Portable hair dryers don't work because the water insulates the ice. You may not like the answer here but this is several decades of hands on exerience speaking. So here goes......
1. Unplug the unit.
2. Empty the contents of the freezer
3. Place a fan blowing into the freezer section for well over 2 hours.
(THIS MAKES A MESS so be ready with rags and a mop)
<After external fan period and mess period>
4. Get yourself a single strand of #14 gage household electrical wire with insulation. Strip the end of the wire about 1 inch on the very end of the wire, fold it back on itself so that there is not a sharp end. (Flat tight U Loop) and start pushing it through the drain. If you hit any blockages or elbows try bending the loop just slightly. (Just do not force it really hard as you may detach the drain tube from the freezer compartment. Measure the distance that you have traveled the wire through the drain. It is pretty much a straight shot top to under the bottom of the chassis at which point there are some bends. Once you know you have reached the bottom of the chassis... pour HOT water thru the drain and observe the lower catch tray in the bottom of the unit checking for water flow from the tube. Often the plastic tray in the bottom of the unit has water in it just as a result of normal defrosting. The end of the cabinet drain tube sits in that tray. Over time the dust and lint that collects forms an ugly goo in the plastic tray. That goo eventually dries out and can also encapsulate the end of the drain tube. Make sure to clean the drain pain and the end of the drain tube during this process.
If you have problems and there is water in the drain that you need to remove; a roast baster works pretty good for removal of the water near the drain.
While you have it manually defrosted do your best to clean the drain top and bottom. These 2 areas are where most blockages occur.
Once your all done cleaning... wipe the bottom catch tray dry.
Pour a measure amount of water 50 ml or so in the top drain.
Check to make sure you get 50 ml at the catch tray. If you do not get close to what you put in.. at least 45 ml. Then there is a problem with the drain tube. i.e Hole, pinch, fold etc.
Getting the unit to room temp... (Fan) and letting the room temp defrost the ice in the tube is the best way to clear this. Slow process but a must do. There really is not a fast way to do this. If you don't have access to a piece of wire... a larger LONG plastic ZIP / Cable / Spot tie (Like they use for handcuffs) will work well also.
Just a final note. I looked up your unit parts via Hotpoint UK.
http://www.hotpoint.co.uk/hotpoint (Model FFS70S)
There are 116 parts available and the drain is not listed.... be careful.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Hotpoint Freezers
Ice in bottom of upright freezer -- problem with tube position?
Hello, get a short piece of electrical wire and strip the insulation off. put a bend in one end and then hang it over the heater directly above the drain making sure the wire runs into the drain about an inch. the heat from the heater will make sure the drain stays clear. Hope this helps. Mike
Nov 19, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Aug 23, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Maytag Freezer mqu1556aew 2004-07.Ice buiding up on the bottom of freezer.
if self defrosting model check frozen drain in freezer
Aug 09, 2009 | Freezers
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Proline Freezer upright /not freezing down very well
Defrost it and see if you have lost the insulation aroundthe pipe. If you have you can use expanding spray fome insulation on it. like you use on your house.
Dec 27, 2008 | Freezers
Freezers Logo
145 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
