Question about McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator
Change rod on enguine - McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator
Enguine code p1035 keeps coming keeps coming up, we've replaced 02 sensosensor, still running horrible and code still there
P0135 is a 1/1 o2 sensor heater performance fault (make sure that you are using factory o2 sensors) Chrysler products do not get along well with aftermarket also there is a computer flash that goes along with the new sensor
Mar 16, 2015 | 2005 Chrysler Town & Country
How to reset the change oil light on 2002 yukon Denali
this is in the operators guide, lost that?
Jul 15, 2014 | 2003 GMC Yukon XL
Engine light is on
this would indicate something wrong with the enguine such as a sensor or emissions control devise. take it to a mechanic and see what code pops up or try your auto parts store who may have a loaner code reader.
Jan 29, 2011 | 2005 Ford Ranger
1991 ramcharger 318 suddenly stalling out when i turn the heat on or the radio etc. voltage drops alternator tested ok so did the battery
check te ground. you should have a good ground from the battery to the enguine block and from the enguine block to the firewall somewhere but need both grounds.
Jan 29, 2011 | 1991 Dodge Ramcharger
2001 alero. the car will not start i changed the fuel filter, fuel pump. and it still seems its not getting fuel to the enguin.
Have you scanned the computer for trouble codes? The codes will give you and idea where to look for the problem. You need to check to see if the spark plugs are firing. You can verify that it's getting fuel by pulling one spark plug and see if it has wet fuel on the tip. This would have to be done immediately after attempting to start the car. Let me know what you find and I can better diagnose the possible causes of the no start condition. If I don't hear back from you, have a Merry Christmas.
Dec 23, 2010 | 2000 Oldsmobile Alero
2004 mazda 6 enguine noise
IS IT A TURBO WHISTLE TIPE NOISE? IF SO CHECK THE TEETH ON THE OIL PUMP AND THE CRANKSHAFT. IF DAMAGED REPLACE PUMP AND CRANKSHAFT.
Mar 30, 2010 | 2004 Mazda 6
1986 mazda 626 overheating only at hiway speeds
some times some the blower fan blow back you have checf the corret wait have flow too enguine
Aug 19, 2009 | 1986 Mazda 626 Coupe
Fed or Cali engine?
change o fix,the ecm,if the air flow dont work properly,and the enguine run rich,try another ecu.
Mar 13, 2009 | 1993 Suzuki Sidekick
Hello, How do you check the transmission fluid for a toyota highlander 2002?
Enguine at operating temperature, transmission selector lever in park.
Dec 07, 2008 | 2002 Toyota Highlander
McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator Logo
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
