I have a little 1985 RCA (poss. model # EKR295S?) with a built in antenna. Is there ANY way to connect it up to a converter box for the transition?? On the back of the tv there are two screws under the base of the antenna in the upper left corner with wires connected to them. Then there are four screws on the botton left corner, two say UHF and two say VHF. There are wires connected to the two VHF screws only, but I have been able to get both VHF and UHF channels anyway. I have purchased two different converter type boxes and connected the wires to the screws in various combinations (the top two or the bottom two, with the old wires connected and without... etc.) but I do not know how to "intercept" the antenna signal into the converter box and back to the TV.
  • 1 more comment
  • weetray3 Jun 19, 2009
    I really don't want to get rid of this TV... Are you saying there's really nothing I can do? How would I connect up the digital antenna... It's worth a shot...
  • weetray3 Jun 20, 2009
    I will accept your solution, but I wanted to make sure I thanked you for your help and advice. I am not sure how this website works and I didn't know if it will let me after I click accept :) So, with that, THANK YOU!! :)
    Oh, I guess it does let me comment!! Thanks again!
  • 6,784 Answers
Hi, this will not work this way. the new signals are digitally encoded for the digital tuners. the 1985 RCA you are referring to , is a analog based tuner system. this will not work. I have actually tried to do this on one of my older sets as well to no avail. I also tried the Coaxial converter adapter as well and, this did not work as well. it really has a lot to do with the set up of the actual tuner.The actual set will need to be at least a 2000 model to accept the digital signal that the converter box will relay through the tuner. this signal is HD/digital and, on some network, HDTV as well.
It is possible to add a digital powered antenna to amplify and intercept these signals but, i doubt it. this set is a bit behind the transition. a newer set will help.
Posted on Jun 19, 2009
  • Michael Masters
    Michael Masters Jun 19, 2009
    Unfortunately, there is nothing you could possible do to make this work. its not what you are doing that is wrong, its just that, this Television is a bit behind the digital revolution. the analog internals will not accept the digitally encoded signal that the converter box will transmit. Your unit will have to have the latest tuner, which is coaxial based and not VhF/UHF(screw mounted interceptor module)based.
    I understand how you are feeling at this point. YOu are facing the inevitable decision of buying a new or used up to date set. i understand this is a tough decision but, its the only decision that will yield results in this situation unfortunately.
    You could us my method that failed when i actually tried it but, its worth a try. you will need a coaxial converter. this device is a 2 inch long cylinder like connector that will have a coaxial female connector on one end and, a VHF/UHF split connector(screw mount) connector on the other end. you will need to run the converter box feed through the coaxial female connector side. just insert the male coaxial cable in this side of the device then, take the opposite side, which is for the back of your set and, screw the split connectors under the screws and tighten. make sure it connected to the VHF side.
    Next, power the converter box up, and do a channel search. hopefully , this will work for you.
  • 1,170 Answers
How to Set Up a Digital Converter BoxConnecting the Box
There are two coaxial cable ports on the back of a digital converter box. There may also be RCA connectors for video and audio. To connect the box to your TV, you simply unplug the antenna from your TV, plug it into the converter box "Antenna In" port and run a coaxial cable from the "Out to TV" port to your television's "Antenna In" port.
Alternately, you can plug the antenna into the "Antenna In" on the box and use RCA cables to send video and audio to your TV. Nearly every television made since the 1980s has RCA inputs. Video is usually a single cable with yellow connectors on either end. Audio is a pair of red and white cables that must be connected red to red and white to white, or you won't get any sound. If you have a mono TV, you only need a single RCA cable to connect it, and the correct port should be labeled on the converter box.
Getting Channels
Once your digital converter box is hooked up to the television, turn on the converter box and your TV and tune your TV to either Channel 2 or Channel 3. From here, you can use menus in your converter box to scan for broadcast signals in your area. You should scan every few weeks, as more and more channels are being added to the digital lineup. Once the scan is complete, which should take about three minutes, the channels will be saved and you can tune them in using the remote that came with your converter box.
Note that you won't be using your TV's remote to change channels anymore. Your TV will need to stay tuned to one channel (or Video In if you're using RCA cables) to get the signal from the converter box.
Converter Troubleshooting
If you cannot watch television, first double check your connections. Make sure the cables are connected properly and that all connections are tight. Make sure that both the TV and the converter box are turned on, since you need both running to get a signal.
Tune the television to Channel 3, or switch the input source if you've used RCA cables. You should see a setup menu. If not, tune the television to Channel 2 or Channel 4, or cycle through the input sources on your TV. Once you find the menu, you'll know which channel or input source to use.
If you are not getting all of the channels you should be getting, try adjusting your antenna. Even a small adjustment can add more channels. Elevating the antenna, relocating it away from obstacles or changing its direction can help you pick up more channels.
If you do not have a good UHF antenna, you may need to get a new one. Digital television broadcasts on UHF channels (14 through 68). Older antennas may only have a small, bowtie-shaped antenna for picking up UHF signals. If you're in a rural area, a long-range UHF antenna might be needed to receive all the channels in your area.
If the picture is blocky, freezes or if the audio skips, it's a sign that the converter box isn't getting enough signal. This can happen as a result of weather or because the antenna isn't positioned properly. Try adjusting the antenna to improve the picture quality.
Hope I helped with the repair of your problem.
An Accept from you is how I get paid.
And a positive feed back tells me how I did with the repair.
Arjun
I have a Toshiba older TV that doesn't have HD digital converter box I bought a leaf ultimate antenna do I still need to use the converter box with this new antenna
if the tv does not have a built in hd digital tuner you need a Hd digital converter to analogue converter. What you need to be careful about is the available inputs on the TV if it only has AV in then you need a converter that transmits out RCA video or an analogue tv channel on RF the tv can tune into. Some of the new converters have HDMI out so if TV does not have HDMI input it won't connect. The antenna would go into the converter. Not sure how much signal you need you may need an rf amplifier if the signal is poor in your area.
Jun 01, 2015 | Toshiba Televison & Video
No antenna port for Olevia TV How do I connect outside antenna to Olevia monitor
you will have to use a VCR, DVD player that has a built in tuner, or an HD converter box. The HD converter box will have an antenna connection for the outside antenna. But will also have RCA outputs to connect your TV to the converter
Feb 05, 2013 | Olevia 237T 37 in. LCD TV
Hooking up antena & converter box
Good: Connect the antenna to the converter box where it says antenna/in. Connect the coax cable to where it says to tv/out on the converter box. Connect this cable to the coax/rf input on the television. Plug in and turn on the converter box and the television. Make sure the television is on channel 3 and follow the setup process that pops up on the screen.
Better: Connect RCA cables to the converter box where the yellow red and white holes are. Connect them to an RCA input on your television. If you don't have a red hole on the television that's ok, just connect yellow and white and leave the red plug dangling. Connect the antenna to the converter box where it says antenna/in. Plug in everything and turn everything on. Press the video/input/source button until you have located the setup screen for the converter box and follow the directions on the screen.
Dec 02, 2012 | GE 27GT271 TV
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
Is the rca true flat tv able to be used by putting up an antena -or will we need a convertor box ? currently we have direct tv and are thinking about canceling it and use an antena.
This model does not have a built in HD tuner (ATSC Tuner). You would need an HD antenna (that is a more recent antenna that receives UHF) and an HD converter box to get the newly broadcast HD signals.
Nov 06, 2009 | RCA TruFlat 27F520T 27" TV
I have a 1985 RCA tv. My go video worked just
you'll need to plug your go video to another socket on your tv.if there is only one , then you need a switch box.you can plug the converter and the go video in the switch box. so that you can use it alternately.
Jun 22, 2009 | GoVideo DVD Recorder/VCR with YesDVD
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Jan 01, 2009 | Televison & Video
GE Spacemaker TV/Radio combination Model #7-7650
Yes, you will need an external antenna to pull in the digital signals. It will not work with the built-in antenna on the GE. Alternately, you can use an external antenna (ie, rabbit ears), connect them to the converter box, then connect the converter box to the antenna jack on the back of the TV (I think it has one). Granted, not an elegant solution for a kitchen TV, but it beats not using it anymore.
Cheers
Nov 11, 2008 | GE Televison & Video
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
